Volcano 2 speed problems    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Volcano 2 speed problems
Page: [1]
Login
Volcano 2 speed problems - 3/23/2007 1:32 AM
damaged123
Score: 100
Last Login: 3/26/2007
Status: offline
I got the 2 speed for the volcano from redcat, installed and works fine, but it seems like its stuck in second considering it has less torque, but it may even be in first i wouldnt know since both spur gears spin...
It came with both the screws in the bottom screwed basically all the way in. I tries turning them both out a little, and one out a lot, but i dont know what to do to shift its always the same. Right now they are both all the way in. Which screw do i adjust i thought i only adjusted one not two
Hide Signatures
       Post #: 1
RE: Volcano 2 speed problems - 3/23/2007 1:55 AM
Chubbysdad
Score: 100
Last Login: 12/22/2009
Status: offline
the one screw needs to be all the way in. That is what holds it to the shaft. The other screw the further it is out, the sooner it will shift into second. There is a spring loaded lever you could say that when it spins round and round it comes out and catches the other gear and then it is in second.
_____________________________
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16, Redcat Earthquake, Redcat Drifter
Hide Signatures
(in reply to damaged123)
       Post #: 2
RE: Volcano 2 speed problems - 3/23/2007 2:21 AM
damaged123
Score: 100
Status: offline
whats a good start point? im assuming the one that is locking it is the straight one, and the offset one is the one i gotta adjust, but how far out is it ussually.....i have no idea where to start, and i have yet to realllly screw it out, only till the back of the screw is flush with the ring, so i could go a bit more but i didnt want to, seems most of my adjustments kept it in 2nd gear, cuz the acceleration was like half of what the stock single speed was.
Hide Signatures
(in reply to Chubbysdad)
       Post #: 3
RE: Volcano 2 speed problems - 3/23/2007 2:56 AM
glk420247
Score: 100
Last Login: 5/10/2012
Status: offline
you don't want to screw it out passed flush, because then the allen screw will actually hit the second gear and that will make it stick in second gear. If you look at the second gear which is the small of the 2 it has a little metal pin in it. When the little arm on the shifter opens up that's what it hits to go into second gear.
I would screw it all the way in, but not tight, just so it touches bottom, then about 2 turns out. Actually start with 1 and 1/2 then just keep turning out little by little, until you get it to shift. Just make sure the allen screw is not passed flush. Mine is 2 turn out, and maybe just a tad more or less. But some where in that range.
Also with you unscrewing the other allen screw you might have spun it out of position. The rod it connects to has a little flat spot where it tightens down to. If that is not tighten down in the right spot your shifter might not work properly. I hope this helps and makes sense.
Team Losi Lst2 (Kick azz truck)
Hide Signatures
       Post #: 4
RE: Volcano 2 speed problems - 3/23/2007 3:03 AM
glk420247
Score: 100
Status: offline
look at this thread here it show how it should be assembledhttp://www.rcuniverse.com/forum/m_4207842/mpage_7/key_/tm.htm Post #175
Ands then try this one It explains the shifter.http://www.rcuniverse.com/forum/m_4207842/mpage_1/key_/tm.htm Post # 20
These pictures are all past posts complementary of Popper and chubbsuncle
Chubbsuncle also did this one http://www.putfile.com/uncgreg/images/18903
< Message edited by glk420247 -- 3/23/2007 3:38 AM >
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
