jimweda
CA, USA Status: offline
Actually, the one time it does seem to make a difference is if you are flying elevons like on a wing or the Funjet for instance. If you don't hook it up correctly you can't get the servos to work in the proper directions. So, if you're flying a plane with elevons and you can't get it to work right, try switching the two and then it should be fine. Some times you'll have to reverse one or two of the servo directions, and, also in this case, you need to have "Flaperons" on. Not sure why it works that way, but seems to be fine if you're just doing two seperate aileron controls. Oh well, live and learn. Jim [/quote] aflipz is correct about the aileron/aux1. You just need to turn flaperons on, and have flap mixing to 0. I think I'm set up backwards though. I use aileron for right aileron, and aux1 for left aileron. Works fine. I believe some guys use ail. for left aileron, and aux 1 for right. Doesnt seem to make a difference. [/quote]
