Tmoth4
Joined: 3/14/2002 From: Brecksville, OH, USA Status: offline
NEO, I'm not making my dive brakes functional. They're in the fixed position. I know it would be really neat but I didn't want the extra complexity and extra servos. On my earlier Dauntless I used just the flaps and no upper dive brakes and it worked fine. If I did do upper dive brakes I would definitely hide the control horns. On the Ziroli plans he shows Robart gear door type hinges, I think. You could glue in 1/8 ply bases for the horns and use short sheet-metal screws to attach the horns. Put the screws in, take the screws out, put a drop of thin CA in the holes and put the screws back in. The horns will not come loose. I've attached control horns that way many times with no problems. If any of the screw pops through the top you can file it off. Are you going to the MAPS show on Saturday? It looks like the Dauntless is still going to be there. There's supposed to be a P38 there too, which I've never seen fly before. Jim
