osterizer
MD, USA Status: offline
Hi, hikai. It sounds like you have things going in the right directions. I've used the 3154 (digital version of the 3114), so I'm pretty sure the 3114 should work. I assume you've tried increasing the gain so the gyro will come in sooner? Also, it's probably fine, but you should also check the tail belt tension so you're sure it's not slipping. Did you check the pitch range on the tail? When mine was set up at 2400, I'd have about 5 degrees right pitch at neutral versus flat, then full right was about 40 degrees, and left maybe 10 degrees. I had the ball on the servo arm 7 or 8 mm from the center, then trimmed the neutral position in rate mode to hold zero with no transmitter trim by adjusting the length of the pushrod. If you can get it adjusted properly in rate mode, then AVCS will hold without a problem.
