Club 40 - Rules / Mod discussion
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Club 40 >> Club 40 - Rules / Mod discussion
Page: [1] 2 3 4 5   next >   >>
Login
Club 40 - Rules / Mod discussion - 3/30/2007 3:50:32 PM
daven
Status: online
Please use this thread to discuss Rules and allowed mods.
Some of the main issues from the Hangout thread were.
Re-covering?
Fuel Tanks?
Stock Hardware?
Wheels / Landing gear?
Pushrods?
Sealing Gap surfaces?
Cheek cowl mods?
Reinforcement?
etc...
Have at it.
< Message edited by daven -- 3/30/2007 4:04:47 PM >
_____________________________
Dave Norman
klasskote.com
supertrc.com
       Post #: 1
RE: Club 40 - Rules / Mod discussion - 3/30/2007 4:52:49 PM
Jim Duda
Status: offline
Let's race folks! As long as we keep to the two airframes and engines currently specified in the Club 40 Rules I don't think any mods will result in a measurable speed advantage. These are just suggestions...
Re-covering? Allow it - use anything you want: Toughlon - Monokote - Econocote - Solarfilm - FasCal - Silk and Dope, etc.
Fuel Tanks? Allow any tank - any size...vented or Bubbleless
Stock Hardware? Use any brand, metric or SAE, kit supplied and/or whatever you have available
Wheels / Landing gear? Wheels must not be smaller (diameter) or thinner (width) than stock; filing flats on landing gears for a better set screw (grub screw) bite is encouraged to prevent loss of mains and tailwheel. Steerable tailwheel is required!
Pushrods? Use anything you want BUT they must exit at the points per stock airframes...in other words, NO INTERNAL Control Horns for Rudder and Elevator
Sealing Gap surfaces? Encouraged, but not required
Cheek cowl mods? Allowed as long as they stay internal to the engine compartment area and don't change the shape of the airframe.
Wing interchangeability Either wing may be used on either fuselage
Servo Tray May be changed (but it is not an easy modification)
Additional Hinges Allowed - use as many as you want, mechanical or CA type
Reinforcement? Encouraged, but not required. Examples: Reinforcing wing center section; landing gear block; wing hold down blocks, etc.
Wing Bolts Nylon bolts allowed - any size. Taping over the supplied metal ones to prevent loss due to vibration highly suggested!
Muffler Allow JB Welding and pinning the muffler halves together to prevent loss of muffler.
Propellor Allow anything including wood props. Balancing highly recommended
Spinner Spinner/Prop nut highly recommended - not required. Aluminum spinner (any size) allowed. "Heavy Hub" allowed for balancing if required. Use the supplied plastic spinner at your own risk
Fuel Bring your own. Any nitro % allowed
Minimum Weight 4 lbs - 8 ounces - Ball Bearing engine, 4 lbs - 6 oz Bushing engine
You folks take it from here...
< Message edited by Jim Duda -- 3/30/2007 5:55:35 PM >
(in reply to daven)
       Post #: 2
RE: Club 40 - Rules / Mod discussion - 3/30/2007 6:00:29 PM
daven
Status: online
Good list Jim, but I would suggest limiting fuel to not more than 15% nitro.
Dave Norman
klasskote.com
supertrc.com
(in reply to Jim Duda)
       Post #: 3
RE: Club 40 - Rules / Mod discussion - 3/30/2007 6:13:39 PM
averen
Status: offline
Funny that you mention this. I'm going to be trying some 30% in my LA .40 this weekend just to see if there is any performance gain. I doubt there will be that much, as to really take advantage of the additional nitro another shim would be needed on the head. I'll report back with what I find, but I have a feeling it will only be a couple 100RPM at best.
I pretty much agree with everything that Jim has to say. Although swapping wings might be a little much as it will change the drag profile of the Racer to be cleaner. I think as long as the drag profile stays the same the changes should be allowed. Having said that I do have the Racer and I would love to put the Raider wing on it since it's cleaner So on one hand I'm all for it...but on the other it might be unfair. I'll have to see if Todd will let me borrow a wing of his for a couple of laps and see if there is that much of a performance gain...we can decide from there. I have no problems putting the Racer wing on the Raider.
Jared
Knowledge is Power, Power Corrupts, Study hard...BE EVIL!
(in reply to daven)
       Post #: 4
RE: Club 40 - Rules / Mod discussion - 3/30/2007 6:21:00 PM
DonStegall
Status: offline
Here is my original message that I should have started a new topic with.
quote:
I knew this day was coming, but I was hoping it would be a little longer.
We need to keep it fun, but we may need to put a tighter set of rules together to control technology creep. Since I have been in contact with a large number of the groups and people that are flying Club 40, I will take on the task of identifying areas that may need regulation. And my end result will be presented as a Request For Comments (RFC). I will start the process by listing some of the issues that I know about. And I will pose some questions.
