RE: NEW Fliton Inspire 90 Pattern Plane    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> RE: NEW Fliton Inspire 90 Pattern Plane
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: NEW Fliton Inspire 90 Pattern Plane - 7/9/2007 10:24 AM
smok
Score: 100
Last Login: 12/19/2012
Status: offline
Jack, Sure it's about exchanging info and opinions and I do have mine too...
You do not have an Inspire 90 neither but you already know that you would need 8 hours to fix the covering... weren't you advising me to buy and build one before making comments ?
Btw. there may be better solutions but the dowel makes sense for my engineering experience in both planes - the 60 is very light and the surfaces would flex anyway if put to max deflection at speed. Also the 60's large surfaces are not intended to be flown at high rates at high speed, rather at low rates + speed or high rates 3D ( low speed ). And for the Inspire 90 - it is a pattern plane, so the deflections and forces are very low on the elevator. CPLR ( an obscure french pilot ) flies Futaba 9254 on the elevator on a 2 m Oxalys and it's plenty enough. Also with pattern CG location there is very low negative lift on the elevator anyway, so again the dowel should be just fine ( not that it's a best design but IMHO a valid one ).
Also your post sounds like "gee look 'everyone' says these planes are crap" and "just search the internet and you'll see what everyone says" - for me sounds line millions of flies can not be wrong too ;-)
Smok
Hide Signatures
(in reply to jfetter)
       Post #: 51
RE: NEW Fliton Inspire 90 Pattern Plane - 7/9/2007 6:33 PM
blackshark3
Score: 100
Last Login: 2/6/2008
Status: offline
Well I received mine about 10 days ago, until now I have the chance to open it....
Preliminary checking the contents and the instructions manual, I found:
1. The parts are built quite light... I did not actually weight each part with a weight, but feeling them by hands. Especially I have the empty fuse of an Excelleron just out of the box handy to compare. I hold the Excelleron fuse on one hand, the Inspire on the other, feeling both weight is similar, but noted that the Insipire fuse is longer, is designed with separate wings and had a much thicker backend, so my feeling is that the Inspire is actually constructed lighter. All parts are straight by eye checking....but who knows....I thought my Zen 120 "banana" was straight when it comes out of the box...
2. The covering, while triming is good, they are WM covering which IMO is easy to peel off and once off cannot be iron back on... Even so, WM covering are even better than those used by CMpro and ESM....Still at this price I would expected something like Monokote or Oracover.... Great looking decals though...
3. The control horns looks to be WM small 3 point horns.. While they are not bad, I would expect usage of the WM large 3 point horn... The engine mount is not soft mount, which is too substandard... Fuel tank, so so... FRP struts looks ok, but I shall substitute them for a set of reliable Bolly carbon gears and carts.... What? No carbon wing tube at this price?!
4. Design wise, there are lot of points not to my likings... First being that dowel to link both elevators, while yes its better than the staple, still for a pattern design I would expect in fuse elevator servo mount with linkages goes all the way from the middle to the end, also that out board rudder design... When I build mine I would try to modify it by putting both elevator and rudder back inside the fuse, pull pull for rudder, and use DEPS for elevator. I just don't like the dowel...personal taste. The canopy part is quite long so once taken off it shall give a large open area to work on... The more I see it, the more I feel that the Inspire 90 is design more for electric than for nitro... I might feel delighted about it if I am an electric fan, but I am not.... I plan to put in a set of YS110S with Hatori pipes, the cavity under the front fuse that is supposed for the pipe is too small to clear the Hatori pipe, judging from my eyes... The securing of the wings is also not to my likings... I would rather see screws goes from the fuse to the wing, or hooks and tension spring way, which I would try to modify it into...
Overall feeling, I would say the Inspire 90 is design from the ground up for electric, retro fit for engine... At this price, (over here it cost 100% more than Excelleron 90 and ESM Freestyle Adrenaline 120, 50% more than CMpro Leo 110 and the Otop 110, 30% more than WM Zen 120 and Spot On 110, all of these I once own and at the same market level) I would expect more from the Inspire 90...
My 0.002 cents....
