Why does
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Why does
Page: [1]
Login
Why does - 3/21/2007 4:27:13 AM
rsking45
Status: offline
My cpp head for the floor while hoovering and I gently pull back on the right stickamd as soon as i let the stick center and the heli rises?
Aslo If I grab on the blades end I can move the up and down.While picking up on one blade end the opposit blade will move down.I would think that there is to much play in there.
correct?
       Post #: 1
RE: Why does - 3/23/2007 12:37:03 AM
mrasmm
Status: offline
Not sure about your slop q... check out bladecprepair.com... they go over all of the slop and where it is, and how much is ok... as far as the other problem, it is called sticky collective. I just posted on this within the last couple of days... you can look for that... or read up... this problem is well documented =)
_____________________________
I don't always check every thread I respond to, so feel free to PM me
(in reply to rsking45)
       Post #: 2
RE: Why does - 3/24/2007 7:01:52 PM
osterizer
Status: offline
The a/c's lift changes when you move the collective. It's normal to add power to maintain altitude when you tilt the rotor more than a smidge.
[Edit] Also, note that it is normal as well for the rotor to be able to tilt a bit in the head-- it's called flapping, and it's there to compensate for differential lift in forward flight. Whether yours is normal or not is something you should research (see other comments here), or take it to your local hobby shop or rc club and see if you can get someone to look at it for you.
< Message edited by osterizer -- 3/26/2007 6:00:48 AM >
(in reply to mrasmm)
       Post #: 3
RE: Why does - 3/24/2007 8:30:48 PM
choppersrule
Status: offline
Rsking45,
Sounds like you may have broken the spindle or the o-rings in the rotor hub popped out. Check it out closesly. Also, it could be that the screws that hold the grips onto the hub are loose, those should be tight and use loctite on the screws.
Dave / Choppersrule
quote:
ORIGINAL: rsking45
correct?
Left skid low....
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.392RCU5
