RE: Aquacraft Super-Vee 27 Nitro.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Aquacraft Super-Vee 27 Nitro. Page: <<   < prev  35 36 37 38 39 [40] 41 42 43 44   next >   >>
Login
RE: Aquacraft Supe... - 6/29/2008 7:32:21 PM
Ron Olson
Status: online
Try taking your idle speed up if it doesn't want to keep running. A fatter needle will need more as the lean needle will want to idle faster.
_____________________________
Member, Southwest Michigan Model Boat Club.
(in reply to cwaterhunter)
       Post #: 976
RE: Aquacraft Sup... - 6/29/2008 11:35:51 PM
Jared199
Status: offline
i am having problems with my sv 27 nitro it seems to not run the same after half the tank is gone. do you know what could cause this?
thanks
(in reply to Ron Olson)
       Post #: 977
RE: Aquacraft Sup... - 6/30/2008 12:08:32 AM
d-lo
Status: offline
quote:
ORIGINAL: Jared199
thanks
make sure it's getting good water supply through the cooling system, watch for it coming out the side port as you drive by, if it's not, it could be getting hot on you.
two, make sure that the pressure line from the pipe is secure to the tank top, as the motor/tank requires pressure to supply adequate fuel.
three, try unplugging your pressure line from the pipe, pinch the fuel line off going to the carb, and blow on it. see if your cap is holding pressure. i ended up using a pop bottle cap, worked much better. i also added some gasket material to the bottom of the cap to help seal better.
four, make sure you are not too lean, come out on your high speed needle a bit, and see if it still runs hard, or 'burbles' a bit, indicating it's a little rich. i would come out until you know are too fat, then come in from there 1/8th turn at a time...... i do this EVERY time out, saves pistons don't ya know......
this is all just just my two cents....
well, you can try these things, and let us know how you fare!
davey
(in reply to Jared199)
       Post #: 978
RE: Aquacraft Supe... - 6/30/2008 12:22:53 AM
MOVMX Racer
Status: offline
quote:
ORIGINAL: sushi2me
Grimracer is right - DO NOT SWIM FOR A BOAT. It's NOT worth your life (read: drowning) no matter how strong a swimmer you are! Also there is always the possibility that the water is pollluted!
I never swim for it without my life jacket. I usually only drive it at my local lake when I go to jet-ski, so the water isn't polluted to the point of toxicity, and I always have my life vest. I still need to know the ID and OD of the stuffing tube so I can get one!
My Rc: SV27 Nitro boat, 3.3 Maxx, stock RC10B4, 5400KV 45mph RC18T, and stock Losi XXX-S.
(in reply to sushi2me)
       Post #: 979
RE: Aquacraft Sup... - 6/30/2008 12:52:25 AM
cwaterhunter
Status: offline
quote:
ORIGINAL: d-lo
quote:
ORIGINAL: Jared199
thanks
davey
yea what davey said lol,,, all good things to check.....the fuel tank cap is the cause alot of times
IF IT AIN'T FAST IT AIN'T FUN!!!!!!!!!
(in reply to d-lo)
       Post #: 980
RE: Aquacraft Supe... - 6/30/2008 1:15:12 AM
d-lo
Status: offline
quote:
ORIGINAL: MOVMX Racer
quote:
ORIGINAL: sushi2me
i am pretty sure it is 1/4" o.d. i got mine at a local hardware store, they have all sizes, and they telescope within each other. if you are not going to run the teflon liner,(i would, or place a smaller diameter piece of brass tubing to take up some of the slack in there..) this should work just fine. i have done several stuff tube mods for other boats using the supervee/vegas output shaft bushing inserted into the tubing, and it works great!!
davey
(in reply to MOVMX Racer)
       Post #: 981
RE: Aquacraft Sup... - 6/30/2008 1:27:32 AM
Jared199
Status: offline
thanks for the info on the tank i ran my boat yesterday and smoked both of my uncles boats
(in reply to d-lo)
       Post #: 982
RE: Aquacraft Sup... - 7/2/2008 5:46:56 AM
tombo001967
Status: offline
As long as I'm not the only one going thru the new boat blue's, I don't feel as bad.
I have a couple of questions for the veterans.
First of all, I have followed the break in directions and my boat will start and run pretty well. I have noticed an ocasional bog, I let off the throttle momentarily and get back in it and it runs hard again. Do you think I am to lean still?
Second, Flat out straight, the boat doesn't seem to run as hard as a slight turn to the right. I think the prop is picking up out of the water a hair and lets the engine wind out better. Should I mess with mixture, rudder angle, or both?
Other than that, It's been an absolute riot! Got my first barrel roll on Sunday! Wish I had video. Freakin' halarious.
On a side note, picked up an Aeromarine 40" catamaran off of Craigslist a couple of weeks ago. Never ran. Came with all parts, just needs to be finished. I'll post some picks when I can.
< Message edited by tombo001967 -- 7/2/2008 5:49:45 AM >
       Post #: 983
RE: Aquacraft Sup... - 7/2/2008 5:56:12 AM
Ron Olson
Status: online
Yuppers, still a little lean.
When the engines revs in the turns it's actually leaning a little and letting the prop "air out" a little. Try raising the strut a little more.
(in reply to tombo001967)
       Post #: 984
RE: Aquacraft Sup... - 7/2/2008 6:23:24 AM
tombo001967
Status: offline
Right on. Thanks Ron. I'll give it a whirl this weekend and let you know.
       Post #: 985
RE: Aquacraft Sup... - 7/3/2008 3:59:08 PM
m_tech
Status: offline
Hi guys, after your advices , now i can start my engine easly , but i have a problem maybe it is the biggest problem. when i put the boat on the water, it stops after 1-2 secs, i started the engine 5-6 times but when i push the trigger it stops. what is the problem ? Thank you for your answers
       Post #: 986
RE: Aquacraft Sup... - 7/3/2008 4:10:52 PM
cwaterhunter
Status: offline
cant just put in the water.... kinda toss it and bring up the revs first, then it should go...and it will also not go for about the 5 to 10 feet till the prop grabs,, dont over rev it..once it grabs,,,, look out then the fun begins!!!!!!!!!
(in reply to m_tech)
       Post #: 987
RE: Aquacraft Sup... - 7/3/2008 4:25:45 PM
m_tech
Status: offline
i push it to the water not toss , is tossing the boat to the water solve my problem ?
when the engine stops and i take it back , i see water in the boat , i could not find where water comes in to hull.
ok, 1- i started the engine 2 1/2 open needle , is starts easily , on the land it is running good, i throw it but not too fast ,it goes for 1-2 secs and stops , if i throw it fastly , you say problem will be solved ?
2- can we install a clutch on the engine ? i think clutch will be very useful for stabil running.
3- and the last way , i f i want a electric conversion on sv27 nitro, is it simple and how much does it cost?
thank you.
       Post #: 988
RE: Aquacraft Sup... - 7/3/2008 4:48:16 PM
cwaterhunter
Status: offline
check your needle setting... HS out at least 3. it could be to lean
