TNTtrucks
TN, USA Status: offline
quote:
Seems the faster/higher up you are the more glitch prone it is. I have to agree myself after today that it's distance and possible other interference from cell,high volt, towers etc. Didn't think of it, but I was flying in a much smaller field my last 3 flights, but back at my large field today... glitches! Most, but not all sadly, were at the far ends or higher up for some practice. Trying to get some knife edge spins per my new BYflyer mag and even holding control input through the manuver it did violenty jerk out a few times (at different points, top, middle, etc.), although I tried several. I did get some nice inverted flat spins out of trying that looked cool to me. Either weak holding servo or glitching I was guessing, but since it has a semi gentle entry and I noticed it there, I leaned more to a glitch. Had 2 motor cutouts on the 1 and only batt., go wind, so I'll re-program my esc too. Thanks for the info. alabama, I just opened my transmitter and connected the blue and black wire's (only ones) going to the top left (viewed from front) spring loaded switch. My switch was faulty and didn't work as it just flopped around and I'm sure it was causing cut-outs on me after testing. So by connecting the wires I effectively removed the switch and since I don't ever need to cut all transmitter output, I didn't replace the switch, just bypassed it. I wouldn't worry unless your switch doesn't spring back or work smoothly.
