Jezmo
Joined: 6/26/2006 From: Spring, TX, USA Status: offline
quote:
ORIGINAL: KC36330 kc EDIT: N2O allows an engine to burn more air/fuel, Nitro only provides more O2 As It Burns giving an engine more power, the two work nothing alike. Actually, they do work alike. They both release O2 during the heat of combustion allowing more fuel, in our case alcohol, to be added to the mixture and burned in the chamber. When you run a higher nitro content fuel in your plane, you will richen up the mixture to compensate for the added O2 being released. A property of nitrous oxide is that at about 565 degrees F., it breaks down into nitrogen and oxygen. When it is introduced into the intake tract of an internal combustion engine, it is sucked into the combustion chamber and, on the compression stroke, when the charge air temperature reachs 565 deg., a very oxygen-rich mixture results. If we add extra fuel during nitrous oxide injection, the effect is like a super charger or increasing the compression ratio of the engine. I won't post any more on this subject but there is erroneous info being posted here so take what you read with a grain of salt. I am no chemical engineer but I did race cars professionally for over 30 years and learned just a wee bit about fuel. Just enough to know when I am being BSed.
_____________________________
Raptor 50 V2 OS 50 Hyper, T-Rex 450XL CDE, Spektrum DX7, SuperTigre OS FOX Saito Enya Jett TT
