2 stroke Engine dyno home made??????
Tower Hobbies
Logged in as Guest
  Printable Version
Saito FA-325 R5 Radial - RTF
Seller:  RKINERSON
Details:   $1,100.00   |  9/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> 2 stroke Engine dyno home made??????
Page: [1]
Login
2 stroke Engine dyno home made?????? - 3/29/2007 1:12:53 PM
jet182
Status: offline
Is there any way of making a home made dyno for these little engines. Just starting out and would like to see the results of future modifications.
Any help much appreciated.
Thanks Troy
E-mail troylynch182@hotmail.com
       Post #: 1
RE: 2 stroke Engine dyno home made?????? - 3/30/2007 4:39:52 AM
aussiesteve
Status: offline
Do you specifically wish to measure the torque or just see how the performance changes with modifications?
If you wish to actually measure the torque, the easiest way is mount the engine on a tilting platform with a small hydraulic ram and pressure gauge at one end of the tilting arm (the end of the platform away from the hinge of the plate). then couple the engine to a small load (small alternators from motorcycles work well - you can alter the load on them via a variable resistor). measure the RPM and the pressure on the gauge - this pressure will equate to a torque value (Foot/lbs or Newton Metres). Horsepower can then be calculated.
If you just wish to see how performance changes, Mount the engine on a stand, run it with different propellors and measure the RPM with a good tacho. Use the same propellors each time so that the loading is standardised.
Either way for proper comparison, you will need to also measure air Temperature and humidity. then calculate back to standard conditions.
_____________________________
Australian agent for
RCGF engines & Boxes, 33RC airframes, Tzone models, Super Kraft (SK) & others
(in reply to jet182)
       Post #: 2
RE: 2 stroke Engine dyno home made?????? - 3/30/2007 1:44:54 PM
Jezmo
Status: offline
Look at this thread
http://www.rcuniverse.com/forum/m_5637891/tm.htm
Raptor 50 V2 OS 50 Hyper, T-Rex 450XL CDE, Spektrum DX7, SuperTigre OS FOX Saito Enya Jett TT
(in reply to aussiesteve)
       Post #: 3
RE: 2 stroke Engine dyno home made?????? - 3/30/2007 2:09:06 PM
Sport_Pilot
Status: offline
I seem to recall one where the engine was connected to a generator, the load of the generator would load the engine, and an arm from the generator would push down on a spring scale. Measuring the power from the generator was a nice double check on the RPMxTorque from the engine speed and scale reading.
“I Saw Elvis at 1000 Feet” John Force
(in reply to Jezmo)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.518RCU1
