RE: Peakmodel Extra 260 25%
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Peakmodel Extra 260 25% Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Peakmodel Extra 260 25% - 8/2/2007 2:39 PM
fredstyle
Score: 100
Last Login: 7/7/2009
Status: offline
roysterDW-- the stock tank is fine but the dubro has a flat bottom so it's just a little easier to mount, also the dubro is on
ounce lighter. So far that's the only thing in the kit that I haven't used. The stock hardware is pretty good IMO.
Hide Signatures
(in reply to RoysterDW)
       Post #: 76
RE: Peakmodel Extra 260 25% - 8/2/2007 9:46 PM
RoysterDW
Score: 100
Last Login: 3/22/2010
Status: offline
quote:
ORIGINAL: fredstyle
Thanks Fredstyle!
I'm going with similar servos but Futaba only cause I have discount vouchers from Tower
What size Du-Bro tank did you buy and is it plumbed as a 3 line or 2 line system?
I'll try and post some pics of mine as well.
Hide Signatures
(in reply to fredstyle)
       Post #: 77
RE: Peakmodel Extra 260 25% - 8/3/2007 12:37 AM
fredstyle
Score: 100
Status: offline
quote:
ORIGINAL: RoysterDW
quote:
ORIGINAL: fredstyle
Thanks Fredstyle!
No prob-- I'm thinking 3 line with the 12 oz tank, and the hangar 9 fuel dot... I'm in uncharted territory- my only building is with
electric arf's, no fuel lines to worry about!!!! Got the cowling cut out now just have to deal with the fuel sys plumbing...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 78
RE: Peakmodel Extra 260 25% - 8/3/2007 4:18 AM
cmircman
Score: 100
Last Login: 3/14/2010
Status: offline
I just wanted to give you guys a heads up on your build. Before you go much further you might want start really thinking about how you are going to get this plane to balance out. I put a saito 150 i mine and i am nose heavy with a 35 oz engine. Your engine acording to peak models is 50.71oz. Have you guys thought of how this plane is going to balence? When you do get your cg issue sorted out i will tell you that this is one of the best flying planes i have ever flown. You will definetly love it! I wish you the best of luck with your build.
Rich
< Message edited by cmircman -- 8/3/2007 4:21 AM >
_____________________________
Never take life to serriously. You will never get out alive!
Rever Bro #195
Hide Signatures
       Post #: 79
RE: Peakmodel Extra 260 25% - 8/3/2007 5:27 AM
RoysterDW
Score: 100
Status: offline
fredstyle - Thanks for the pics! Keep em comin!
I'll post some up as soon as I get my digi cam back off my wife
Nice job on the cut out of the cowl. Not sure if a rear dump would have made any difference but the side dump most certainly is going to allow more air to flow over the engine.
Did you have any probs mount the engine with the supplied mounts. Heard from one guy saying they were tooo short and he had to cut some of the box away. I rather not do that and weaken the plane.
Hide Signatures
       Post #: 80
RE: Peakmodel Extra 260 25% - 8/3/2007 6:36 AM
fredstyle
Score: 100
Status: offline
quote:
ORIGINAL: cmircman
Rich
Thanks for the heads up!!! I was thinking all the batteries as far aft as possible, maybe make a tray if need be... behind the rudder servo.
Royster-- No problem at all with the stock stand offs, they sent me nice template that was a piece of cake to mount. I reinforced the
firewall with 1/8" dowel on the sides as well as adding triangle stock to the front, then just went ahead and hit all the joints with 30
min epoxy just to be safe. As circman pointed out the 40cc is a bit heavier than the 26cc but only a few ounces more than the evo 26
I've got on a 50" ultimate.
Hide Signatures
(in reply to cmircman)
       Post #: 81
RE: Peakmodel Extra 260 25% - 8/3/2007 7:26 AM
RoysterDW
Score: 100
Status: offline
quote:
ORIGINAL: cmircman
Rich
Hey Rich
CG is always on my mind when I build. According the latest Airplanes News 70% of maidens end up in crashes due to poor CG.