_____________________________
Technical consultant
Hirobo Limited; Black Products; Cosmo Fuel
Hide Signatures
(in reply to smok)
       Post #: 52
RE: NEW Fliton Inspire 90 Pattern Plane - 7/10/2007 2:40 AM
jfetter
Score: 100
Last Login: 4/22/2013
Status: offline
quote:
ORIGINAL: smok
Smok
Smok,
True, I don't have an Inspire 90 because I went to my LHS and opened the box to get a good look, something you haven't even done. As for estimating the time to fix it, I'm sure you can estimate how long it takes to do things you are familiar with, say drive to the store, build a birdhouse, iron and straigthen a 90-sized plane, really not rocket science.
The dowel sucks, plain and simple, you may or may not know it but one hinge from each side of the elevator goes through the dowel, making the slight offset they created when they slotted it (granted, not intentionally) now play a bigger part in aligning the elevator halves. Had they simply supplied a dowel, for me to align as necessary by gluing without aligning the hinges too, perhaps your point would be valid but because they slotted it and made it integral to the inner-most hinge, they created another problem that others have noted and echoed.
I don't know why you are defending something you admittedly don't own or fly, it seems to me your motives are questionable. I am an avid Inspire 60 flier and one who went to his LHS as soon as an Inspire 90 came in to buy it, why would I knock it after being one of the first to go pick one up? Seems I at least have something to base my opinion on (yes, some of what I say is echoed in the build threads, I use this not to MAKE my point but to back it up) while you simply point out that it can't be that bad. I again say to you go and buy one, build it, fly it (the Inspire 60 is fine too) and then tell me I am wrong.
Opinion is one thing but informed opinion is another, right now your opinion as somone that hasen't actually held, built, flown or owned one is un-informed. I don't know why you insist it really can't be that bad or I am exaggerating or the masses of people that have posted are somehow all wrong. I was part of this thread back when Fliton announced the 90 was coming, I have been excited about it for months, my motives appear genuine. You on the other hand seem to just want to point out that you don't see any issues in your opinion, with something you don't own nor intend to buy, with no sense of ownership or vested interest in Fliton and no real basis on which to provide that opinion...
Jack
< Message edited by jfetter -- 7/10/2007 2:42 AM >
Hide Signatures
(in reply to smok)
       Post #: 53
RE: NEW Fliton Inspire 90 Pattern Plane - 7/10/2007 3:17 PM
smok
Score: 100
Status: offline
Speaking of questionable motives... your post sound genuinely like you want to discourage other people from buying anything Fliton, while you praise another product along with a note that it's XYZ $$s cheaper. I think anyone can make it's own opinion and does not need to be told that "masses of people" think this or that and therefore it must be taken for granted.
I have taken my time to examine an Inspire 60 both in a box in my LHS and another one of my club buddy, finished and flying at the field. So please do not change the facts that I have no first hand experience with Fliton, to back up your claims ( yes, this is one of dispute tricks to oppose something your adversary did NOT actually say ;-)
Actually once my Flip 3D dies ( which ain't look like it's going to be anytime soon ) then I am going to get an Inspire 60 for myself too, as I can see from my mate's Inspire that it's a plane that suits my preferences (light, hi-perf and that means needs good handling which I am OK to follow ). I do not think I am going to spend more time on this dispute, anyone can make his/her own mind anyway..
Smok
Hide Signatures
       Post #: 54
RE: NEW Fliton Inspire 90 Pattern Plane - 7/10/2007 4:35 PM
jfetter
Score: 100
Status: offline
quote:
ORIGINAL: smok
Smok
Smok,
Thank you for allowing us to make up our own minds, glad you suggested that as I was just lining up to buy an Inspire 90 since you said its a good plane. You are correct, I am warning others to look before they buy with this one, is that a bad thing? Also yes, I can highly recommend Hanger 9 based on what I see in their new kit (my first), I didn't use it to say buy them over Fliton, only to illustrate that both kits are about the same price yet worlds apart in quality (besides that they are totally different kinds of planes, harldy in direct competition).
