100cc Yak Review
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> 100cc Yak Review
Page: [1] 2   next >   >>
Login
100cc Yak Review - 3/24/2007 5:27:56 PM
Mark Dennis
Status: offline
Hey guys,
Check out Joe Hunts latest review on our 100cc Yak 54 QB!
100cc Yak Review
Click to see fullsize image.
Click for fullsize
_____________________________
Team Aeroworks
Thank You: Aeroworks, Desert Aircraft, and Smart-Fly
       Post #: 1
RE: 100cc Yak Review - 3/25/2007 9:03:00 PM
Bobby Folsom
Status: offline
Mark, I flew my AQ QB 100cc Yak yesterday. It flew absolutely great!! It weights 29 lbs but you'd never know it. It has unlimited verticle doesn't bounce around in the wind, snaps so slow I'm going to have to learn how to do snaps all over, drops the nose just great in a stall and stops rotating in the spin when I let go of the sticks!!
I have a DA 100, MTW 75K canisters and a Biela 3-blade 26 x 10 prop on/in it, 5955s everywhere but throttle which has a 5985 ( won one at the Sherman, TX IMAC contest last fall that Hitec had donate prizes for). Using trottle management I can get it to fly the same speed upline and downline - it seems like I have to add power to get it to come down!!
The CG is at 3 3/4" and is just perfect. The recommended low rates on everything are probably okay if using a 28 x 10 Mejzlik but with the 3-blade Biela they are just a little slow so I used mid rates (which is 1/2 way between recommended high rate and low rate) on all three control surfaces
the electonics are: SmartFly power expander/super regulator, SmartFly pin switches (all with heavy duty wre and Deans connectors), Fromeco 4800 Peerless Li-ions on the flight pack and a 2400 on ignition with a Fromeco regulator and Electro Dynamics optical ignition cutoff switch. The RX is a JR synthesized receiver with the sysnthesized module plugged on a JR 10X.
All in all, Aeroworks has done another fine job. I told Rocco that if he built a plane with "bolt in canisters" that I would buy it - it did and the best part is that, hard to believe, flys better than the Extra 260!!
Thanks Rocco, Mark and the rest of the Aeroworks gang.
Bobby
(in reply to Mark Dennis)
       Post #: 2
RE: 100cc Yak Review - 3/25/2007 9:23:30 PM
Mark Dennis
Status: offline
Bobby,
Glad to hear you like it! Ive been flying mine for about 3 weeks now and absolutly love it! Have fun with yours and let us know what you think when you get more time on it. My guess is you'll like it more than you do now!
Team Aeroworks
(in reply to Bobby Folsom)
       Post #: 3
RE: 100cc Yak Review - 3/26/2007 4:23:16 AM
Bobby Folsom
Status: offline
Here are several pictures of my Yak and equipment setup. The field is located in Mt. Pleasant, TX and is a great place to fly a first flight!! BTW, I went ahead and installed four 3/32" baffles behind the cut out wedge-shaped slots just in case. I added a 3/4 oz and epoxy finishing resin to them so that the oil/gas won't soften the wood. Didn't have a heating problem a tall.
Enjoy.
Bobby
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 4
RE: 100cc Yak Review - 4/5/2007 2:51:14 AM
Tired Old Man
Status: offline
Bobby,
I really like the way you did your baffles. They should work out very well. Thanks for the idea. I'm going to borrow it and use in on another project.
If you can''''t fix it with a hammer, you have an electrical problem.
       Post #: 5
RE: 100cc Yak Review - 4/5/2007 3:07:26 AM
Bobby Folsom
Status: offline
You're very welcome Silver. I'm glad to help out. This project is my first with canisters - I love the way they sound. BTW, Tom posted some pictures on canister installation the other day and I realized that I had installed the silicon tubes incorrectly. I was lucky that they hadn't fallen out!!
Bobby
(in reply to Tired Old Man)
       Post #: 6
RE: 100cc Yak Review - 4/6/2007 4:12:37 PM
larshkj
Status: offline
We are 3 guys here in the Oslo area (Norway) who has this plane. We have only gotten a few flights on them, but so far it really looks promising.
Lars
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 7
RE: 100cc Yak Review - 4/7/2007 5:02:53 AM
Lormuhl
Status: offline
I also have the 100cc Yak, DA100 with stock mufflers, carbon gear, tail and tubes, Li-ons, Hitecs and Spektrum. Came in at 27lbs 1 oz. I noticed the three blade props. Im using a Mezlik 27-10 now. How much difference does the three bladers work and which size are you using? I am not a IMAC guy, just a fun flyer that does sport and 3D.
(in reply to larshkj)
       Post #: 8
RE: 100cc Yak Review - 4/7/2007 10:53:15 AM
bodywerks
Status: offline
stick with the 2 blade for most types of flying. The 3 blades are nice for keeping the noise down, they accelerate smoother, and can sometimes help a bit with downline breaking. And, of course, they give you more ground clearance. Typically, though, 100cc planes used for freestyle/3D flying have a 2 blade. two blades accelerate the plane faster and typically have a little more grunt to the way they pull.
STRAIGHTEN UP AND FLY LIGHT!!!
(in reply to Lormuhl)
       Post #: 9
RE: 100cc Yak Review - 4/9/2007 3:42:50 AM
Lormuhl
Status: offline
Thanks for the info Bodyworks. Im happy with the plane the way it flys now, but always looking for improvements. I ll stay with the carbon 27-10 Mez.
(in reply to bodywerks)
       Post #: 10
RE: 100cc Yak Review - 4/9/2007 9:56:57 PM
airega1
Status: offline
Is it necessary to use the clear iron-on mat'l on the leading edge of the main wing panels? as per plans
Learn and Earn
So you can Turn and Burn
       Post #: 11
RE: 100cc Yak Review - 4/10/2007 9:25:32 AM
larshkj
Status: offline
Who knows if it is necessary... ?
But I wouldn't be the one finding out it actually is! So my advise is to apply it. It's not a time-consuming process, and the clear strips of covering are supplied in the box.
Lars
(in reply to airega1)
       Post #: 12
RE: 100cc Yak Review - 4/10/2007 1:53:45 PM
reyn3545
Status: offline
Where do your graphics generally start to peel.... along the leading edge. That's what the clear is there to protect. Sure, the plane will fly without it, but next year, it will look better with it.
       Post #: 13
RE: 100cc Yak Review - 6/5/2007 8:20:12 PM
Robby368
Status: offline
Where do you find all these pretty ladies?
Takeoff is optional, landing is MANDATORY!
       Post #: 14
RE: 100cc Yak Review - 7/1/2007 2:55:06 PM
airega1
Status: offline
Hey Bobby, I'm in the process of putting together a 100cc QB yak. In the instructions in says to set up the ball links in different holes on the aileron control horns on the same wing panel, did you do this? just wondering about the ratio difference.
Frank
Learn and Earn
       Post #: 15