Bare in mind the G26 is a heavier motor than our SPE40, but I'll be keeping an eye on nose weight.
I guess we'll cross that bridge when we come to it. Also this is not the first time a SPE40 has been put into a Peakmodel Extra. Its been done by even the deisgner Paul Xu.
Cheers
Hide Signatures
       Post #: 82
RE: Peakmodel Extra 260 25% - 8/3/2007 7:58 AM
nowinkk
Score: 100
Last Login: 3/10/2010
Status: offline
Slightly nose heavy is preferable than otherwise as far as CG is concerned in my experience.
Life ends when u stop dreaming; Hope lost when u stop believing n Love fails when u stop caring. So dream, believe n care..
Hide Signatures
       Post #: 83
RE: Peakmodel Extra 260 25% - 8/3/2007 8:17 AM
RoysterDW
Score: 100
Status: offline
quote:
ORIGINAL: nowinkk
Yep, I agree. I had a Sukhoi SU-31 and was meant for a .46 but I installed a 55AX and it was a tad nose heavy but she flew well once it was balanced.
Gimme nose heavy over tail heavy any day of the week
Hide Signatures
(in reply to nowinkk)
       Post #: 84
RE: Peakmodel Extra 260 25% - 8/3/2007 8:53 AM
stew007
Score: 100
Last Login: 12/19/2009
Status: offline
One thing you could do if your having balancing problems, is cut the stand-offs down a bit to move the engine further backwards, even trim the cowl so it is a bit shorter if need be, bore a hole right through them and use a longer m4 bolt, thats what i've done with the Peak 26cc. But I would finish the install first and see how nose heavy first, then experiment with the mount. I think the CG should be 133mm back from the leading edge of the wing at the fuse for the plane to fly at it's best.
Hide Signatures
       Post #: 85
RE: Peakmodel Extra 260 25% - 8/3/2007 9:26 AM
RoysterDW
Score: 100
Status: offline
Thanks Stew
I just tried the alloy stands offs and they are short!! The muffler hits the firwall.
I guess I may have to go with a rear dump muffler cause no way am I butchering up the airframe.
Interesting some guys have had no problems. Mmmmm a small email to Peak Model I thinks
Hide Signatures
(in reply to stew007)
       Post #: 86
RE: Peakmodel Extra 260 25% - 8/3/2007 1:16 PM
RoysterDW
Score: 100
Status: offline
quote:
ORIGINAL: fredstyle
The reason I went with dual elevators is for balance, bigger motor so a little more tail weight. here's the progress so far:
Did those stand offs come with the kit?
They look longer than mine as mine hits the firewall, long by about 8mm.
Hide Signatures
       Post #: 87
RE: Peakmodel Extra 260 25% - 8/3/2007 4:34 PM
theo63
Score: 100
Status: offline
well i am about to start on mine as well this weekend,i want to get a pitss muffler for mine so i dont have to cut the box,i seen the muffler for the spe 40 but now i cant find it,does anybody know where to get one
steve
Hide Signatures
       Post #: 88
RE: Peakmodel Extra 260 25% - 8/4/2007 12:13 AM
fredstyle
Score: 100
Status: offline
quote:
ORIGINAL: RoysterDW
quote:
ORIGINAL: fredstyle
The standoffs came with the kit, as well as the "newer" ignition that reads 4.8-18v. Honestly my main concern is the motor itself... all's i've read is that these are hit or miss. It fired and ran on the test bench but i'm not big on running it for long without cooling air over the motor. I know this opens a whole new can of worms but does anyone have time with this motor???
Hide Signatures
       Post #: 89
RE: Peakmodel Extra 260 25% - 8/4/2007 1:33 AM
RoysterDW
Score: 100
Status: offline
quote:
ORIGINAL: theo63
Yep Cermark who are also speengine.com and also BCMAengines.com but they may not sell you one unless you bought the engine from them.
