3.3 shafts    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Slash 4x4 roller with TQ 2.4GHz Traxxas Link - Kit
Seller:  Callifas38
Details:   $150.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> 3.3 shafts
Page: [1]
Login
3.3 shafts - 3/27/2007 12:10 AM
maxmania214
Score: 100
Last Login: 5/16/2007
Status: offline
hi guys
just a quick question i just ordered some 3.3 half shafts for my max but didnt think that i have 1.5 a arms will thay fit
please say thay will ?
what do i do if they dont?
cheers liam
_____________________________
WOW now i did say not to stand there !!!
Hide Signatures
       Post #: 1
RE: 3.3 shafts - 3/27/2007 1:20 AM
maxmania214
Score: 100
Status: offline
c-mon guys i know it in there some were!!
Hide Signatures
(in reply to maxmania214)
       Post #: 2
RE: 3.3 shafts - 3/27/2007 2:02 AM
MaxxRT
Score: 100
Last Login: 6/18/2008
Status: offline
Are you talking about the shafts that connect to the trans or the diffs? Neither will fit without some modifications. The driveshafts definately wont fit and you will need the 3.3 suspension to make them work. The half-shafts (that connect to the trans), the rear will work with a little bit of trimming but the front, asuming you have a .15 maxx, i believe you will have to upgrade to the larger disc brake hub/hex.
Hide Signatures
       Post #: 3
RE: 3.3 shafts - 3/27/2007 2:23 AM
carl250r
Score: 100
Last Login: 12/5/2010
Status: offline
i have been through all sorts of drive line dealings with. i could help you.
but you need to ask this question again in a way that makes sence. and this thing here that you said "but didnt think that i have 1.5 a arms will thay fit" i have no idea what this means.
what model truck do you have? and what are you trying to do to it?
Tmaxx 3.3 ,fantom pipe, FOC, hump pack, aluminum chassis braces,skid plates, bumpers, bulkheads ,rear diff , and RPM A arms
Hide Signatures
(in reply to MaxxRT)
       Post #: 4
RE: 3.3 shafts - 3/27/2007 3:25 AM
maxmania214
Score: 100
Status: offline
my car is an early 1.5 t maxx
and we call the drive shaft connecting the diff, to the wheels, half shafts over here!
i was known to believe that the aerly t maxx were not as wide, so thats why i asked if the later 3.3 shafts would fit as I thought these were longer? i wasent sure if i was going to have to get some new suspention arms ( i dont realy want to have to ) lol
thanks
liam
Hide Signatures
(in reply to carl250r)
       Post #: 5
RE: 3.3 shafts - 3/27/2007 3:43 AM
tommythecat
Score: 100
Last Login: 2/27/2013
Status: offline
I think all you need are:
The extended A-arms from the trx 2.5 t-maxx or newer ( I think that you may also need new turnbuckles when you switch the arms, but I'm not sure
New 3.3 axle carriers
and the shafts of course.
I think that is all you should need for the 4 corner shafts, but I'm sure someone whose done it will jump in and clarify...I hope
Hide Signatures
       Post #: 6
RE: 3.3 shafts - 3/27/2007 3:54 AM
carl250r
Score: 100
Status: offline
yeh you will need all of that stuff and 3.3 tie rods to fit the axle cariers.
Hide Signatures
(in reply to tommythecat)
       Post #: 7
RE: 3.3 shafts - 3/27/2007 8:50 AM
MaxxRT
Score: 100
Status: offline
quote:
ORIGINAL: maxmania214
thanks
liam
I did this same conversion and you'll need the 3.3 a-arms along with the other things. 2.5 arms will not work because they dont have enough clearance for the pins on the driveshaft. The 3.3 arms have a notch in the arms to allow for the shafts to rotate freely and not bind. You can find everything you need on ebay fairly cheap.
Hide Signatures
       Post #: 8
RE: 3.3 shafts - 3/27/2007 9:22 PM
maxmania214
Score: 100
Status: offline
thanks guys
i appriciate it
Hide Signatures
       Post #: 9
RE: 3.3 shafts - 3/28/2007 12:14 AM
rawiswar
Score: 100
Last Login: 4/21/2009
Status: offline
just sell your max on ebay and by a brand new 3.3 t maxx lol
thats what im going to do in a few months
T maxx keep breaking when gentle bashing?
(DRIVE IT LIKE YOU STOLE IT)
Hide Signatures
       Post #: 10
RE: 3.3 shafts - 3/28/2007 1:51 AM
carl250r
Score: 100
Status: offline
the 3.3 is one bad hombre.
Hide Signatures
(in reply to rawiswar)
       Post #: 11
RE: 3.3 shafts - 4/2/2007 2:52 AM
jonnzzo
Score: 100
Last Login: 9/15/2007
Status: offline
my t-maxx 3.3 has destroyed a rear drive shaft. havent even used it all that much, maybe 4-5 tanks. the ujoint have oblonged the holes in the shaft and the cup. popped the u-joint right out. has anyone seen a stronger shaft avalible?, maybe aluminum or something?.
Hide Signatures
       Post #: 12
RE: 3.3 shafts - 4/2/2007 3:23 AM
carl250r
Score: 100
Status: offline
the same thing happended over and over with mine. 3.3 tmaxx
what they have to fix it is what they call "CVD's" CVD shafts..
take a look at ebay item# 260102567813
there are many different brands out there. this is just a example of one.
Hide Signatures
(in reply to jonnzzo)
       Post #: 13
RE: 3.3 shafts - 4/2/2007 3:34 AM
jonnzzo
Score: 100
Status: offline
wow those are spendy. so I will most likely have a problem with the front shaft and the axle shafts too?.
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