How do you make a point, do you simply state something without any background or comparison? Aparantly your method of arguing somthing or making a point can't contain anything negative about what you are talking about nor mention any positives about competing products or technology because this would make you seem biased. You sound like someone defending something without really knowing what you are talking about.
Kudos for actually touching an Inspire and flying your buddies, that alone now makes you an expert so I must appologize for my own informed opinion. I guess having an opinion based on actually owning one, building one, having perhaps 150 flights on one, taking part in the original build threads for it, reading everything I can get on it, re-attaching the covering repeatedly and waiting anxiously for its "big brother" to hit the market doesn't outweigh your taking the controls for 2 minutes...
Jack
Hide Signatures
(in reply to smok)
       Post #: 55
RE: NEW Fliton Inspire 90 Pattern Plane - 7/11/2007 4:15 AM
huckinstix
Score: 100
Last Login: 12/5/2007
Status: offline
Blackshark, can you elaborate on why you think this plane is more for electric than glow and how other planes (that are hybrid) are better suited with that "hybrid" tag?
In regards to your comment about the wing assembly, I really like the wing assembly as opposed to my fliton extra freestyle where I have to screw it in sideways. Screwing it in from the top is a much easier option and I'm glad that was addressed.
The covering works well for me, it is not coming loose and it is very friendly to work with. No wrinkles out of the box b.t.w.
jfetter, the inspire 90 looks nothing like the inspire 60 in terms of design... so I have to strongly disagree with your "same plane but enlarged" theory. Given the scheme is similar, but thats about it. Look at the control surfaces alone for both planes, there is a huge difference. The Inspire 90 screams pattern while the 60 easily does both. 90 has a nice long tail moment. The fact that you throw that comment out there I think is hurting your credibility. Do people still believe that you can just blow an airplane up to a larger size? Its called Reynolds Number, read up on it sometime.
The plane flies better than anything I have ever flown in this size, so everyone can have their opinions on little knick-knacks but truth be told, this thing flies unbelievably well.
PS. Has it ever occured to any of you complainers to file a warranty claim with Fliton? Yes, they do offer warranty and darn good service at that too.
Hide Signatures
       Post #: 56
RE: NEW Fliton Inspire 90 Pattern Plane - 7/11/2007 4:53 AM
jfetter
Score: 100
Status: offline
quote:
ORIGINAL: huckinstix
What is so hard to accept about a guy who has an opinion that the Inspire 90 just isn't a good value? Geez, you'd think I took the US flag and burned it while running around with a Hitler mustache! The Plane flies well, true but it is not worth $359 (again, IMO), it still has the same weaknesses that the Inspire 60 has even after a large amount of criticism and time to make changes, is this really a point for debate? Clearly you like Fliton, as do I but don't think it has to be a black or white argument, I can like them and still be dissapointed in their product...
Jack
Hide Signatures
(in reply to huckinstix)
       Post #: 57
RE: NEW Fliton Inspire 90 Pattern Plane - 7/11/2007 10:22 AM
blackshark3
Score: 100
Status: offline
I have never own any "hybrid" plane before, so I could not comment on the difference between the Inspire 90 and other hybrid planes.....
My feeling that its designed from the ground up for electric is based on the facts that there are much fewer amenities for nitro engine fitting factored into the design of the plane, compared to electric. There is even no servo opening for placing the throttle servo, and no mention of how to place it in the manual! Yes nitro needs a servo, motor only need ESC, that's why Filton did not design for the throttle servo mounting hole. Also, that slot that goes under the cowling is designed for placing the ESC only, its too small for the short Hatori muffler, not to mention its impossible to use the older style long Hatori muffler. Further, for electric motor there is a very nice motor mount that comes with the kit, and the firewall already have slots opened to take that motor mount, which makes out a very clean and neat installation, but for nitro they only give a crappy engine mount without dampers, and I have to patch up all the slots opened for the electric motor mount on the firewall and improvise on mounting the engine. All these give the impression that Filton design the plane for electric, then throw in a crappy engine mount and a fuel tank to call it a hybrid....
As to the securing of the wings, yes I would say that having the screws facing on top is very convenient, but that lip, while ok for electirc, needs more "meat" to take the vibration of a 4 stroke nitro engine. Also, my friends' Inspire 90 comes with carbon wing tube, mine was black aluminum, maybe I had a lemon....
