RE: MX450 XS Discussion Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> RE: MX450 XS Discussion Thread
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: MX450 XS Discussion Thread - 3/28/2007 1:04:43 AM
sammy64
Status: offline
I agree about the tape, but i have not order any new blades yet.. still waiting on a few parts ( Be careful when Tightening screws ) but i plan to fly this sunday with the stock blades on its first flight
(in reply to []TEX[])
       Post #: 51
RE: MX450 XS Discussion Thread - 3/28/2007 1:32:08 AM
[]TEX[]
Status: offline
I flew this afternoon and lost one screw from the seesaw. I was only 10ft off the ground at that point so I was lucky and was able to bring her down softly.
I took some screws fom my donor heli and thread locked them. Make sure you check those, you can't see them directly.
< Message edited by []TEX[] -- 3/28/2007 3:34:46 AM >
_____________________________
Raptor 50 Titan | T-Rex 600E
(in reply to sammy64)
       Post #: 52
RE: MX450 XS Discussion Thread - 3/28/2007 2:38:07 AM
[]TEX[]
Status: offline
The experience of loosing a screw helped the tracking issue. Since they are a bit hidden I missed them. I have a new screw in there, thread locked and tightened both, it tracks right on target.
Click to see fullsize image.
Click for fullsize
< Message edited by []TEX[] -- 3/28/2007 2:39:16 AM >
       Post #: 53
RE: MX450 XS Discussion Thread - 3/28/2007 3:31:01 AM
rabidbandit
Status: offline
TEX,
Great to hear about you finding the tracking issue I had one problem similar but turned out it was an out of spec (bad machining) bearing seat/stop in an aftermaket CNC main blade grip. When the darn head was stationary...I never found it loose. When it was rotating, the centri-forces on the grips would deform the bearing stop just enought to drop it about the 1/4 mark. The material that was supposed to retain and center the bearing was drilled out to large. Drove me nuts for weeks....could have lost a blade as weak as it was. This was ofcoarse the old "Sport 500" .45 nitro heli I used to have
Chris
AXE CP: Stock,.....
MX450XS: Stock,.....
       Post #: 54
RE: MX450 XS Discussion Thread - 3/28/2007 3:37:15 AM
[]TEX[]
Status: offline
How did you like the nitro compared to the 450?
My friend and I are arguing the fact that I should have gone to nitro instead, but I like the ease of electrics.
(in reply to rabidbandit)
       Post #: 55
RE: MX450 XS Discussion Thread - 3/29/2007 2:06:56 AM
sammy64
Status: offline
Is anyone one having a problem with the tail .. Using a 240 gyro and have the AVCS off.. i cant get Enough throw to get the Heli to spin on the ground in any direction.. i have expanded the push rod to where it has fallen apart with out to much force from the servo .. any ideas ??
       Post #: 56
RE: MX450 XS Discussion Thread - 3/29/2007 2:13:51 AM
[]TEX[]
Status: offline
quote:
ORIGINAL: sammy64
Take the 240 out of the equation and connect the rudder servo directly to the Rx. Make sure you center the servo horn. If if it still has little throw, check your EPA settings on the Tx. You should start at 100% EPA.
If the rudder servo works normally then it is possible the gyro is damaged.
Check the pitch slide on the shaft, it should move smoothly with the link off. If not try a drop of oil.
What radio are you using?
       Post #: 57
RE: MX450 XS Discussion Thread - 3/29/2007 2:48:34 AM
sammy64
Status: offline
I have tried it with the Gyro out of the picture and its the same ..Iam using an Futaba 6EXH W/3107 servos .. I think you mite be right about the EPA settings .. will chk in the AM
       Post #: 58
RE: MX450 XS Discussion Thread - 3/29/2007 3:15:46 AM
[]TEX[]
Status: offline
quote:
ORIGINAL: sammy64
Ok, hopefully that is the problem.
       Post #: 59
RE: MX450 XS Discussion Thread - 3/29/2007 11:04:32 AM
rollingball
Status: offline
I've noticed the the slider won't work right until the black coating wears off. It also helps to taper the bushing taking away the sharp edge. The oil will help greatly in the workings also.
Trial&Error - Repeat
       Post #: 60
RE: MX450 XS Discussion Thread - 3/29/2007 11:43:32 PM
sammy64
Status: offline
Yes setting the EPA worked .. still think it mite need a little more.. i will keep working on it .. think about getting some sand paper and running the motor to sand down the tail shaft to see if thats the answer .. got to get this thing flying soon or its back to the AXE
(in reply to rollingball)
       Post #: 61
RE: MX450 XS Discussion Thread - 3/30/2007 1:32:21 AM
[]TEX[]
Status: offline
Thanks to Osterizer I got my Mahblades today. They are very nice and completely balanced. I am very impressed.
Click for fullsize
< Message edited by []TEX[] -- 3/30/2007 1:33:53 AM >
       Post #: 62
RE: MX450 XS Discussion Thread - 3/30/2007 1:33:35 AM
[]TEX[]
Status: offline
quote:
ORIGINAL: sammy64
Great to hear you found the problem!
       Post #: 63
RE: MX450 XS Discussion Thread - 3/30/2007 2:08:32 AM