I have emailed Cermark to see if they can supply. Keep ya posted
Hide Signatures
(in reply to theo63)
       Post #: 90
RE: Peakmodel Extra 260 25% - 8/4/2007 1:38 AM
RoysterDW
Score: 100
Status: offline
So fredstyle you got the longer stand off with your Extra260 25% with a SPE40, correct?
I spoke with Way from Peak (via Messenger) and he told me they are short because the plane is supposed to have a 26cc. I said it would have been nice to tell customers that it aint gonna fit when they order a 40cc!! Derrr.
Hide Signatures
       Post #: 91
RE: Peakmodel Extra 260 25% - 8/4/2007 1:42 AM
RoysterDW
Score: 100
Status: offline
Yeah so now I have to have a look at options on mounting the engine.
Not sure if the rear dump muffler work until I get one and try and fit it, UNLESS there is someone on this forum that can tell us all that it will fit without hacking into the airframe.
Cutting that corner off just doesn't cut it for me Na seriously it will weaken the plane and that motor needs all the support it can get. IMO
Hide Signatures
       Post #: 92
RE: Peakmodel Extra 260 25% - 8/4/2007 7:07 AM
fredstyle
Score: 100
Status: offline
quote:
ORIGINAL: RoysterDW
Yes that is correct the stand-offs came with the combo, ordered it off the peak website as the 40cc combo... maybe it was one of those hit or miss items i mentioned earlier. The only thing i've decided to change has been the fuel tank, and that was just by a buddy who recomended it. the motor even came with a 40cc template!!! How long ago did u order your kit??? Mine was shipped direct from China in one box.
Hide Signatures
       Post #: 93
RE: Peakmodel Extra 260 25% - 8/4/2007 8:44 AM
gorcsew
Score: 100
Last Login: 3/16/2010
Status: offline
Hello Everyone!
I wold like to buy this Extra 260 with the 40 cc engine. Unfortunately to my country the shipping is not free.
I wold ask, how long took the shipemt in your case?
Arrived the package and the plane without any damage?
Thanks for the answers, best regards
GorCseW
Hide Signatures
       Post #: 94
RE: Peakmodel Extra 260 25% - 8/4/2007 1:57 PM
theo63
Score: 100
Status: offline
gorcsew,mine took just about a week,and no damage to report,boxed very well
steve
Hide Signatures
(in reply to gorcsew)
       Post #: 95
RE: Peakmodel Extra 260 25% - 8/5/2007 9:29 AM
RoysterDW
Score: 100
Status: offline
Mine arrived as quoted 5 days!! Good packing with no damage to any parts. ALthough I have and engine that wont mount to my firewall due to wrongly supplied mounts. Hopefully getting sorted out soon.
Covering was perfect not like my new E-Flite Mini Funtana X with wrinkles everywhere.
Hide Signatures
       Post #: 96
RE: Peakmodel Extra 260 25% - 8/6/2007 3:16 AM
RoysterDW
Score: 100
Status: offline
Heres the prob I have with the muffler.
Have contacted Peak and am waiting on a reply.
Click for fullsize
Hide Signatures
       Post #: 97
RE: Peakmodel Extra 260 25% - 8/6/2007 3:25 AM
RoysterDW
Score: 100
Status: offline
More pics:
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 98
RE: Peakmodel Extra 260 25% - 8/6/2007 6:15 AM
gorcsew
Score: 100
Status: offline
Hello RoysterDW!
Why don't use rubber spacers / spring like this. [picture below] A bit more weight to the front, but less vibration to the aircraft.
Steve, RoysterDW thanks for the answers.
GorCseW
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 99
RE: Peakmodel Extra 260 25% - 8/6/2007 7:10 AM
RoysterDW
Score: 100
Status: offline
quote:
ORIGINAL: gorcsew
Hello RoysterDW!
GorCseW
Nope no good. For one anything with a spring it will change the vector as I was told by large scale pilots and yes the CG will be even harder to attain.
I will try and buy a rear dump muffler and see if that works out.
I would rather mod the muffler than the airframe.
Worst case I have another set of stands offs custom made for me.
Thanks for the idea.
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.500RCU1
