NEW~~~E-Flite Extra 260 480 ARF~~~
Tower Hobbies
Logged in as Guest
  Printable Version
The Amazing FLAMING DOOFUS Mini Flying Wing RTF!
Seller:  EASYTIGER
Details:   $89.00   |  11/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> NEW~~~E-Flite Extra 260 480 ARF~~~
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/4/2007 2:32:32 AM
stinger40
Status: offline
Whee!!!!! A new plane!!! This one looks good!!!
http://www.e-fliterc.com/Products/Default.aspx?ProdID=EFL2475
< Message edited by stinger40 -- 4/4/2007 6:22:17 PM >
_____________________________
Gravity is a terrible, terrible thing.
       Post #: 1
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/4/2007 10:05:58 PM
stinger40
Status: offline
Nobody likes this one? I thought it looked pretty spiffy. I'll have one when it comes out.
(in reply to stinger40)
       Post #: 2
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/5/2007 3:24:30 AM
Taildragger726
Status: offline
I like it !!
Also known as N726AC
       Post #: 3
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/5/2007 4:33:52 PM
malcolmm
Status: offline
It looks interesting, but after building an Eflight mini Funtana X, I will wait and see how the Extra turns out. I dislike my Mini Funtana X so I am I am looking for a new home for my 480.
I noticed that the published weight for the Extra is almost identical to the mini Funtana X. But the mini Funtana X lists a battery of 2100, whereas the Extra lists a 1320 to 2100. The Mini Funtana X comes out much heavier than published, most are around 32 oz. If the Extra is similar, or even heavier with the 2100 (no way a 1320 is enough), it will be a flying boat anchor.
Malcolm
(in reply to Taildragger726)
       Post #: 4
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/5/2007 8:37:22 PM
3DownLow
Status: offline
This model looks like a candidate for the Cyclon Mini Punch. 2.8oz brushless outrunner/geared. Swings up to a 14 x 9 prop at about 450watts. That should overcome any weight issues. Costs more than the airframe, but most quality powerplants do. Small price to pay for having more than enough 3D H.P. under the cowl. Performance should be phenominal! Can't wait to try it out. Like the color scheme too.
Click to see fullsize image.
Click for fullsize
(in reply to malcolmm)
       Post #: 5
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/6/2007 12:18:07 AM
VictoryRoll-91
Status: offline
I LOVE the look of a cyclon motor!
That should work very well.
92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
(in reply to 3DownLow)
       Post #: 6
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/6/2007 2:15:32 AM
3DownLow
Status: offline
Looks cool,light and swings a big 3D prop, what more could you ask for?! Ok, cheaper price...and then my alarm clock went off!
(in reply to VictoryRoll-91)
       Post #: 7
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/9/2007 1:58:37 PM
stinger40
Status: offline
quote:
ORIGINAL: 3DownLow
I've never seen those before. Those look great!! Where can I get more info?
       Post #: 8
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/9/2007 2:57:18 PM
Maudib
Status: offline
Atlanta Hobby Carries the full line of Cyclon Motors:
http://www.atlantahobby.com/shopdisplayproducts.asp?id=385&cat=Cyclon
       Post #: 9
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/9/2007 3:07:40 PM
dribbe
Status: offline
Hi,
You can also find them (with some information) on Horizon Hobby's site.
The Mini Punch is in the Elite section.
http://www.horizonhobby.com/Stores/Default.aspx?StoreBrandId=CYL
Have Fun,
David
quote:
ORIGINAL: stinger40
quote:
ORIGINAL: 3DownLow
BVM Rep
Horizon Hobby
       Post #: 10
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/9/2007 3:24:01 PM
stinger40
Status: offline
Thank You!!!!! Both of you!
(in reply to dribbe)
       Post #: 11
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 4/23/2007 2:54:53 PM
Dangerous Dan
Status: offline
The manual states that the 1320 drains quickly at full throttle, I would use the 2100. I am quite curious what the weight is tith the 2100 and 480.
I need this plane to round out my hanger. I already have a 33% and a 42% Extra-260
when inverted down=up and up=$$
       Post #: 12
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 7/15/2007 5:58:21 PM
oregonrc
Status: offline
Mine came out just under 28oz AUW.
(in reply to Dangerous Dan)
       Post #: 13
RE: NEW~~~E-Flite Extra 260 480 ARF~~~ - 7/15/2007 7:47:49 PM
aflipz
Status: offline
I don't think that cyclon is a good choice if it needs a 14" prop, i am using a 11x5 and it's already close to the ground on take off and landing. Wouldn't go past 12"
I made a short vid using a 10x5E xoar, i was getting cutoffs on the 11" and i thought it was too much for the motor, turns out it was a bad motor lead connection (i think, haven't flown since i re did them) Anyway it's a great plane and will be a top performer if i can sort the power system issues i was having.
Phoenix 35
kontronik maxi dancer (66 grams)
vislero 1300 mah 20C 3 cell (110 grams)
bluebird 371's all around
7P rx
11x5 xoar (switched to 10x5 in the vid, much better power on 11x5)
Auw; unknown, guessing sub 26oz
Note the cutoffs were making me very very nervous. Hope you like the running comentary by my friend "Jello"
http://www.youtube.com/watch?v=Puu-K_QyQbA
(in reply to oregonrc)