Overall, I like very much the cosmetic of the plane (Except for the elevator dowel...), and the construction is not bad, if I plan to fly electric with it I think I would like the Inspire 90 very much, but as a nitro guy I feel that while they named it according the size of a nitro engine, the Inspire simply does not provide enough design consideration for mounting a nitro engine. Further at this price I would expect better ingredient. Mine might fly very well with a nitro engine afterall, but just by looking at it in kit form now I am not impressed yet...
My 0.0002cent....
< Message edited by blackshark3 -- 7/11/2007 10:33 AM >
Hide Signatures
       Post #: 58
RE: NEW Fliton Inspire 90 Pattern Plane - 7/11/2007 3:46 PM
Funtana140
Score: 100
Last Login: 2/4/2009
Status: offline
The fact that you throw that comment out there I think is hurting your credibility. Do people still believe that you can just blow an airplane up to a larger size? Its called Reynolds Number, read up on it sometime. [/b
I'm sorry but I don't think that you need to account for Reynolds number when scaling up from a 60 size to a 90 size. His argument was perfectly sound in that he thought the plane was a slightly modified (for the purpose) and enlarged Inspire 60. I don't think that you can say that he is hurting his credibility when what he suggested is perfectly legitimate. Suggesting that he reads up on Reynolds number when the two models are going to be roughly the same size, flying in the same air with the same viscosity and similar speed just doesn't make any sense.
Hide Signatures
       Post #: 59
RE: NEW Fliton Inspire 90 Pattern Plane - 7/11/2007 5:40 PM
greg_m
Score: 100
Last Login: 3/19/2013
Status: offline
Hey y'awl
Stop freaking moanin about each others comments - jeeeeessssshhhhhhhhhh because of all of you I won't even bother to look at the plane or this thread again - well done on disappointing an interested reader with your load of personal critisism when all I wanted to know about was the bloody plane!!!!!
I thank blackshark3 for actually having a plane and giving me the best information on it - I now currently own a CMPro Leo 110 and am very happy with it as I am also a nitro fan - electric is for foamies I say - hahahaha
regards, Greg
Hide Signatures
(in reply to Funtana140)
       Post #: 60
RE: NEW Fliton Inspire 90 Pattern Plane - 7/16/2007 10:43 PM
kochj
Score: 143
Last Login: 5/18/2013
Status: offline
zzzzzzzzzzzzzzzzzzzzzzzzz
why don't you just call each other and talk about your comments?.
Thay way it doesn't boar the hell out of me.
Just kidding,
we all must realize that emotions will run high when a new plane is released. Even though you have no claim in the company or it's stock.
like power selection, glow, battery, os, YS, and everything in between, plane or brand loyalty is 90% emotion. JIMHO
Back to the Plane ....
I like pattern planes...
I don't own one but the price of 350$ is very close to the QQ 73 Gen II and I can put a gasser in that one.
I am aware that pattern planes are very exspensive. This one looks to be a better alternative to those that like a more precise plane (unlike the Funtana 100X which has much cupling)
The size does not seem to be that much bigger than the inspire 60.
It seems that from a marketing standpoint you would stop the production of the 60 and just stay withth e the 90?
I would think that a little larger would have been a better step for them.. 120-140 size pattern ship?
I am guessing that they are banking on the very popular size saito 125 and the OS 120AX engines to match with this plane.... I am trying to say that we may see in the future the disolvement of the 60 and only the 90 being in production... Or I may be wrong..
Nice plane though..
< Message edited by kochj -- 7/16/2007 10:46 PM >
If you can''''t dazzle em with brilliance,baffle em with BS
Hide Signatures
(in reply to greg_m)
       Post #: 61
RE: NEW Fliton Inspire 90 Pattern Plane - 7/17/2007 4:17 AM
BoneDoc
Score: 100
Last Login: 4/18/2011
Status: offline
The 60 and 90 are different. The Inspire 60 is a hybrid with oversized control surfaces, while the Inspire 90 is a pure pattern plane.
