Tmoth4
Joined: 3/14/2002 From: Brecksville, OH, USA Status: offline
rcfanuck, I've built three planes from Ziroli plans: AT6, P47, and now the Dauntless. Nick Ziroli has got to be one of the best designers in the world. All of his plans are fantastic. He gives you a full sheet of patterns for all parts and, if you cut them out carefully, everything fits together perfectly. I've built from some "off brand" plans that were a nightmare. The only deviation from Ziroli's plans is that I replace a lot of the plywood parts with balsa in low stress areas just to save weight. This has had no ill effects on my other two planes. His Hellcat plans should be every bit as good as his others. I personally have always loved the nice curved lines of the Dauntless. shupack, I agree. I've learned a tremendous amount by following other's threads here. Jim
