jaejw1
CA, USA Status: offline
I already told u whete to go,,,, and ur not going to be very happy with the lil tiny mamba motor,,,, with out knowing what gearing ur going to use,, there is no way to just give u the link to a particular gear,they may not make it,,, the pinion needs to be a 48 pitch metric ,, I thjink its .6 module,,, and the permax will tear every gear u have if u gear it at either 16/45 or 13/45 (stock gearing) the permax is best when geared at 19/45 or 21/45,,,,, btw have u read this thread from the beginning,,,, reason I ask,,, what makes u think the 4200 will be able to do anything,,, it will probably be as fast as the vr3 motor,,,,,
< Message edited by jaejw1 -- 1/14/2008 1:22:59 AM >
_____________________________
motor review http://www.rcuniverse.com/forum/m_5643067/tm.htm tire review www.rcuniverse.com/forum/m_6000527/tm.htm
