ParkZoneFlyer
NY, USA Status: offline
Well... as jmir said, let's be fair about the Typhoon 3D2: People complained about the stiff elevator, now the elevator has hinges just like the ailerons Servoes are upgraded to digital, I don't know if they are any better, but the elevator is sure improved! It no longer has a weird, green TX with a Receiver that puts dual rates on the 5th channel; The ZX10 is 5 channels with ADDITIONAL dual-rates. It is also black and silver, and has X-port capability. People said the typhoon was twitchy... the transmitter now has built in expo. KE and rudder authority was generally weak... SFG's added. NiMH battery lacking in power... Quality Li-Poly substituted. ESC tends to burn out... Eflite 25AMP ESC replaced The ONLY things I could think of that would make this plane even better are (hint hint) wheel pants, transparent canopy, and maybe an outrunner motor standard. But hey, for only $10 more than the original, the Typhoon 2 is great!
_____________________________
Easiest way to hover? Fly a Kite!
