bigtim
CA, USA Status: offline
thanks for the heads up on the washout JGrc. I did end up building a wing jig from the tips that I got here wheather or not I end up using it on this model I am not sure I made it for the Me109 I don't know. I am almost ready to start the build,I have a after market fiberglass cowl,and canopy I got off the eBay, I am planning on using the origonal kit components for templates and recut the kit with new wood,incorporating lightening holes in the wing ribs and fuse formers,as for the wood blocks theres alot of room for using built up structures rather than carving wood blocks that the Royal kits use,as well as sheeting rather than planking with the thicker wood recomended. I plan on using some of the tecniques that Top Flight uses since I have a D-9 kit to copy from,I also need to cast a gun hood cover out of fiberglass for my access hatch,for the fuel dot,on off switch,and retract filler. there is a couple of details that I need to work out to move forward I really want to focus on keeping this plane light and add some scaleness as well. I have a engine a OS91 surpass,the gear I want to use are really pricey so I am thinking I might go with the lighter robart spring down air up gear with wire struts to keep it light,there alot less expensive, its abit in advance so I will see when I get closer to needing them how much $$ I am willing to spend. once I get my canopy in the mail things should start rolling. I have been dragging my rear a bit but I really want to get going on this one soon, work and other distractions have gotten in the way, any others thinking about building this plane please post some more info or photos as soon as I start I will post progress shots.
