(QHOR & SPA3D plans here) Wing with no spar and no glue needed
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> (QHOR & SPA3D plans here) Wing with no spar and no glue needed
Page: <<   < prev  18 19 20 21 22 23 24 25 [26] 27   next >   >>
Login
(QHOR & SPA3D plans here) Wing with no spar and no ... - 8/19/2003 6:55:21 AM
2thelmt
Status: offline
My old Quick 500 Viper only used one servo
It never had flutter, Ailerons are small.
Just tring to help with my experience, I guess we all fly differently-I'm a bit of crazy flyer, I like to Test the limits of speed with all my planes. Hence 2THELMT
Ian
(in reply to Tattoo)
       Post #: 626
(QHOR & SPA3D plans here) Wing with no spar and no ... - 8/19/2003 7:40:03 AM
3D Romeo
Status: offline
Ian
I was wondering what '2thelmt' meant...I should have known! LOL
I was hoping to have mine done to fly tomorrow...but it's looking like I probably won't have it done by then. I tend to over-analyze things, and also tend to go over-board making things as neat as I possibly can...these are not good traits for Coroplast & PVC planes! Oh well, at least I have (4) of the best looking PVC horns you'll ever see! LOL
I'll throw a picture up when it is done...but it is nothing special. I'm building it almost to the letter, and not putting any graphics on it. I'm still not exactly sure what my profile fuse will look like, and if I don't think of something soon, it'll probably just end up looking something like a 'Hots'.
_____________________________
See I told you I was a good Pilot...Doh!...Never mind...
       Post #: 627
(QHOR & SPA3D plans here) Wing with no spar and no ... - 8/23/2003 11:05:35 AM
CRrdr97
Status: offline
Hi, when i went to lowes and asked for pvd gutter pipe and they showed me pvc pipe. I can't find the square stuff. What else would it be called?
       Post #: 628
(QHOR & SPA3D plans here) Wing with no spar and no ... - 8/23/2003 11:40:55 PM
CRrdr97
Status: offline
pvc* sorry
       Post #: 629
(QHOR & SPA3D plans here) Wing with no spar and no ... - 8/24/2003 3:37:06 AM
dickj
Status: offline
I asled for the square pvc down spout at the rain gutter department
Whatever goes up, doesn't necessarily come back in the same conditon.
       Post #: 630
(QHOR & SPA3D plans here) Wing with no spar and no ... - 8/25/2003 7:12:21 PM
fd59
Status: offline
Just built a SPA3D this weekend. I used the blue pvc electrical boxes found at Wal-Mart (only 25 cents each!). Needed only two.
       Post #: 631
SPAD3D - 8/26/2003 7:39:23 PM
cpierre82
Status: offline
I had my first flight over the weekend & loved it.
       Post #: 632
(QHOR & SPA3D plans here) Wing with no spar and no ... - 8/27/2003 12:04:16 AM
Goinstraightup
Status: offline
Yeah, these are great!
What engine are you using cpierre82? Do you know what your final weight was?
       Post #: 633
spad - 8/27/2003 12:50:48 AM
cpierre82
Status: offline
im using a os 46fx. i did not check the weight. I'm also using a smaller battery pack & a small RX, but the OS46fx pull it like a rag doll. I may stiffen up the tail section and
the wing some.
       Post #: 634
Re: spad - 8/27/2003 1:12:59 AM
fd59
Status: offline
[QUOTE]Originally posted by cpierre82
the wing some.
[/QUOTE]
Put a Tower 46 muffler on that 46FX and watch it really come alive!!!! The best $15 you will ever spend!!!
       Post #: 635
(QHOR & SPA3D plans here) Wing with no spar and no ... - 8/27/2003 8:45:18 AM
Daddyo57
Status: offline
Well Tatoo, you seem to be the go to guy for these things!!! i just ordered a stack of coreplast from Harbor, in white, My question is, What are you using to achieve your great looking color schemes? Paint stick on or what? I am going to build a SPA3D unless you tell me another is better ( PQHOR or QUOR) intend to build the Gee Bee too cause it looks so cool. Going with the GMS 47 for power I think
Of all the things I have lost, I miss my mind the most...
       Post #: 636
3D: Great design, great flyer! - 8/27/2003 4:46:43 PM
Alvin Souphound
Status: offline
Hey Tattoo thanks for the plans for such a great flyer!
We have made several flights, and the boys with the expensive 3D's, big 4 strokes etc. want me to make them a SPAD 3D.
I'm using a TT42 for power, and reduced the size of the wing and fuselage by 2" so it would fit in my sub-compact car. The plane lifts off in a few feet, power is reduced to 1/2 or less throttle for rolls, loops etc. The roll rate is WOW! with those 4" controls, and 3"(each way) of throw. Well, you said "As much as possible" on the throws. Elevator with that much throw is touchy, and will sure chase it's tail, but requires TLC when landing.
My 1st SPAD is still logging flight time which speaks to the strength of your designs. Keep up the good work!!!
Alvin
All the best,
Alvin
       Post #: 637
Re: Re: spad - 8/27/2003 5:59:14 PM
cpierre82
Status: offline
[QUOTE]Originally posted by cvfd59
Put a Tower 46 muffler on that 46FX and watch it really come alive!!!! The best $15 you will ever spend!!! [/QUOTE]
i just order Tower's 46 muffler. i'll keep you posted.
       Post #: 638
(QHOR & SPA3D plans here) Wing with no spar and no ... - 8/27/2003 8:24:20 PM
Goinstraightup
Status: offline
[QUOTE]Originally posted by Daddyo57
What are you using to achieve your great looking color schemes? Paint stick on or what? [/QUOTE]
Daddyo,
The best thing I've found is the vinyl from the sign shop. They have every color imaginable and it is easy to apply. It is name brand too. My sign shop sells it to me for $2 a foot from a 2 foot wide spool. I've found that Sig decals work nice too. Just put a little windex down and then place your vinyl or decal. Then squeegie out the windex and you are set. It stays on for good. This is what is used on my PQHOR (which I love!).
Jeff A
Click to see fullsize image.
Click for fullsize
