Going For Worlds Fastest Truggy!!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> Going For Worlds Fastest Truggy!!!! Page: [1] 2 3 4 5   next >   >>
Login
Going For Worlds Fastest Truggy!!!! - 3/27/2007 12:54 AM
MiamizFinest
Score: 140
Last Login: 6/18/2013
Status: offline
OK guys im goin to try to set this up for the worlds fast truggy compation.............this is a kyosho inferno st us that ive set up for the street as u can see everything on the car is brand new (exept the motor it has less than a gallon from when i had it in my muggy) i wanna make this thing go as fast as possible.......so i want everyone to help out at the moment ill keep this axial 28 in it but in the near future i will buy another novarossi 528 motor and run that in this truck to get the highest end speed i can get!!! i got this car as a brand new roller for 175 bucks........and ive put in JR 590 servos a JP-3 ,axial 28 and ofcourse those beautful HARD TO FIND foam tires!!!!! any idea's on geting the most top speed possibable would be apractated!!!! here is some pics ill psot videos some time next week!!!!!!!
PS if you do not like my idea of what im trying to do PLEASE do not start bad mouthing and start a flame war..........if you dont like it please do not start anything
_____________________________
-= 100 Is Only The Beginning =-
-= Made In Dade =-
Hide Signatures
       Post #: 1
RE: Going For Worlds Fastest Truggy!!!! - 3/27/2007 1:19 AM
Sprocket87
Score: 100
Last Login: 12/20/2007
Status: offline
Well first off look at getting some sort of brushless electric motor/lipo system. Then figure a way to utilize a 3speed transmission and that will be a good start.
Hide Signatures
(in reply to MiamizFinest)
       Post #: 2
RE: Going For Worlds Fastest Truggy!!!! - 3/27/2007 1:45 AM
nbk
Score: 100
Last Login: 7/23/2008
Status: offline
I guess you can put the biggest clutchbell you can find on it,
put a faster motor.
Im sorry but your not going to get anywhere near the worlds fastest anything with nitro now-days.
Hyper 8.5 l Recoil l
Hide Signatures
(in reply to Sprocket87)
       Post #: 3
RE: Going For Worlds Fastest Truggy!!!! - 3/27/2007 1:52 AM
MBX5T Maniac
Score: 100
Last Login: 11/13/2009
Status: offline
Cut those tires smaller like I said, use a Novarossi engine in it, and put a huge clutch bell on it. Also, try to fit an Ofna 2-speed clutch in it
My toys: LST, Mini Inferno, XX-CR, GrassHopper, RC10, Rustler, MBX5T Prospec, Mugen MST-1
Hide Signatures
(in reply to nbk)
       Post #: 4
RE: Going For Worlds Fastest Truggy!!!! - 3/27/2007 2:04 AM
kidd
Score: 100
Last Login: 4/9/2011
Status: offline
the hyper 7 2 speed might fit.
Hide Signatures
(in reply to MBX5T Maniac)
       Post #: 5
RE: Going For Worlds Fastest Truggy!!!! - 3/27/2007 3:09 AM
MiamizFinest
Score: 140
Status: offline
Oh my bad i ment WORLDS FASTEST NITRO TRUGGY!!!!!!! LOL either way yes im goin to cut the wheels in half.......and i will fit a 2speed in it the 2speed from the inferno gt drops dirrectly in (i already tryed it since i own one) either way any other idea's i havent thought about?????//
-= Made In Dade =-
Hide Signatures
(in reply to kidd)
       Post #: 6
RE: Going For Worlds Fastest Truggy!!!! - 3/27/2007 8:05 AM
supertib
Score: 302
Last Login: 6/19/2013
Status: offline
for fastest Truggy i think you need to be running a center diff. 2 Nova 28's woul;d give you the most speed...likely in the 85 MPH range.
Neal Smith..owner Clockwork Racing Engines
Hide Signatures
       Post #: 7
RE: Going For Worlds Fastest Truggy!!!! - 3/27/2007 2:31 PM
nitro _ burner
Score: 100
Last Login: 9/10/2010
Status: offline
some thoughts, set the camber so the tires are perfectly flat on the road. keep the larger tires they will give slower acceleration but a higher top speed, and of course find the highest gear ratio possible, even if it gives you a slower acceleration. ohh and at a speed that your looking at and tires like those set the suspension to the lowest setting. you will want a realy low centere of gravity for speed, controll, and to reduce the chances of grip roll.
good luck.
RC''s: BL Mini B, Micro B, BL RC18T, CEN ME16MT and an LST2!!!
