RE: Comp-Arf Extra 260 2.6m Q's/Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
98 inch Caribou - ARF
Seller:  AUSTARSMODEL
Details:   $820.00   |  4/15/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Comp-Arf Extra 260 2.6m Q's/Build
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/5/2007 10:19 PM
WinginIt
Score: 100
Last Login: 3/25/2013
Status: offline
Looks great Turbo.
Do you know how many coats of clear coat he used on it?
Doug
_____________________________
Doug
"HAVE YOU HUGGED YOUR DA TODAY?"
Hide Signatures
(in reply to marksextra)
       Post #: 76
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/5/2007 10:26 PM
k2bdv
Score: 100
Last Login: 12/15/2012
Status: offline
Man, that turned out really good.
Did you leave the bottum white?
Hide Signatures
       Post #: 77
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/5/2007 10:44 PM
camss69
Score: 105
Last Login: 5/24/2013
Status: offline
Awesome turbo, looks really good!
Not a YAK.
Hide Signatures
(in reply to k2bdv)
       Post #: 78
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/7/2007 5:35 AM
k2bdv
Score: 100
Status: offline
Hey Turbo,what kind of paint did you use?
Hide Signatures
(in reply to camss69)
       Post #: 79
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/7/2007 6:15 AM
marksextra
Score: 105
Last Login: 5/22/2013
Status: offline
Thanks guys, I'm pretty happy with it. To answer your questions, it has one coat of clear and DuPont paint was used (I believe). We left the bottom white because we are going to use vinyl on the underside of the wings. EXTRA on one and 260 on the other in a holographic silver. On the fuselage side, behind the wing we are also going to put EXTRA 260 in the same holographic silver vinyl. I can't wait until it's finally done.
Once you go Yak, you never go back!
Hide Signatures
(in reply to k2bdv)
       Post #: 80
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/7/2007 7:09 AM
WinginIt
Score: 100
Status: offline
Thanks for the info Turbo.
Darcy says ours should ship this week. Can't wait.
Doug
Doug
Hide Signatures
       Post #: 81
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/8/2007 7:53 AM
camss69
Score: 105
Status: offline
The 4.5" AirWild Aluminum spinner looks sweet on this plane, I picked mine up today!
Not a YAK.
Hide Signatures
(in reply to WinginIt)
       Post #: 82
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/9/2007 9:06 PM
marksextra
Score: 105
Status: offline
Tested the C/G last night and came out just a bit tail heavy. about an inch aft of the recommended 95mm.
zdz80, jmb can, 3 2600li-ion batts on the firewall, choke and throttle servos infront of the wing tube, one 8711 under the fuel tank....etc....
will try to move my batteries out a bit more, and maybe install my smoke pump.
all up weight will come in around 24lbs without pilot.
Hide Signatures
       Post #: 83
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/9/2007 9:45 PM
WinginIt
Score: 100
Status: offline
That's great news on the weight Turbo.
Ours are scheduled to be delivered tomorrow.
Doug
Doug
Hide Signatures
       Post #: 84
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/10/2007 3:37 AM
camss69
Score: 105
Status: offline
I finished my canopy last night, I tinted it using RC Car window tint spray paint, it came out ok, I probably won't use it again, but it came out ok.
I took out one of my 8711's off the rudder to help with the balance, I think the single 8711 should be enough to get the job done, and I can take out one matchbox helping the all up weight. I'm going to check it tonight and see what kind of difference it made. I'm aiming for the aft most recommended balance point, which I think they say is 95mm to start with.
I'm going to pick up the RX from the hobby shop tonight, how are you guys routing the RX antenna? Inside or out, on the top or side of the fuse? I'm going to use the 10ch JR PCM RX.
After talking to a couple comp-arf guys at the field I'm going to mount the matchboxes for the wings in the wings. I was going to leave them in the fuse close to the RX but they were saying they set all theirs up with them in the Wings and it works fine with just the two servos.
Not a YAK.
Hide Signatures
       Post #: 85
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/10/2007 6:34 AM
marksextra
Score: 105
Status: offline
Re-weighed mine without the pilot and this time got 25lbs 9oz. with zdz80, 3 2600li-ions, jmb can, etc...
moved the batteries up in front of the firewall on a tray I made. C/G came out at 115m from leading edge. Don't know what else I can do to get any further up front on the c/g. Bigger batts, lead, smoke, are all options I guess.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 86
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/11/2007 4:09 AM
WinginIt
Score: 100
Status: offline
Hey turbo and camss,
Any guess on when you guys might maiden????
K2BDV's and mine came in today. Boxes were damaged (one large hole in one and a few other bangs) but all was OK inside .
