RE: X or XL?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> RE: X or XL?
Page: <<   < prev  1 2 3 4 [5]
Login
RE: X or XL? - 4/9/2007 4:31:39 PM
Raserx
Status: offline
Yup...and matches the negative on your charger...which is what I thnk you just said.
(in reply to zerofox)
       Post #: 101
RE: X or XL? - 4/9/2007 4:49:55 PM
Missileman
Status: offline
I am sorry but WRONG.
There is a negative ONLY and at the other end of the plug is a positive ONLY. all the wires in between are both positive AND negative.
ie... The wire next to the negative wire is positive for that 1st cell AND negative for the 2nd cell. The next wire is positive for the second cell AND negative for the third cell.
So it does matter what order the wires are located.
_____________________________
Comments by author are not to be confused with the truth, past or present.
(in reply to Raserx)
       Post #: 102
RE: X or XL? - 4/10/2007 12:39:47 AM
zerofox
Status: offline
indeed, further research tells me that i need to invert ALL 4 leads to make it not go nuclear... i basically have to pull the connecter and flip it over...
(in reply to Missileman)
       Post #: 103
RE: X or XL? - 4/10/2007 1:37:16 AM
Raserx
Status: offline
Thats odd. My batteries have four wires...one negative and three positive on the charging plug.
I guess I should have been more specific. I have the align charger. When I rebuilt my lipo battery I had three positive leads that I soldered to each individual cell. The cells attached to each other via the metal tabs built into each battery cell. A single negative wire is connected to the final cell.
So it is possible to check the charge of each cell with a volt meter from the charger plug or cumulatively from the main positive and negative wires that connect to the ESC.
Hopefully this is more clear.
The question I should have asked was what type of battery/connector do you have? Charger?
I really shouldn't have assumed, thanks missilman for the wake up call.
       Post #: 104
RE: X or XL? - 4/10/2007 6:37:40 AM
zerofox
Status: offline
well, i removed the connector and reversed all leads... its been charging for bit now and seems ok, we'll see once its done
ive been told by my LHS that its a good idea to charge it, then run it down, and charge it again a few times to 'break it in'...
agree? disagree?
       Post #: 105
RE: X or XL? - 4/10/2007 11:44:59 AM
Raserx
Status: offline
lipos do seem to run better after a few charges. But don't waste the charges...use em' on your heli. You'll be after more batteries soon...I have 5 and could use 5 more for my SE more. 5 Give me almost a solid hour of flying...if i can keep it in the air that long..lol
       Post #: 106
RE: X or XL? - 4/12/2007 3:28:08 AM
zerofox
Status: offline
well, i got it all dialed in.
got it off the ground a few inches a few times, starting the process of trimming.
then i bumped the rudder a bit to straighten it out, the throttle went up a couple of 'clicks' and it popped up.
i panicked, tried to bring it down.
it started a slight roll on the way down, hit the ground and grenaded.
im not sure when ill be able to afford to replace everything that broke, so it was fun, i appreciate all the tips and help.
Click to see fullsize image.
Click for fullsize
       Post #: 107
RE: X or XL? - 4/12/2007 3:36:03 AM
Raserx
Status: offline
MAN...I hate to hear that. Boom strikes are the worst...cause everything goes at once.
The parts are cheaper than you might think.I might have a few parts I'll loan ya for postage...
       Post #: 108
RE: X or XL? - 4/27/2007 4:43:56 PM
zerofox
Status: offline
i havent posted anything in here for a while, so i thought id update.
im fixing the trex a part at a time... the list is pretty darn long, $150 worth.... i considered just getting an SA...
in the mean time, im picking up a used CP Pro as a crash test dummy so i can fly (read crash) something while im working on my rex.
should have the CP in about a week or so.
thanks again to everyone who helped me out on here, ill have rex pics up here again soon!
       Post #: 109
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
11.578RCU1