Hide Signatures
(in reply to supertib)
       Post #: 8
RE: Going For Worlds Fastest Truggy!!!! - 3/27/2007 9:51 PM
stspower91
Score: 100
Last Login: 6/16/2007
Status: offline
make some custom carbon fiber parts lighten the thing up a little anything you can do to take weight off wil really help
Hide Signatures
(in reply to nitro _ burner)
       Post #: 9
RE: Going For Worlds Fastest Truggy!!!! - 3/27/2007 10:16 PM
-EXTRA-
Score: 100
Last Login: 12/3/2009
Status: offline
Get some really really good bearing's for everything.
Hide Signatures
(in reply to stspower91)
       Post #: 10
RE: Going For Worlds Fastest Truggy!!!! - 3/27/2007 11:06 PM
dmr bikes 4 eva
Score: 100
Last Login: 5/13/2008
Status: offline
good bearings gear it real real high you may have to cut your own gears lock all the diffs just to get the power down to the floor o and that hole in the body wont help past 50mph
you miami guys seem to be the oneswith the fastest cars so why not ask some of the guys you run with
i know you are considerg a novarossi but you really should consider brushless it will give you the rpms you really want but then again im no expert but yeah nice truck
Hide Signatures
(in reply to -EXTRA-)
       Post #: 11
RE: Going For Worlds Fastest Truggy!!!! - 3/27/2007 11:42 PM
1/8racer
Score: 100
Last Login: 12/23/2009
Status: offline
get ready for chassis warping.....its like 2mm thick
Hide Signatures
(in reply to dmr bikes 4 eva)
       Post #: 12
RE: Going For Worlds Fastest Truggy!!!! - 3/28/2007 12:48 AM
MiamizFinest
Score: 140
Status: offline
quote:
ORIGINAL: 1/8racer
I THOUGHT THE SAME THING!!!!!!!!!!! im geting to buy a kyosho ST-R chassis!!!
also i cant ask any of the guy from around here becuase i em the first to set up a truggy!!! and also i wanna stick with nitro!!!! im clueless when it comes to brushless and lipos!!!!
-= Made In Dade =-
Hide Signatures
(in reply to 1/8racer)
       Post #: 13
RE: Going For Worlds Fastest Truggy!!!! - 3/28/2007 2:27 AM
what_stanger
Score: 100
Last Login: 10/16/2009
Status: offline
if you can get away with it, skinnier tires in front for less rotational mass. After the above things, save weight! You know my take on this stuff..
for starters that jammin' pipe is on the heavier side. Why not get a total high end pipe? Get the most rpm as possible. Start grinding away at useless material (everywhere!) Just don't wreck it, it won't matter how weak it is, as long as you don't curb the damn thing!
although curbing an rc at 50-80mph would be cool.
Mugen MBX6 - Novarossi Plus .21-4
Hide Signatures
       Post #: 14
RE: Going For Worlds Fastest Truggy!!!! - 3/28/2007 3:49 AM
robertcrav
Score: 100
Last Login: 3/5/2009
Status: offline
Might want to check out the ... February and March Xtreme RC Car Magazines, they put two Axials (I think) in an STR, and hit a two way average over 70mph.... They used Pro Line BowTies and used the mechanical advantage of the tires ballooning to lower the overal drive ratio for a higher top speed...they seemed to have issues with blow overs and the front getting extremely light, so I would think you'd want the rear pretty stiff, and the front raked down as much as you could...
Hide Signatures
(in reply to what_stanger)
       Post #: 15
RE: Going For Worlds Fastest Truggy!!!! - 3/28/2007 5:41 AM
dirthead
Score: 100
Last Login: 8/13/2012
Status: offline
You might want to take the rear wing off to reduce drag , at those speeds, it'll definitely slow you down. also I don't know if a 3 speed setup would work or not, just a suggestion.
I thought I saw everything till someone proved me wrong ...again !! TTR RULES!!
Hide Signatures
(in reply to robertcrav)
       Post #: 16
RE: Going For Worlds Fastest Truggy!!!! - 3/28/2007 7:38 AM
mOnO n.s.G^
Score: 100
Last Login: 10/25/2009
Status: offline
once done get some vids ma du
< Message edited by mOnO n.s.G^ -- 3/28/2007 8:05 AM >
Hide Signatures
       Post #: 17
RE: Going For Worlds Fastest Truggy!!!! - 3/28/2007 8:37 AM
MiamizFinest
Score: 140
Status: offline
quote:
ORIGINAL: robertcrav
I SAW THAT IT WAS CRAZY!!!!!!!!!! they would have pulled out more speed if they locked the center diff but they didnt wanna do it.....................I DID THO WITH RED PLAY-DOH!!!........also i order a ofna 086 top end pipe i should have it by friday
ok here is a little update............yestuday i couldnt take it and whent out and ran the IFNERNO ST at about 11 PM at a cosco parking lot ................and THAT THING WAS HALING ASS!!!!!!! i dropped a 19 tooth clutch (biggest i had in hand) and that thing was SEROUSE!!!!!!!!!! i know i was doin just over 50 MPH(from looks but i didnt radar it)........and i was very happy i also took the wing off to see how it would perform and it ran perfect in a str8 line so i dont need a wing .........the only thing holding me back was my stupid axial 28 the carb was messed up it was leaking fuel out of the HSN and the midrange needle litterally fell out of the engine..............i got furstrated and deside to sell it..........im selling it to a buddy of mine that has a spare novarrossi carb laying around and since the engine is fine and the carb is the only think messed up its a great deal for him!!!
