spinbotz
Joined: 4/26/2006 From: Grand Junction, CO, USA Status: offline
Glad to see your contributions, Juan and Golden Knight. I need to take pics of my skydiver setup asap for use as idea starters for someone to build just the skydiver itself, then purchase a custom made canopy, or if they are capable of sewing, also include to scale PDF files of airfoils commonly used for a ram type canopy. *Instructions cont:* cont from step 3 Arms can also be straight out, or slightly bent at the elbow for more throw. There are several ways to get plenty of proportional steering control via the arm and the trailing control riser. Depending on your particular setup, you can thread the steering riser through the rear metal loop where all the rear risers are connected and then tied to the respective control arm. Be sure that it's set up so as not to bind or get tangled with the other risers in the group. You can also do a direct canopy to hand connection where the riser is literally tied to the hand itself. This may offer the least amount of throw, but experiment once you get the arms working to find the best canopy trailing deflection possible. You want to have the ability to do as FULL of a flare as possible just before landing to set your diver down gently. 4. Skydivers come in many different styles. from GI joes modified heavily to allow internal micro to inbetween micro and standard sized servos, to totally entirely scratch built creations with custom sewn diving suits, store bought or home made hands, heads, arms, and legs, and hollow or board type body. *board type bodies are merely a flat body with exposed servos and often set up so that loose clothing hides most of the internals unless clothing is removed for maintenance or battery changes to skydiver.* Depending on if you want your own, unique skydiver, (I certainly did, though I do respect and like the ones available all ready to skydive) or want a true tested hobby quality skydiver pre made and ready to go, there are many ways to enter this fun growing theme of RC 5 Canopies. Ok, I know I really suck at sewing, so the best way to go, if you do too, *not saying you do if you ARE good at sewing* is to purchase a premade canopy from one of many fine online manufacturers available online. The shipping costs sometimes are included in the total price, but may also sometimes be a seperate cost as well. If you are good at sewing, then research online or try creating your own airfoil cross section as large as you may need for your skydiver's scale and weight. As the manufacturers have said before, *Dave Naylor, GoldenKnight, and Juan, among the many* it's open on what size chute and airfoil type you may need. There are both sport chutes, *faster, manueverable* and slower ones, *still manuverable, but not nearly as fast, and are unable to cut through a rather windy drop as well as a ram canopy designed for a faster fall/glide. 6 Ask the helpful fans of RC skydiving within this forum and other forums where rcskydivers are mentioned. they may be able to provide additional helpful hints, tips, and ideas on creating or buying a skydiver. (Folks, definitely feel welcome to add onto this thread within this forum if you wish. The more info about skydiving, the better!) Some items folks might ask questions of: Servo extensions for drop boxes, or, cutting a hole in a drop plane, or creating a drop plane/buying one Recommended Engine sizes and airplanes that have tested true to enabling skydivers to become airborne Repairing a skydiver after a dirt dive and how to maybe reinforce weak spots or catch them during a DIY to prevent future damage Customizing a skydiver for personal tastes in appearance, and performance. Add ons to skydivers, such as smoke, night time glow sticks/batt operated lights making the skydiver itself a smaller payload carrying model and dropping streamers or even tiny parachuters How tos on adding on a micro camera to a skydiver, *belly mount, or head mount if possible. *the camera would be the head.* Padding a skydiver against a dirt dive if the skydiver design allows and what type of padding recommended. Packing canopies and setting up pilot chutes correctly for near trouble free openings. More to be added on. *to get really creative, even think about free fall control, and making actual Wing Suits for your skydiver. *caution, ensure that the wing suit does not interfere with the control of the canopy once the canopy opens.* Rocket power? If a guy can strap on minature jet engines and fly through the air via a flying wing strapped to his back, one could concievably make a model version and use model rockets to propel him through the sky for a short distance. *note: this may fall under regulations disallowing building radio controlled rockets in essence. Please do not proceed if this is at all not allowed in your area or country.*
