RE: Vendetta Brushless motors... pros/cons
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: Vendetta Brushless motors... pros/cons Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Vendetta Brushless motors... pros/cons - 4/2/2007 5:45:21 AM
jaejw1
Status: online
rally tires,,, those hard things,,,,,
what didnt you like about the half8th gex adapter,,,, did you get the plastic one or the alloy
_____________________________
motor review http://www.rcuniverse.com/forum/m_5643067/tm.htm
tire review www.rcuniverse.com/forum/m_6000527/tm.htm
(in reply to 20%nitro)
       Post #: 26
RE: Vendetta Brushless motors... pros/cons - 4/2/2007 8:16:28 AM
Silentbob343
Status: offline
What is the max RPM on the Ammo motors? Both the 3900 and 5100 claim to handle 11.1v, but a fully charged 3 cell is 12.4v which would put the 5100 over 60,000 RPM.
I have one 2 cell and one 3 cell, so I'm thinking the 3900. The OD of MQ tires is 2.8". What is it for Mini Inferno tires, 2.5"?
heh, max RPM for the permax says 50,000RPM, but 5200kv with a 3 cell lipo is way over 50,00RPM.
http://www.multiplexusa.com/product_fs.htm
< Message edited by Silentbob343 -- 4/2/2007 9:19:29 AM >
       Post #: 27
RE: Vendetta Brushless motors... pros/cons - 4/4/2007 4:21:41 AM
20%nitro
Status: offline
the hex seemed a little small and also the tire options seem limited with the adaptors oh and they were plastic . HPI Pirelli T Rally Tire 26mm S Compound seem to be the trick for the tc guys on this surface but its not the only choice because of the limited contact patch. i ordered both the ammo and the permax to try in the vendetta should be here soon and the spur kit may be here for the weekend-------????
thanks for the interest and help
< Message edited by 20%nitro -- 4/4/2007 4:36:21 AM >
mbx5 prospec ws7,ttr st1 c6bb,jmn crt axial 28,firestorm,18t,detta,tc3 mamba 7700 dirt oval
(in reply to jaejw1)
       Post #: 28
RE: Vendetta Brushless motors... pros/cons - 4/7/2007 12:05:43 AM
aznmode
Status: offline
Hey Jae,
Got my Permax a few days ago and it is fast and very torquey. I like it a lot. Thanks. The only thing is on take off it cogs and I know thats because of the motor. Is there a way to get around that? I was bragging to my friends how fast this motor is and how it can probably keep up with their mini-t and propulse but my take off sux a$$ cause of that cogging so I end up losing when I try to race them. Any input is greatly appreciated.
       Post #: 29
RE: Vendetta Brushless motors... pros/cons - 4/7/2007 12:12:49 AM
Silentbob343
Status: offline
quote:
ORIGINAL: aznmode
Hey Jae,
NVM I see you are using the Quark. My goal is 0 cogging with my BL setup so let me know how it goes.
< Message edited by Silentbob343 -- 4/7/2007 12:15:27 AM >
(in reply to aznmode)
       Post #: 30
RE: Vendetta Brushless motors... pros/cons - 4/7/2007 12:20:31 AM
jaejw1
Status: online
quote:
ORIGINAL: Silentbob343 What is the max RPM on the Ammo motors? Both the 3900 and 5100 claim to handle 11.1v, but a fully charged 3 cell is 12.4v which would put the 5100 over 60,000 RPM. I have one 2 cell and one 3 cell, so I'm thinking the 3900. The OD of MQ tires is 2.8". What is it for Mini Inferno tires, 2.5"? heh, max RPM for the permax says 50,000RPM, but 5200kv with a 3 cell lipo is way over 50,00RPM. http://www.multiplexusa.com/product_fs.htm
you might never see max rpm,,, not unless you gear it wrong and drive it for long periods,,,,
you have to look at drag and rollout,,, you might reach the vehicles top end before reaching the motors max rpm...
there is a video of someone using a 3s lipo with the permax ,,, dont know their gearing ,,,, but if you are using stock wheels you might want to gear it at 19/41
(in reply to Silentbob343)
       Post #: 31
RE: Vendetta Brushless motors... pros/cons - 4/7/2007 12:24:43 AM
jaejw1
Status: online
quote:
ORIGINAL: aznmode Hey Jae, Got my Permax a few days ago and it is fast and very torquey. I like it a lot. Thanks. The only thing is on take off it cogs and I know thats because of the motor. Is there a way to get around that? I was bragging to my friends how fast this motor is and how it can probably keep up with their mini-t and propulse but my take off sux a$$ cause of that cogging so I end up losing when I try to race them. Any input is greatly appreciated.