also im not goin to put it off............ im buying a novarrossi 528 for my inferno st tomorrow or thursday.......then well see whats up!!! im also torn between a novarossi 528 or a REX ROSSI 528 (the blue head one) i know they are the same engine but SUPPOSTLY from what i heard it turns 2,000 RPM more...........does anyone know if thats tru??? where can i specs on this engine??? since the novarossi site is under constution and the specs section doesnt really work.........
-= Made In Dade =-
Hide Signatures
       Post #: 18
RE: Going For Worlds Fastest Truggy!!!! - 3/28/2007 6:49 PM
dmr bikes 4 eva
Score: 100
Status: offline
if its in your budjet you should get the new engine modded by rick brake for top end then it would really haul i mean really
Hide Signatures
       Post #: 19
RE: Going For Worlds Fastest Truggy!!!! - 3/28/2007 10:53 PM
crazy for rc
Score: 100
Last Login: 3/20/2009
Status: offline
yeah dude that was cool it would have cool to seen a video of that you see how blooned the tires got that one way to brakedown foam and solfin the tires up at the some time
Hide Signatures
       Post #: 20
RE: Going For Worlds Fastest Truggy!!!! - 3/29/2007 5:24 AM
Nik.
Score: 106
Last Login: 7/27/2012
Status: offline
those foams look awesome!
Team Smiley
Just remember, if the world didn''''''''t suck, we''''''''d all fall off.
Hide Signatures
(in reply to crazy for rc)
       Post #: 21
RE: Going For Worlds Fastest Truggy!!!! - 3/29/2007 9:13 AM
MiamizFinest
Score: 140
Status: offline
quote:
ORIGINAL: dmr bikes 4 eva
OH HELL YEA BRO RB is the BEST MODS!!!!!!!! i have is picco 28 RB modded in my revo and that thing FLIES!!!!!!!!! i will send out my motor to get modded but i will send it with the pipe so both the pipe and motor and be touched by the hand of god!!!!!!!
-= Made In Dade =-
Hide Signatures
       Post #: 22
RE: Going For Worlds Fastest Truggy!!!! - 3/29/2007 5:19 PM
rc4x4nut
Score: 100
Last Login: 12/31/2007
Status: offline
First of all if you want total speed you dont want the .28 for torque you want a high end .21 like a modded v spec or c6bb. The gear ratio in the diffs could be higher. Best bet would be a CRT and find the smallest spur gear or use a 8 spider diff with a 43t and that 19t clutch bell. That would give you a gear ration of about 7.5. But in the end its going to cost quite a bit. RC Cars 100 mph rs4 cost about 4500 if I remember correctly.
Hide Signatures
       Post #: 23
RE: Going For Worlds Fastest Truggy!!!! - 3/29/2007 10:56 PM
MiamizFinest
Score: 140
Status: offline
quote:
ORIGINAL: rc4x4nut
this is completely not true...............i already tryed running a ninja 21 on my buggy and the 21 doesnt have the tourque to run such a high weight truggy at that speed it will never get its full RPM range.............for a truggy a 28 is the way to go ive already tested this
a 21 is perfect for rigdinng it into a jato,rc10gt,RS4 2, XXXN-T ext..........and try to go as fast as you can.............also if it cost 4500 bucks to get a RS4 to 100MPH that guy is a JOKE!!!!! my friends have already done it with less than 1,500 dollars AND i know first hand three people that have PAST 100MPH with a RS4 one of them is at 103MPH the other 106MPH and the fastest RS4 in miami is a 107MPH trust me you will see these cars at worlds fasters RC compation
its not all about HIGH GEAR RATIO AND GO!! u need to test if the engine if it can even push the gearing you wish............if you over gear it the engine NO MATTER WHAT YOU DO will never in its life open up all the way
-= Made In Dade =-
Hide Signatures
(in reply to rc4x4nut)
       Post #: 24
RE: Going For Worlds Fastest Truggy!!!! - 3/30/2007 4:30 AM
annie_himself
Score: 100
Last Login: 12/8/2011
Status: offline
I like the really think and strong chassis braces and steering link.
Saldly, 98% of teens have switched to rap music, if you're part of the other 2% that like real hip-hop put this in your sig.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.971RCU1
