RE: Aquacraft Super-Vee 27 Nitro.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Aquacraft Super-Vee 27 Nitro.
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: Aquacraft Super-Vee 27 Nitro. - 5/7/2007 4:03:36 AM
All Things Custom
Status: offline
the fuel tank on every s v 27 Ive seen has a burr on it. smooth out the burr and put a piece of neoprene in the cap........no more leaks.
Thw srtingers are very weak also. After break in I ran 2 tanks before finding this problem. 1st tank in the water, my cowl flew off?????????? it seemed loose out of the box but I trusted it. I was wrong, my other one is super tight.
I emptied the hull and reinforced the stringers and added some floatation. All is good now. A bit more weight for stability .
I dont know much about props. I wann a top speed prop ...any recomendations??????????/
(in reply to motorhead91)
       Post #: 151
RE: Aquacraft Super-Vee 27 Nitro. - 5/7/2007 4:09:15 AM
mistressracing
Status: offline
can you post any pics of the stringers and fuel tank problems , want to make sure before i have one shipped to australia
_____________________________
"Gasoline is for washing parts, alcohol is for drinking and nitro is for racing."
(in reply to All Things Custom)
       Post #: 152
RE: Aquacraft Super-Vee 27 Nitro. - 5/7/2007 4:12:32 AM
Srowe
Status: offline
Hey guys- I just ordered a Supervee Nitro and I am wondering what the difference in nitro percentages are. I know the higher the nitro the faster but is there a drawback of using more nitro? Does it have anything to do with engine longevity? and does it make a noticable difference? I just want my boat to be reliable. Thanks!
       Post #: 153
RE: Aquacraft Super-Vee 27 Nitro. - 5/7/2007 4:23:55 AM
All Things Custom
Status: offline
I just run 35 It doesnt wear out the engine parts as fast some say and some say as long as the oil content is high enough that ntro % will not affect the longevity.. A proper break in period is very important.
(in reply to Srowe)
       Post #: 154
RE: Aquacraft Super-Vee 27 Nitro. - 5/7/2007 5:10:09 AM
Ron Olson
Status: offline
One drawback of using higher nitro is that in hot, humid weather, the needle is harder to set. I rwad an interesting thread on another site that said that when you run higher nitro and the same percentages of oil that you are really adding more oil as you have to run the needle richer anyway.
I'm still working with props. I just sharpened and balanced 3 more yesterday. Jerry Dunlap is using a pitched up M-440. Right now I'm turning an X-640 with no trouble. Next I'm waiting for the Aquacraft props to come out so I can try them.
Member, Southwest Michigan Model Boat Club.
       Post #: 155
RE: Aquacraft Super-Vee 27 Nitro. - 5/7/2007 1:12:37 PM
All Things Custom
Status: offline
Thanks alot, please keep us posted with the prop selection ans the testing.
(in reply to Ron Olson)
       Post #: 156
RE: Aquacraft Super-Vee 27 Nitro. - 5/7/2007 4:35:47 PM
Ron Olson
Status: offline
I think that this is the one that Grimmie says to use on this boat: http://www2.towerhobbies.com/cgi-bin/wti0001p.pgm?&P=PR&I=AQUB9720 , and hey, we've got an up close and personal shot of it!
       Post #: 157
RE: Aquacraft Super-Vee 27 Nitro. - 5/7/2007 6:37:57 PM
motorhead91
Status: offline
does it need sharpened or is that done already?
Chuck Norris Doesn't Have To Write Books. The Words Assemble Themselves In Fear.
       Post #: 158
RE: Aquacraft Super-Vee 27 Nitro. - 5/7/2007 6:45:45 PM
Russ Williamson
Status: offline
You will be able to bolt our props on and go, but sharpening and fine balancing is recommended for best performance. Soon we will have a full set of sharpening and balancing instructions on www.aquacraftmodels.com website.
Rw
quote:
ORIGINAL: motorhead91
Russ Williamson
AquaCraft Product Manager
       Post #: 159
RE: Aquacraft Super-Vee 27 Nitro. - 5/8/2007 1:47:36 AM
motorhead91
Status: offline
what are the speed gains and stability like with these props?
(in reply to Russ Williamson)
       Post #: 160
RE: Aquacraft Super-Vee 27 Nitro. - 5/8/2007 6:45:27 AM
Jerry Dunlap
Status: offline
Replacing the 3 bladed prop that comes with the boat with the M440 provided 5 mph on the radar gun. I had to bend the ride plates down to keep the boat from bouncing.
I have not had an opportunity to try any the the Grim Props yet.
JD
       Post #: 161
RE: Aquacraft Super-Vee 27 Nitro. - 5/8/2007 5:59:40 PM
All Things Custom
Status: offline
please keep us posted thanks alot
(in reply to Jerry Dunlap)
       Post #: 162
RE: Aquacraft Super-Vee 27 Nitro. - 5/8/2007 11:16:43 PM
motorhead91
Status: offline
what exactly do lifter props do? i saw those and didnt know if they would be good to have also....
and also....what are some good cf props....thanks
< Message edited by motorhead91 -- 5/8/2007 11:18:14 PM >
       Post #: 163
RE: Aquacraft Super-Vee 27 Nitro. - 5/9/2007 12:57:13 AM
Jerry Dunlap
Status: offline
A "Lifter" prop is commonly used on hydroplanes.
JD
       Post #: 164
RE: Aquacraft Super-Vee 27 Nitro. - 5/9/2007 1:04:50 AM
Flettis1
Status: offline
The cap on the fuel tank really sucks. Fuel readily spills out even when cranked down super tight. Having problems acheiving WOT...maybe because of fuel tank. Does anyone have the same issue...I looked for the
