JimTrainor
Joined: 10/25/2002 From: Ontario, ON, CANADA Status: offline
I flew in -10 degree C weather today. The first start was easy, but the engine refused to start after the first flight. Couldn't figure out why, so I gave up. While packing up I noticed that the fuel jug had what appeared to be condensed water droplets all over the inside of the fuel jug above the level of the fuel. It was not subtle, it was very very clear. Many large and small well formed drops. I am assuming this was water, and I am assuming that this indicates a high moisture level in the air sealed in the fuel jug, and that it may indicate spoiled fuel... which might explain my starting troubles. But, and I am uncertain if this even possible, it might also simply have been alcohol vapor condensing on the inside of the container. I tried to wipe a bit off the inside of the container to see if I could tell, but it is hard to tell the difference with only a small amount. Methanol does not have a particularly strong characteristic odor. Has anyone else see this when flying in cold temperatures?