To streamline the text, a few terms will be abbreviated:
SRM2 - Sky Raider Mach II
LR40 - LA Racer 40
The engine compartment sides (cheeks?) of the SRM2 are an area begging for enhancement and controversy. They vibrate, and they sometimes flutter at speed. Plus they can break if banged significantly. Some groups allow a piece of wood or other material to join them. At least one person has added doublers to them. I don’t think either method is a speed enhancement. In fact, both could slow the plane down. But techniques could be used to reduce any speed penalty and therefore could enhance the performance. I think it is important to not allow rounding the edges significantly. Removing the cheeks could possibly be a speed improvement. I think that they must be in place at the start of a race. Reattaching them during an event will probably not hold up to flight conditions. I think a pre-event inspection may be required.
The landing gear block assembly has broken out of some planes. Repairing the damage will most likely not result in exactly the same configuration, especially if the original parts are lost or are too broken to reuse. One repair I saw shifted the gear forward a quarter to half inch. The SRM2 and LR40 use struts with the same mounting configuration and are interchangeable. The landing gear on the SRM2 is shorter than the LR40 gear. I personally have used a LR40 gear on a SRM2 because it gives more ground clearance. Another person has used a landing gear made from flat aluminum stock. I doubt if he used the stock wheels because he used Dubro American size axles. Lost wheels will most likely be something other than stock wheels. We will probably need to specify a minimum diameter and width if substitute wheels are allowed.
ARF tanks are often not available at the local hobby shop. People tend to replace ARF tanks, especially with use and development of leaks, with off the shelf tanks. And there is the issue of bladder tanks. Some would argue that bladder tanks improve performance, and unless homemade, they add significantly to the cost of the aircraft.
The spinner used could affect performance. Some will prefer to use a smaller spinner or prop nut. Some will want to use a larger spinner. I personally have replaced some spinners with aluminum spinners.
SRM2 and LR40 wings are interchangeable. The dual aileron servos on a LR40 wing are exposed and may have more drag. Using a SRM2 wing on a LR40 could provide an advantage. An LR40 wing on a SRM2 would probably provide no advantage. A local guy busted his SRM2 wing and I had a LR40 wing with one little dent. Is it ok for him to use a LR40 wing on a SRM2?
Sealing the gaps of control surfaces, or using gap/hinge seal tape is another issue.
Does the amount of dihedral in the wing need to be checked?
At least one local guy trimmed the bottom of his rudder so he could get more elevator throw. This modification was for better aerobatic capability, but could it have a benefit in a race? The only thing it seems to do is allow better snaps.
I replace the control horns with Dubro horns and I use Great Planes nylon clevises on 2-56 pushrods. I also push out the wing mounting blind nuts and replace the wing bolts with 1/4-20 nylon bolts. Is hardware substitution an issue?
Don Stegall
RCPRO - http://www.rcpro.org - http://www.rcpylon.com
(in reply to averen)
       Post #: 5
RE: Club 40 - Rules / Mod discussion - 3/30/2007 6:56:15 PM
Jim Duda
Status: offline
Dave - I think at this point you're unbiased since you have never flown the event and as far as I know, have never built either plane allowed under the current "rules"...do you see anything suggested so far that would give someone an unfair advantage at winning the heat?
On the fuel issue: Speaking for Texas, we're trying to keep the entry fee at a minimum so to avoid the hosting club(s) from bearing the fuel costs, we allow the contestants to bring their own...thus enforcing a maximum nitro content is pretty tough. Personally, if someone shows up with 60% nitro, needling it becomes tougher, plugs will melt, and the chances of a DNF increase significantly. To me, running exotic fuel isn't worth the risk.
PLEASE newcomers, let us hear your concerns since this event is primarily intended for you to have fun and to feel that you're not at a disadvantage.
(in reply to DonStegall)
       Post #: 6
RE: Club 40 - Rules / Mod discussion - 3/30/2007 7:34:09 PM
daven
Status: online
Jim,
Its not so much as a mod that would give an unfair advantage, as it is a "Mod that is perceived as an unfair advantage".
Perception is far more powerfull, and damaging.
Here are my thoughts take them as you will, I will most likely never fly in this class:
I wouldn't allow bladder tanks. As much as I like them, I don't think they belong in this type of event. It brings on extra cost (tanks are expensive, and so is the tanker), and is not in my opinion in the spirit of the event.
Sealing the hinge line is fine. This is no big deal to me, anyone can do it with a little tape or covering and offers virtually no performance gain other than roll rate
I would limit fuel to 15% max, I really think the contestants would think that was fair, even if they were bringing their own fuel.