Josh
Hide Signatures
(in reply to kochj)
       Post #: 62
RE: NEW Fliton Inspire 90 Pattern Plane - 7/20/2007 2:32 AM
wagen017
Score: 100
Last Login: 5/19/2013
Status: offline
Agree with you Josh. The Inspire-90 is quite a different plane then the Inspire-60. It is much closer to the Infinity they produced before. I guess Fliton ran out of inspiration on names... . Luckily they seem to have plenty of inspiration for the planes! I really like the fact they now produced a what seems to be a real pattern plane (Iso another 3D).
Anyway I like the looks of it and I am awaiting the first flight reports.
volkert
Club Saito member #371
Hide Signatures
(in reply to BoneDoc)
       Post #: 63
RE: NEW Fliton Inspire 90 Pattern Plane - 7/20/2007 2:57 AM
jfetter
Score: 100
Status: offline
quote:
ORIGINAL: wagen017
volkert
Speaking of which, where are the flight reports? This thing has been out now several weeks, I wonder if the initial excitement dried up after folks looked at it close?
Jack
Hide Signatures
(in reply to wagen017)
       Post #: 64
RE: NEW Fliton Inspire 90 Pattern Plane - 7/20/2007 4:44 AM
BoneDoc
Score: 100
Status: offline
Jack,
There are only a few that are sold / released with this current batch. I've just gotten mine from Neumotors.com. I'm busy up the wazoo with residency and will try to squeeze a build thread in there somewhere. My gross impression (without taking anything out of the box) is that it's a great quality plane with a so-so hardware.
Josh
Hide Signatures
       Post #: 65
RE: NEW Fliton Inspire 90 Pattern Plane - 7/20/2007 6:37 AM
jfetter
Score: 100
Status: offline
quote:
ORIGINAL: BoneDoc
Jack,
I'm surprised by this, my LHS got 2 in about 2 weeks ago (when I initially went in, looked it over and decided not to buy it) and they still have the same 2 sitting in the store. I assumed folks have had them for at least 3 weeks now...
Jack
Hide Signatures
       Post #: 66
RE: NEW Fliton Inspire 90 Pattern Plane - 7/20/2007 7:27 AM
BoneDoc
Score: 100
Status: offline
I'll post some info later once I get my build going. I might decide to do a separate build thread.. or maybe stick with this one .
I got my kit from www.neumotors.com. $329 SHIPPED! That's a great deal.
< Message edited by BoneDoc -- 7/21/2007 10:08 AM >
Josh
Hide Signatures
       Post #: 67
RE: NEW Fliton Inspire 90 Pattern Plane - 7/21/2007 10:01 AM
BoneDoc
Score: 100
Status: offline
All right!
Let's get the building part of this thread started!
First of all, IMHO, this plane is a first quality build. Mine comes out straight from the box without ANY warping. The only wrinkle on the covering I've found so far is a small one at the bottom of the fuse (definitely not a deal breaker for me ). I think those who got jaded at the kit were either:
1. Disappointed at the hardware (especially the wheels) package, or the box (which if that is you, I'd have to question your criteria for "good" ).
2. Got unlucky with Mr. Brown
3. Got unlucky with your LHS beating up your package, or other people who opened the box prior to you messing everything up.
All kidding aside, here are some pics. Please note that I have not done ANYTHING to alter the appearance of the kit (ie. I have not spent the last 7 hrs reshrinking everything to remove the wrinkle / warp / etc)
Here's how I got her: Double boxed, very nicely packaged
Opening the Box, here is how she looks; very neatly packaged, very well protected
You can see here how each package is wrapped with foam, as well as plastic covering... NICE!
Removing the covering, you can see here how much care they put into making sure that it arrives to you unscathed. As a side note, mine is production #63 .
Josh
Hide Signatures
       Post #: 68
RE: NEW Fliton Inspire 90 Pattern Plane - 7/21/2007 10:06 AM
BoneDoc
Score: 100
Status: offline
FIT & FINISH OF THE KIT
Ok, here are some pics to show you the fit and finish of the kit
Look at how well seated the canopy is to the fuselage... Can't get any better than that.
