gunfighter
TX, USA Status: offline
Stan, First let me say that we are still having a few "growing pains", and there were several mistakes made at the event Saturday. As the CD, I take the blame. We had pilots for lap counters all day and I was amazed at the number of "discrepancies" we had. This was caused, I feel, by the lap counters trying to watch the race while they are counting. They loose track of which plane they are supposed to be counting and miss a lap or count a lap twice. If some one has a suggestion to aleviate this I would love to hear it! Re: the 11 lap rule - If you cut a pylon the lap you are on does not count. You must run another lap to make that up. Where the problem arose was disagreement whether the pilot that cut was ahead of or behind the 2nd place plane. If the plane that cut was ahead, and on the same lap, then he would only have to lap the second place plane 1 time to be in the lead. If, however, the plane that cut was behind another plane, then he would have to pass the other plane twice to take the lead. It was my understanding from the lap counters, that the plane that cut was behind when he cut. After a rather in depth investigation, it appears there were 2 errors by 2 different lap counters during that race. 1 lap counter only counted to 9 while the other rightfully counted to 11. This was not discovered until after the next main was run so there was really nothing I could do about it. If this race had been for money or big prises, I would have declared the race void and run it again. By the time I realized what had happened, one of the planes involved in the heat was destroyed in a crash so a re-run was impossible. We also had a problem with a cut judge. This person had worked as a cut judge before with no problems that I was aware of. this race, he decided to call a cut if the plane did not go completely around the poles. Our rule is you just have to fly past the pole. This caused a couple of people to "cut out" and DQ. When this was discovered, the judge was replaced and more specific instructions were given to the cut judges. I then had a pilot that wanted me to go back and adjust his score card to show a first place instead of a DQ in one race. I could not do that because when the second cut was called, the lap counter stopped his watch and quit watching the plane, so no one knew where he would have finished or what his time was. It seems the larger this gets, the more problems we discover. The race group and all the clubs involved are working very hard to get this right, but it will take work and understanding by all to make it go. Please keep the comments coming. I do not mind CONSTRUCTIVE critisism. That is the only way we learn what you liked and what you did not like. Next race is June 9th at the Prop Busters field in Somerset. See you there. And by the way - you guys are in trouble because I am actually going to race at the next one!!!