Doug
Hide Signatures
       Post #: 87
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/11/2007 5:44 AM
camss69
Score: 105
Status: offline
I may be looking at this weekend, I'm mounting the RX, Batts and Regs tonight, I just need to figure out a couple more servo extensions and pick them up tomorrow then make and install the engine baffle.
Then start locking everything down and setting throws, and i should be good to go.
Next weekend at the latest I hope as long as I can get some good weather!
Glad to hear your's made it ok! I picked mine up from the local FedEx, loaded it into the truck and didn't notice until I got the whole box unpacked that there was a pretty good size hole in the bottom of the box. Luckily mine was ok also.
Keep us updated on your progress!
Not a YAK.
Hide Signatures
       Post #: 88
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/11/2007 6:45 AM
WinginIt
Score: 100
Status: offline
We are looking forward to a flight report.
Doug
Hide Signatures
       Post #: 89
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/11/2007 7:47 AM
k2bdv
Score: 100
Status: offline
I notice that i'm missing the servo hatches for the wings..
Hide Signatures
       Post #: 90
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/12/2007 3:30 AM
WinginIt
Score: 100
Status: offline
Hey Guys,
These wing tubes weigh 15.5oz. A carbon fiber tube would be around 6oz. That would be a savings of over 1/2 lb. Anybody know the exact diameter of the tube and where we could get a carbon fiber one?
Doug
Hide Signatures
(in reply to k2bdv)
       Post #: 91
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/12/2007 3:52 AM
WinginIt
Score: 100
Status: offline
I found it duh!!!!
They are 40mm X 980mm. I guess a 1.5" carbon fiber tube would be suitable
Doug
Hide Signatures
       Post #: 92
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/12/2007 4:34 AM
camss69
Score: 105
Status: offline
You can find them here...
http://www.troybuiltmodels.com/WingTubes.htm
They have a 40mm x 1050 you could cut down to the right length and it's only $60.00
A full half pound would probably be worth it and it wouldn't upset the balance to change it out, you would just drop the half pound almost instantly.
Not a YAK.
Hide Signatures
       Post #: 93
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/12/2007 6:09 AM
WinginIt
Score: 100
Status: offline
I think the carbon tube is worth it.
Doug
Hide Signatures
       Post #: 94
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/12/2007 6:11 AM
WinginIt
Score: 100
Status: offline
Oh..... and Thanks Camss69 for the link.
Doug
Hide Signatures
       Post #: 95
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/13/2007 5:11 AM
marksextra
Score: 105
Status: offline
I had to move the ignition to the other side of the motor dome away from my rx batteries, just to be safe. Finished up the switches, and programmed the radio today. I test ran the motor briefly today. C/G is still about 110-115mm from the leading edge. but........
NEXT NICE DAY!.....I'M GOING TO MAIDEN.
Hide Signatures
       Post #: 96
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/13/2007 5:34 AM
WinginIt
Score: 100
Status: offline
After a close inspection of both our planes they have arrived in great shape although K2BVD's has the wing hatches missing. Darcy is taking care of that and it will be a while before they are needed anyway.
Am really excited to hear a flight report Turbo.
Doug
Hide Signatures
       Post #: 97
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/13/2007 9:15 AM
camss69
Score: 105
Status: offline
Turbo, I think your going to beat me to it, I'm probably looking at Thursday to next Saturday.
I spent 11 hours on it today trying to get it finished up.
A couple questions, how did you setup your choke? I'm trying to use a manual choke but can't seem to figure a way to get it to work so I can leave it on (the pushrod0 and still take the cowl off. Seems like the choke is always a pain to figure out. With the engine baffle in place it makes it pretty tough to see to thread a rod back onto the carb after installing the cowl.
Are you using RF filters on your servo leads?
I'm balancing at about 100mm right now running the single rudder servo. I figure if I want to go further I'll just drop in the second rudder servo. All my RX batts and regs are about 2" behind the landing gear mounts.
Can you post a pic of your tailwheel setup? I need to figure that out still also.
Thx!
Not a YAK.
Hide Signatures
       Post #: 98
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/13/2007 3:48 PM
k2bdv
Score: 100
Status: offline
On the landing gear, did you need to cut the slot where the gear goes in or did they slide in?
Mine are to big and it looks like im going to have to make it a little bigger.
Hide Signatures
       Post #: 99
RE: Comp-Arf Extra 260 2.6m Q's/Build - 5/13/2007 5:52 PM
camss69
Score: 105
Status: offline
Mine just barely fit on one side, I had to push it against the fuse on one side, I should probably take that one out and trim the hole so it's not against the fuse and going to cause a crack later.
I have noticed that there seems to be quite a lot of deviation on the landing gear where some are thicker and some are thinner than others. I've noticed this by people's comments on comp-arf on message boards.
Not a YAK.
Hide Signatures
(in reply to k2bdv)
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.469RCU1
