RE: Aquacraft Super-Vee 27 Nitro.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Aquacraft Super-Vee 27 Nitro.
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Aquacraft Super-Vee 27 Nitro. - 4/30/2007 9:44:11 PM
dan.revo
Status: offline
what would you say is the best. or is the best quality for $300?
_____________________________
jammin x1 crt pro with sts 30, jammin crt .5 with os 18tz, modded trophy truck team losi micro b
(in reply to Ron Olson)
       Post #: 126
RE: Aquacraft Super-Vee 27 Nitro. - 5/1/2007 4:41:02 AM
toyotatruckin
Status: offline
so far remember not having run it, this is the only RTR mono I would spend my money on.......Personal opinion the shockwave I wouldnt give 5$ new for it and the nitro hammer is a lesser boat and wont have the speed of the super Vee, stock or modified....Also might suggest adding some floatation to the cowl just in the off chance it comes off in a wreck....cowl is small wouldnt take much
< Message edited by toyotatruckin -- 5/1/2007 1:05:42 PM >
Mike
www.wrcpbc.org
(in reply to dan.revo)
       Post #: 127
RE: Aquacraft Super-Vee 27 Nitro. - 5/1/2007 6:11:54 AM
unclecrash
Status: offline
Looks sweet Mike. Put a bit of spray foam on it.
I Ain't Buildin No TuG Boats
(in reply to toyotatruckin)
       Post #: 128
RE: Aquacraft Super-Vee 27 Nitro. - 5/1/2007 1:00:14 PM
Grimracer
Status: offline
Plactic drive dog? Not at Aquacraft... Check it again.
Grim
Aquacraft Boat Designer
(in reply to unclecrash)
       Post #: 129
RE: Aquacraft Super-Vee 27 Nitro. - 5/1/2007 1:07:07 PM
toyotatruckin
Status: offline
Ok grim I modified my post, I just checked again and took my pocket knife to it, its aluminum.
Mike
www.wrcpbc.org
(in reply to Grimracer)
       Post #: 130
RE: Aquacraft Super-Vee 27 Nitro. - 5/1/2007 1:54:19 PM
Grimracer
Status: offline
It is made or steel and black oxcide coated. It also has a 45deg champhor on the leading edge.. This is good.
Thanks man.. ROCK ON
Grim
       Post #: 131
RE: Aquacraft Super-Vee 27 Nitro. - 5/1/2007 3:17:24 PM
Ron Olson
Status: offline
Mine looked like it was plastic also. It's so close to the color of the supplied prop and such a close fit, at first I thought that they were one piece!
Member, Southwest Michigan Model Boat Club.
       Post #: 132
RE: Aquacraft Super-Vee 27 Nitro. - 5/2/2007 1:39:28 AM
motorhead91
Status: offline
hey guys..just orderd red sv27 nitro and was wondering what all you recommend doing before running it....thanks
Chuck Norris Doesn't Have To Write Books. The Words Assemble Themselves In Fear.
       Post #: 133
RE: Aquacraft Super-Vee 27 Nitro. - 5/2/2007 3:37:21 AM
mistressracing
Status: offline
would this boat be a good step up from a modified aqua jet , I have a cen aquajet with upgrade prop and tuned pipe . would the sv27 nitro boat be better ??
"Gasoline is for washing parts, alcohol is for drinking and nitro is for racing."
(in reply to motorhead91)
       Post #: 134
RE: Aquacraft Super-Vee 27 Nitro. - 5/2/2007 3:58:59 AM
unclecrash
Status: offline
I think the looks alone are a true upgrade. Fantastic lookin boat. I cant say as for speed I have neither boat.
(in reply to mistressracing)
       Post #: 135
RE: Aquacraft Super-Vee 27 Nitro. - 5/2/2007 5:26:30 AM
Ron Olson
Status: offline
quote:
ORIGINAL: motorhead91
Install the batteries!
I started the carb off at 2-1/2 turns out.
There really isn't a lot to do to get it ready to hit the H2O which is kind disappointing to a tweaker.
       Post #: 136
RE: Aquacraft Super-Vee 27 Nitro. - 5/2/2007 2:15:42 PM
Russ Williamson
Status: offline
Would suggest to just run the SV as is following the break-in guidelines for the engine. Be sure to check out the included DVD
Thereafter, make one mod at a time and test so you can experience the difference. Here are just a couple of things you can do;
Change the prop. Go with our new AQU Grim 42x55 metal prop. Info for our new metal prop line will be on www.aquacraftmodels.com website in a few days. Stay tuned
Sand the bottom of the hull
Sharpen the leading edge of the rudder
Sharpen the leading outside edge of the turn fins
Add pool noodle flotation to the interior starboard side of the hull. Keeps the hull from pointing straight up in case of a flip
Engine mod...opps, can't say those, will void the warranty.
Use a good boat fuel, 30% - 65% nitro.
Tune your metal prop; i.e., balance, sharpen, etc.
Have fun!
Russ
Russ Williamson
AquaCraft Product Manager
       Post #: 137
RE: Aquacraft Super-Vee 27 Nitro. - 5/2/2007 2:32:16 PM
Ron Olson
Status: offline
Seeing how Russ finally let the cat out of the bag, here's a link to the props that will be available: http://www.towerhobbies.com/rcwnews/070424-aqub9700.html
(in reply to Russ Williamson)
       Post #: 138
RE: Aquacraft Super-Vee 27 Nitro. - 5/2/2007 2:38:55 PM
Russ Williamson
Status: offline
Street price for the props will be about 19.99. We have also put these in clamshell packaging which doubles as a prop holder to help prevent damage while in your pit box.
Prop charts and applications, balancing and sharpening tips, etc., will be on AQU website soon. Should have these in stock before the end of this month.
More selection also coming soon....stay tuned
Rw
quote:
ORIGINAL: Ron Olson
Russ Williamson
       Post #: 139
RE: Aquacraft Super-Vee 27 Nitro. - 5/2/2007 5:50:33 PM
