dooleyje
NC, USA Status: offline
quote:
ORIGINAL: osterizer quote:
ORIGINAL: dooleyje Another servo would be the Futaba 3154 thats made for the Gyros, super fast and digital smaller than the 65's. About $32. A tail servo needs to be super fast to keep up with the 401 and the ablility to run at the high frame rate. I use the 9257 because I use 5v, If you have a 6V esc then you need a 9650. The 3254 and 9257 will not run long on 6V. Sorry but the 65's would be a great choice for cyclic but way to slow for the tail and gyro to get any full benefit from the 401. Tail servo and gyro are not ones to skrimp on. My son's MX450 has a 3154 on it and it's good enough to hold in fast reverse flights, tail slides. Talking about gyro's, the next best thing out there is the new Spartan gyro and is the rage. It holds better than the Futaba 611. Jim Jim, the 3154 will in fact run on 6V, you just don't get much benefit from doing so. I've flown the MX extensively with the 3154, and it's fine for flying around right side up, but it isn't strong enough for continuous hard maneuvering. Similarly, I said the 65MG would be OK; not exceptional, but OK for someone who's flying circuits and hovering. If it's what you have in your box, it's fine to start with. Sorry the 3154 gets very hot and will burn out quickly on 6 volts and this is extensivly documented. Happen to me twice. The 3154 on 5V will allow me to to tail slides and fast reverse flight without blow out with a 401 gyro "properly set up". Thats my test for a gyro/servo combo. For $32 buck it is a fine tail servo. Jim
