Throat diameter for 60sp carb?
Tower Hobbies
Logged in as Guest
  Printable Version
O.S. Engines O.S. FS-120 III Surpass (Pump)
Seller:  RCadmin
Details:   $350.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> Throat diameter for 60sp carb?
Page: [1]
Login
Throat diameter for 60sp carb? - 4/3/2007 5:55:18 PM
JoeyCoates
Status: offline
I have a 60sp that seems to have some carburettor issues. I have talked to the service center and the gentelman was very nice an d haelpful, he sent an instruction sheet detailing how to set the carb up, but it is not behaving. Whenever I bring the engine to a low idel it will begin to speed back up after about 2-4 seconds raising in rpm by 400-500 from a 1500 rpm idle to around 2000. I have fiddled with the carb on a test benc extensivly to no avail, the barrel seems to have a lot of in and out movement, and the high speed needle has a lot of back and forth movement even with a new rubber o-ring. I would like to try another carb just to see what happens but I need the throat diameter of the original carb so that I may use another with a similar diameter. Thank you.
       Post #: 1
RE: Throat diameter for 60sp carb? - 4/4/2007 8:24:16 AM
RCV Engines
Status: offline
Hi Joey
Please contact me on laurenne@rcvengines.com. Include your name, address and serial number
Best regards
Laurenne
_____________________________
Technical Support
RCV Engines - UK
(in reply to JoeyCoates)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
