pcomm1
CA, USA Status: offline
quote:
ORIGINAL: wackywheelz quote:
ORIGINAL: pcomm1 Hi Wack, HL mirrored Tamiya's first generation DMD gear boxes. Your showing Tamiya's 2nd generation gearboxes, all and all still close enough. For your own good get those eyes checked. Seriously. pcomm1, see an eye doctor Your basis for saying HL copied Tamiya's original gearbox is pretty weak, is because its setout like every other tank gearbox ever. If you honestly believe this is the case, then I rest my case - you checklist must be "has gears, must be copied". Just like "its a Tiger as well, must be copied". The fact no parts are interchangeable between brands pretty much sums up the rest of this. Wacky, let me help you here with the concept. The HL gear box "design" is a Tamiya knock-off, your images and observations illustrate the facts perfectly. Intellectual property concepts in the USA cover inventions and designs used in commerce. A knock-off "design" is illegal in the USA, of course, not so much in China, at least not yet.
_____________________________
Tamiya 1/16 Jagdpanther, Panther G, Pz4 J, Tiger IE, Sherman & DAK Kubelwagen and 2 parallel world HLs