Great looking painted fiberglass cowl. It definitely exudes ATTITUDE! .
Look, even the manual is plastic bagged and sealed, lol. I've perused through the manual, and it's well written, on par with the new AJ Extra manual, and DEFINITELY MUCH better than the 330 Freestyle.
< Message edited by BoneDoc -- 7/21/2007 10:07 AM >
Josh
Hide Signatures
       Post #: 69
RE: NEW Fliton Inspire 90 Pattern Plane - 7/21/2007 10:11 AM
BoneDoc
Score: 100
Status: offline
Straight & True
Looks pretty straight to me guys.
After less than 5 min of work. That looks awfully straight to me.
Josh
Hide Signatures
       Post #: 70
RE: NEW Fliton Inspire 90 Pattern Plane - 7/21/2007 10:25 AM
BoneDoc
Score: 100
Status: offline
INNOVATION AND UPGRADES AT THE FUSELAGE
For sure, this is NOT a scaled up Inspire 60. Looking inside, this definitely exudes the quality you'd expect from a 300+ dollar kit
Large shot at the fuselage. Very well engineered! Light but strong
See the level of engineering. From experience, I can tell you for sure that sheeting light ply like this is the best mix of strength and low weight.
Sheeted foam turtle deck. Schweet!!!
Sheeted belly pan. Shweet... again!
Josh
Hide Signatures
       Post #: 71
RE: NEW Fliton Inspire 90 Pattern Plane - 7/21/2007 10:35 AM
BoneDoc
Score: 100
Status: offline
TRUE HYBRID
To me, this is the best example of a true hybrid that I've seen to date. It's build light enough to satisfy electric modelers, but tough enough for the glow flyers. Looking at the fuselage, I have no doubt that it will withstand the punishment of rattling glow engines. There are some innovative things Fliton did though to make it a TRUE hybrid.
The firewall is unfinished so that you can accept either the electric / glow option (see pics below)
A firewall doubler, or an electric motor mount perfectly sized for Hacker A50 L series motor
Muffler tunnel that doubles as an ESC location. I had an Inspire 60, and this one is better built for sure.
Very nice touch here. A cooling hole built into the sheeted foam belly pan. SCHWEEEET!
Josh
Hide Signatures
       Post #: 72
RE: NEW Fliton Inspire 90 Pattern Plane - 7/21/2007 10:44 AM
BoneDoc
Score: 100
Status: offline
FLITON'S ACHILLES HEEL
Alas, Fliton's achilles hell has struck again ... the hardware department. IMHO, they're usable (besides the tires ). My Inspire 60 LG held up fine, and from the look of it, this one will also. For now, I'm planning to use everything stock, except for the wheels. I've got a set from my dearly departed Sig Mayhem that will fit it just fine. I agree that Fliton definitely needs to up their game on this area so that it will be up to par with the rest of the airplane / build / reputation.
Seriously though guys, don't let this alone deter you from buying an otherwise wonderful airframe.
Josh
Hide Signatures
       Post #: 73
RE: NEW Fliton Inspire 90 Pattern Plane - 7/21/2007 12:09 PM
smok
Score: 100
Status: offline
Just curious - what's the problem with the wheels ? They look like regular wheels for a pattern plane. Also pattern hardware is built to be light and precise, but not really to withstand significant forces ( as with small deflections the forces are moderate ). That is a difference from more heavy duty wheels for sport planes or from control horns for 3D, when large deflections and forces are expected. Pattern builders usually go to great length to save weight..
Just my 5c,
Smok
Hide Signatures
       Post #: 74
RE: NEW Fliton Inspire 90 Pattern Plane - 7/21/2007 12:28 PM
BoneDoc
Score: 100
Status: offline
They're functional. They're just the same small wheels found on the Inspire 60 as well as the 330 freestyle. My point with the wheels is that this is the worst part of the kit. They're not that bad, but this part would be the only thing I can come up with for people to not think that the plane is a superbly built model.
As for weight, I can tell you from experience that this is a strong and light airplane. They have reinforced the LG plate, so you don't have to worry about your less than perfect landing.
Josh
Hide Signatures
(in reply to smok)
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.891RCU1
