OV-10 Bronco 81"
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> OV-10 Bronco 81"
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
OV-10 Bronco 81" - 3/19/2003 8:24:05 AM
Johng
Status: offline
Good Lord! I already have more planes than I can keep operating/ build/ stay current on/ afford, but I really want one of these Especially the fiberglass parts. Sheesh.
I gotta win the lottery and retire to the shop.
BTW - I found the web site for Bob Sealy, Quality Fiberglass. No mention of the OV-10, but definitely may be worth a call or e-mail.
http://www.ucrcs.com/quality.htm
BTW- The guy shows what looks to be a really nice C-130 glass kit that goes for $350, shipped
_____________________________
John
(in reply to halflight)
       Post #: 26
OV-10 Bronco 81" - 3/19/2003 3:39:25 PM
Sarah
Status: offline
Thanks for the information about the board size Drifter, I have seen a building board which is 48" by 18" will that be large enough?
Also thanks for the picture picture of the retracts, Drifter.
Regards,
Sarah
       Post #: 27
bronco wing - 3/19/2003 7:30:04 PM
drifter
Status: offline
The Bronco wing panel is 15" cord by 40.5" span. A 48"x18" board will work. The two wing panels are then joined on something long enough to maintain accurate alignment. The nacelle is about 38" long.
       Post #: 28
OV-10 Bronco 81" - 3/19/2003 7:33:27 PM
Sarah
Status: offline
Hi Drifter,
Many thanks for your help.
Sarah
       Post #: 29
OV-10 Bronco 81" - 3/20/2003 8:15:35 AM
Fili
Status: offline
Hey Drifter Man, did the spring air retracts come with all the goodies? You know.....valve, fittings,tubing?
       Post #: 30
Bronco cockpit kit! - 4/9/2003 9:06:47 AM
rcwarbirdman
Status: offline
Hey guys, if you're looking to scale up the cockpit, then Dynamic Balsa will be releasing their cockpit kit for the Bronco. I don't know exactly when, but they tell me that it'll be around $100.
Dean
http://www.dbalsa.com/index.html
       Post #: 31
OV-10 Bronco 81" - 4/9/2003 10:41:58 AM
Sky-jacker
Status: offline
Hey Guys,
I have the RU plans but have not started yet. I did scratch one from three views that I got from North American in 1974.
60" span, two OS 40s, 11.5 pounds.
Articulated gear as per full scale and electric retracts,and flaps.
BTW there is a LONG NOSED version and the nose gear retracts forward to be scale.
Good Luck
GEORGE
       Post #: 32
OV-10 Bronco 81" - 4/9/2003 6:41:48 PM
Fili
Status: offline
Great! I'm glad to hear some one is coming out with a cockpit kit. I searched a quite a few web sites on the OV-10 and could find any useful pictures of the cockpit area. A few side views, but nothing I could really use to build my own. Howz everyones progress on their Bronco?
Phil
CORSAIR Brotherhood #20
       Post #: 33
OV-10 Bronco - 4/9/2003 9:07:50 PM
halflight
Status: offline
Just finished covering...decided to go patrotic..corsair blue with red and white. Weather here lousy right now,waiting for nice, warm, calm, spring day for that first flight. Using two OS-61fx for power. I'll try to send a photo in the near future.
       Post #: 34
progress - 4/9/2003 9:30:57 PM
drifter
Status: offline
Getting ready to glass the wing.
Click to see fullsize image.
Click for fullsize
       Post #: 35
Elevator question? - 4/9/2003 9:35:42 PM
rcwarbirdman
Status: offline
Hey guys, did you use 2 servos (and 2 linkages in the booms) to operate the elevator, or just one? Also, how many receivers did you use? I'm thinking of putting one in the wing, and one in cockpit. I will only remove the centre cockpit for travel and storage.
Thanks, Dean.
       Post #: 36
OV-10 Bronco 81" - 4/9/2003 10:04:40 PM
Fili
Status: offline
Two servos,(and pushrods) definately. Even though one might do the job, two will help eliminate flutter. I'm even gonna go for more powerful servos, maybe 70+oz torque for all flight controls. I plan on using one RX with a 6v 1100+maH batt. I found scale and semi-scale retracts at Precision and Century jet but they're not cheap. Robart couldn't be bothered to answer my email whether or not they had something I could use.
Right now I have all componants framed and mostly sheeted. I'm now waiting for epoxy to cure on a few strenghtening modifications I made on the wing, then I can finish sheeting.
Very soon I will have to order the plastics, and choose what retracts I want to use ($$$)
Thanks for the photos and sharing your input and Ideas. Lets have a Bronco flyinn! (If spring ever comes)
Phil
       Post #: 37
Elevator control - 4/9/2003 11:27:28 PM
drifter
Status: offline
I've got two Hitec (s-77's I think) low profile servos mounted in the upper fins. I didn't trust the four bellcrank system suggested on the plans. Too much opportunity for slop and binding.
The Fiberglass fins are wider than the same fins done in balsa and allow servo mounting.
I'm using two receivers, each driving seven servos. Each has a 1100 mah battery pack.
       Post #: 38
OV-10 Bronco 81" - 4/10/2003 2:09:41 AM
SteveD-RCU
Status: offline
Where can I order Uravitchs plans and stuff,I know Ive seen his ads and a review or something I just cant remember which mag ..SteveD
