Wounded Ultra Sport first flight
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Sport Flying >> Wounded Ultra Sport first flight
Page: [1]
Login
Wounded Ultra Sport first flight - 3/25/2007 9:46:54 PM
pumbadog
Status: offline
Well I took the Ultra Sport up for the first time after a 15 year break. I've been flying an Ultra Stick but it was too windy today for that kite. Now the Ultra Sport is wounded. I had a gust of wind catch it about 3 feet off the ground on final and it did a cart wheel that took the wing off. Good thing the aft mounting braket for the wing screws broke off and saved my nylon break away screws. Not too bad of a wreck. Beef up the forward bulkhead were the dowls riped out and re install the aft wing mounting bracket and it'll fly again. It was good while it lasted. I probably shouldn't have done the maiden flight on a windy day, but this is Kansas. If I don't fly on the windy days, I'd never get to fly.
       Post #: 1
RE: Wounded Ultra Sport first flight - 3/26/2007 3:06:11 PM
MinnFlyer
Status: offline
I get a kick out of people who think that Nylon bolts are designed to break before the wood does - It just aint gonna happen. maybe on a landing gear, but not on a wing (Or at least very rarely)
Well, at least your damage doesn't sound too bad.
_____________________________
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
(in reply to pumbadog)
       Post #: 2
RE: Wounded Ultra Sport first flight - 3/27/2007 8:38:11 PM
scottrc
Status: offline
The Ultra Sport is a very tough plane. I have torn my wing mount out a few times becasue of high speed low level passes and forgetting the big weeds at the end of the runway.
The difference between nylon and metal bolts is that the nylon will shear from a hard impact resulting in less damage and savin the wing and the mount. However, the mount usually gives way at about the same time. With metal, the will either get ripped through the wing of through the fuse mount renduring the mountings useless.
Scott
If you love that plane, set it free, if it doesn't return, you should've checked your battery.
(in reply to MinnFlyer)
       Post #: 3
RE: Wounded Ultra Sport first flight - 3/27/2007 9:26:01 PM
Sherpa FE
Status: offline
I have heard that some people cut thier nylon bolts maybe 1/3 of the way through to make sure that they break and not the rest of the plane. I personally have done this myself, as I would problably cut too much and lose the wing straight and level flight.
I even heard that method for the landing gear, what about you guys, what do you think about cutting them?
(in reply to scottrc)
       Post #: 4
RE: Wounded Ultra Sport first flight - 3/27/2007 10:00:57 PM
scottrc
Status: offline
quote:
ORIGINAL: Sherpa FE
Not me, the last thing I want is to be doing a set of rolls or a loop and have the bolt heads shear off. Even on the landing gear, its much easier to replace the landing gear block because the bolts didn't shear then replacing a whole plane because they sheared in flight.
(in reply to Sherpa FE)
       Post #: 5
RE: Wounded Ultra Sport first flight - 3/27/2007 10:06:08 PM
MinnFlyer
Status: offline
A great big DITTO to that!
Mike B.
       Post #: 6
RE: Wounded Ultra Sport first flight - 4/1/2007 7:33:32 PM
crawler tech
Status: offline
Is there some reason you wouldn't use a smaller diameter nylon bolt?
10-24 perhaps.
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.518RCU1
