dalolyn
Joined: 6/16/2002 From: wilber, NE, USA Status: offline
I built a Sr. falcon twin from plans. There is no concern about the engines running at the same rpm. as a matter of fact what sounds like a lot of offset in rpm by sound is no less then a thousand. I do not spend much time making sure the engines are in sync. I tune each individually, then start both and fly. I notice some trim concerns with an engine out but the main thing is do not hammer the throttle with one engine still running. While flying at cruising speed. I notice only a little deference. the biggest battle with an engine out is if you miss the runway and have to abort and fly around again. accelerating, climbing and turning all at the same time with an engine out is a task. I will slowly apply throttle, climb,level out, then begin to turn for another approach.
