gene webber
CA, USA Status: offline
The only charger/balancer system that can do what you desire is the Hyperion eos1210i with 2=lba10 balancers linked together. One balancer becomes a slave to the other and together will balance your 12s pack, but you will have to put 2 balancer taps on your 12s pack as the lba10 only recognizes 6cells each, hence 2-lba10's. So in practice build your pack as a 12s pack, install 2 balance taps and you are good to go, the balancers think you have 2-6s packs hooked-up and balance them to each other. What's cool is Hyperion makes a balance tap for guys building their own A123 packs that plug directly into the lba10 balancer, you need 2 for a 12s pack. You don't necessesarily need the eos1210i charger for the balancer system to work, but it is a sweet and well thought out functional battery management system. Go to allerc.com Gene
