Yak 52 3D - Landing Gear "Nitro"Staff Help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> Yak 52 3D - Landing Gear "Nitro"Staff Help
Page: [1]
Login
Yak 52 3D - Landing Gear "Nitro"Staff Help - 4/1/2007 11:36:30 PM
DPRC
Status: offline
Nitro Staff,
Flew my Yak 52 3D for the first time today. I have to say it flew very nice with very little tirm needed. Just a little aileron correction. After flying for about 8 minutes, I brought the plane in to land, very smooth. As I touched ground, the landing grear broke off. The landing approach was not to "hot" by any means. When I went to pick up the plane from the field to examine the damage, (the landing gear and where it mounts,) appears as if little or no glue was used what so ever. Pretty disappointed to say the least. I feel as if this was the cause for the structual damage. Thank you in advance for support in this situation.
Daniel
_____________________________
DPRC
       Post #: 1
RE: Yak 52 3D - Landing Gear "Nitro"Staff Help - 4/2/2007 6:39:20 AM
edberg
Status: offline
I was thinking of getting this plane, is the structure bad or does it just need to be reglued in that area? I suppose I could just add some epoxy around the landing gear area.
AMA#
873099
(in reply to DPRC)
       Post #: 2
RE: Yak 52 3D - Landing Gear "Nitro"Staff Help - 4/2/2007 7:50:53 PM
DPRC
Status: offline
The plane flew really nice for a maiden flight. I was really impressed. My only deal is that there was no glue where the landing gear mounts. I'm sure it was just an oversite at the factory. I have not seen a prettier plane in this size. I am sure Nitro will make it right.
dp
DPRC
(in reply to edberg)
       Post #: 3
RE: Yak 52 3D - Landing Gear "Nitro"Staff Help - 4/2/2007 8:48:46 PM
nitrostaff1
Status: offline
ok PM me your order number and I'll send you a new landing gear.
John
Nitro Planes
--===www.nitroplanes.com===----
(in reply to DPRC)
       Post #: 4
RE: Yak 52 3D - Landing Gear "Nitro"Staff Help - 4/2/2007 9:29:40 PM
DPRC
Status: offline
John,
Sent PM, Unfortunatly the landing gear is fine, it's the fusalage.
dp
DPRC
(in reply to nitrostaff1)
       Post #: 5
RE: Yak 52 3D - Landing Gear "Nitro"Staff Help - 4/2/2007 9:40:23 PM
edberg
Status: offline
Reading through these threads, you guys have got to be the best customer support I have ever seen.
AMA#
873099
(in reply to DPRC)
       Post #: 6
RE: Yak 52 3D - Landing Gear "Nitro"Staff Help - 4/19/2007 12:06:12 AM
RC_DESI
Status: offline
I had the same issue with my Yak,
The Landing gear block just came off on decent landing. On inspection noticed that it did not have any glue. Looked like was supported by the slot/groove in the mounting plate plate.
I managed to fix it & used 30min epoxy to glue it right ;-)
--Arvind
       Post #: 7
RE: Yak 52 3D - Landing Gear "Nitro"Staff Help - 9/26/2007 5:50:44 AM
maxcontinuos
Status: offline
I had one of these YAKs as well and sure enough, on landing, the gear folded. Came right out of the fuse. The aluminum gear was also really soft. You could literally bend it into any shape you want. I hate ARFs that require a complete change of hardware and structural reinforcing before you can even fly. In the end, I changed out all the hardware, reinforced the landing gear box and adjacent longerons, replaced the landing gear legs, chucked the wheel pants and used proper axles. After all that, the stab failed.
Here is a suggestion, keep the crap hardware, we usually throw it away anyway, and concentrate more on at least building an airworthy structure.
< Message edited by maxcontinuos -- 9/26/2007 5:52:03 AM >
(in reply to RC_DESI)
       Post #: 8
RE: Yak 52 3D - Landing Gear "Nitro"Staff Help - 9/27/2007 3:35:44 AM
opjose
Status: offline
The landing gear blocks seem to need a serious going over, no matter who the manufacturer is.
H9, Great Planes, etc. all suffer from exactly the same problems with the gear mounts, and need for re-inforcement...
I find I almost prefer the softer landing gear though... as long as the gear can be bent back ( I guess this excludes many aluminum gear ) safely.
I would MUCH rather have the gear splay out on me due to a hard landing, than to have to reconstruct the gear mounting area.
It's easy to merely bend things back right at the field as opposed to having to perform major surgery.
The Ultimate 1.20's gear have been called "soft and weak" by some, yet I find them well suited to the plane... since I can readily bend them back.
That is as long as you re-inforce the gear mounting areas...
I replaced my Funtana S90's metal gear with CF ones... and that proved to be a mistake... the next hard landing the underside of the fuselage ripped out ( it was heavily re-inforced by me too ) but the gear stayed nicely in-tact... I would have rather replaced the gear again...
While I often do replace key hardware components a lot of the provided stuff is useful and usable. In the same price ranges rarely to the "big boys" provide any better... Yeah some of needs to be better, but again this is endemic to the industry it seems, in the attempt to keep the prices down on the lower cost planes.
I don't pretend to excuse this, but merely point out that these faults are non-exclusive to any one vendor.
As Max said, I would prefer a sturdier airframe and no hardware, for the same prices...
I guess the problem is that as a whole this is not what we collectively expect to purchase. We as consumers take for granted that horns and fittings will be included.
Build em'', fly em'', crash em'' and build more.
(in reply to maxcontinuos)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.594RCU1