which esc are you using,,,, if its the mamba ,, then it will cogg but the Quark pro car33a is whats best for that motor,,,,,, how is the motor geared,,, what pinion/spur
       Post #: 32
RE: Vendetta Brushless motors... pros/cons - 4/8/2007 3:07:08 PM
20%nitro
Status: offline
thanks jaejw1 i installed the gp ammo and used the mamba spedo and went with the 21/41 gearing and speeds were good and temps were in in line with the guys rinning the associated. now i am thinking about the detta truggy. the long arms and pivot ball knuckles and better body mounts are looking good. anyway thanks to you the detta is gona be a winner again!
       Post #: 33
RE: Vendetta Brushless motors... pros/cons - 4/8/2007 5:49:06 PM
jaejw1
Status: online
21/41 was a guess since I use bigger tires,,,,, how is the speed and torque..... and what can you compare it to
       Post #: 34
RE: Vendetta Brushless motors... pros/cons - 4/9/2007 5:19:08 AM
20%nitro
Status: offline
i run against rc18t and b's with mamba 8kvs and a guy showed up with a detta with a gh motor with a mamba spedo. i dont know what gearing they are running. i'll try to get more info. i spent most of my time fighting set up to get my car to drive right. the torque was strong with the 20/41 but top speed was lagging so i changed to the 21/41 and lost some torque but gained the speed i needed. one guy with the 8kv has a 13/60 in his rc18 and he took the main. the guy with the detta/gh did very well also. after the races i finished my set up and think i can compete next week if i can go. my temps were 116-120 on the spedo and 156-160 at the motor and using 30% drag brake after a 4 min main. i checked the amps at full power and free spin was at about 16 amps and if i locked the wheels i could force 28 for a moment so it seems the motor will continue to work with the spedo even though the specs say otherwise.
g's im gettin windy but im wondering why another friends vendetta with a 6800 mamba does not overheat.
       Post #: 35
RE: Vendetta Brushless motors... pros/cons - 4/9/2007 5:33:35 AM
jaejw1
Status: online
probably gearing or using a rc18 spur,,, a few guys have done this,,,, are you using the detta buggy,,, if so are you using stock tires... might want to switch to the mini inferno buggy wheels
       Post #: 36
RE: Vendetta Brushless motors... pros/cons - 4/9/2007 9:28:59 AM
aznmode
Status: offline
quote:
ORIGINAL: jaejw1
quote:
ORIGINAL: aznmode
Hey Jae,
I'm using quark33 and a 20c 1500mah 3cell lipo geared at 19/41. Didn't you mentioned that the motor will seem like its grinding in the beginning but thats how the motor is. I think thats what i'm experiencing.
< Message edited by aznmode -- 4/9/2007 9:30:48 AM >
       Post #: 37
RE: Vendetta Brushless motors... pros/cons - 4/9/2007 10:33:11 AM
jaejw1
Status: online
holy CRAP dude,,,,, a permax with a 3s lipo geared at 19/41,,, how fast is that thing,,,, you should be able to beat an rc18 with a c4 with absolute ease....
are you racing it or just bashing it
wow I would love to see a video of it
       Post #: 38
RE: Vendetta Brushless motors... pros/cons - 4/9/2007 10:47:28 AM
jaejw1
Status: online
quote:
ORIGINAL: 20%nitro i run against rc18t and b's with mamba 8kvs and a guy showed up with a detta with a gh motor with a mamba spedo. i dont know what gearing they are running. i'll try to get more info. i spent most of my time fighting set up to get my car to drive right. the torque was strong with the 20/41 but top speed was lagging so i changed to the 21/41 and lost some torque but gained the speed i needed. one guy with the 8kv has a 13/60 in his rc18 and he took the main. the guy with the detta/gh did very well also. after the races i finished my set up and think i can compete next week if i can go. my temps were 116-120 on the spedo and 156-160 at the motor and using 30% drag brake after a 4 min main. i checked the amps at full power and free spin was at a