I see no issue in replacing hardware and pushrods, as long as they exit the plane where they are suppose to per the kit.
I like the idea of a minimum weight limit.
I like your idea on replacing the wheels as long as they are no skinnier or shorter.
Thats about it.
Dave Norman
klasskote.com
supertrc.com
       Post #: 7
RE: Club 40 - Rules / Mod discussion - 3/30/2007 10:25:40 PM
Pathous
Status: offline
I haven't run an 40 la but when I run my 15 la on 30 percent fuel I get a large increase in power usually around 1k to 1.5k rpm.
Scott
AMA 6256
RCCA 812
(in reply to daven)
       Post #: 8
RE: Club 40 - Rules / Mod discussion - 3/30/2007 10:42:08 PM
Ed Smith
Status: online
I cannot resist it. I have to make a comment.
I have never flown club 40 and probably never will. I have nothing against it I am just too involved in what I already race. So often we hear that beginner racers want the advice of the experienced racers. Notice I did not use the word "Expert"
So I offer this warning. Reading this thread I get the impression that STOCK, STOCK, STOCK, is no longer satisfactory. Even unlimited fuel is allowed. Well keep it up.
This is exactly how we ended up with $1000,00 Quicky airplanes and $1500.00 Q40 airplanes
Ed S
< Message edited by Ed Smith -- 3/30/2007 10:44:00 PM >
(in reply to daven)
       Post #: 9
RE: Club 40 - Rules / Mod discussion - 3/30/2007 10:59:22 PM
HighPlains
Status: offline
Limit the prop to one size. 9-6 APC works very well.
Dave and Ed both have valid points.
When people want more from their planes, it's time for them to start flying 424 on the same course.
In politics if you want anything said, ask a man. If you want anything done, ask a woman - Margaret Thatcher
(in reply to Ed Smith)
       Post #: 10
RE: Club 40 - Rules / Mod discussion - 3/31/2007 12:47:52 AM
Druce
Status: offline
Why would you want to waste good money on buying 30 -60% fuel + a plug a race on a beater motor and a airframe such as a club 40. Use 5% and keep it simple and user friendly. You could call it formula club 40....
(in reply to HighPlains)
       Post #: 11
RE: Club 40 - Rules / Mod discussion - 3/31/2007 12:59:00 AM
DonStegall
Status: offline
Most hobby shops in the US don't carry 5% in quantity. 10% and 15% are the most common and well stocked 2 stroke fuels. Most do carry 30% heli fuel, but not in quantity.
Because of my trailer, people wanted me to carry fuel. 15% outsells the others by 4 to 1 at the minimum. Plus 15% is the standard fuel for AMA class racing.
I believe Jim Duda's suggestion for pilot supplied fuel is to keep it from being a complication for clubs hosting races. Acquiring fuel is a hassle. You have to be able to get the quantity needed. Determining the quantity needed is the catch. Unless you have a long pre-registration period, it is hard to guess how much fuel to buy. So somebody gets stuck with overages, or gets blamed if not enough is available.
I believe that limiting the nitro to 15% and using the honor system is the right thing for Club 40 Racing. If there is doubt about a competitor's fuel, tach it with their fuel, drain the tank and fill it with reference fuel and tach it again. If there is a 500 rpm difference, disqualify the pilot, or sell them fuel to use. These are the refinements that this thread can address.
Don Stegall
(in reply to Druce)
       Post #: 12
RE: Club 40 - Rules / Mod discussion - 3/31/2007 1:33:22 AM
DonStegall
Status: offline
quote:
ORIGINAL: Ed Smith
Ed S
Ed,
The two currently allowed airframes sell on the street for $70 and $100. The engines are $80 or less. Even if someone buys an OS 40 FX, it is still only $110 or less.
Say you go wild and by 5 rolls of covering for trim. That's $60. Even add $25 for a bladder tank. You're still under $300 minus the radio.
The REAL cost of the winning Q-500 and Q-40 planes is really closer to $1500 to $2000. Have you noticed that mostly sponsored pilots win. Well they are sponsored because they are good. But they get the benefit of top-of-the-line radio gear including $100+ servos. Someone could buy coreless digitals for a Club 40 plane and spend $700 on the in-plane radio gear. But that would just be stupid. We can't legislate intelligence. And coreless digital servos would give no advantage in a Club 40 plane. As Bob Dible says, one click of the needle valve makes more difference. We are already seeing market driven companies producing lower cost coreless digital servos. If an IMAC pilot wants to try Club 40 and has coreless digitals sitting around that he wants to use, why not let him? He may not feel comfortable with using the servos that may have been in a crash in his $5000+ IMAC plane, but doesn't care if they happen to fail in a Club 40 plane.
Don
