Spad + paintball = ???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Spad + paintball = ???
Page: [1] 2   next >   >>
Login
Spad + paintball = ??? - 4/4/2007 11:55:41 PM
Flying freak
Status: offline
Well the title bascially says it all how would a spad make out after a round of beeeing shot at with a paintball gun, Thinking about doing somthign like this for a funfly to get the public involved. Also what plane would you recomend for this task, looking to power with an OS .40 LA...
Thanx for any and all input...
       Post #: 1
RE: Spad + paintball = ??? - 4/5/2007 1:33:22 AM
acam37
Status: offline
Debonair
(in reply to Flying freak)
       Post #: 2
RE: Spad + paintball = ??? - 4/5/2007 1:50:08 AM
Flying freak
Status: offline
oo ok i was thinking somehitng more along the lines of a dagger...or denominator (denominator without landing gear...)
(in reply to acam37)
       Post #: 3
RE: Spad + paintball = ??? - 4/5/2007 2:19:02 PM
Flying freak
Status: offline
=How much materiel do i actally need? will a 48" by 48" piece of 4mil be enough....??
       Post #: 4
RE: Spad + paintball = ??? - 4/5/2007 3:04:32 PM
Deadeye
Status: offline
You want something that will slow down. Shooting a plane while flying sounds easy, but take my word, it is not. 3 years ago our club did this to raise money. I flew the plane, and out of the 300 or so shots shot at my plane, only 2 hit. This was low slow flyby's less than 40 feet in front of the shooter, and less than 10 feet high.
_____________________________
Randy Rossmiller, proud husband of Terrorist Hunter www.shannenrossmiller.com
       Post #: 5
RE: Spad + paintball = ??? - 4/5/2007 3:43:00 PM
Flying freak
Status: offline
how much damage did those 2 shots create? and what did they hit ??
(in reply to Deadeye)
       Post #: 6
RE: Spad + paintball = ??? - 4/5/2007 6:13:58 PM
I.C.O.N.
Status: offline
I have been dreaming of this for two years! I was calling the game SPLADBALL.
Glad I am not the only one. I have two 40's around and a ton of coro.
I was thinking of a wing maybe 36" or so. Would be quick and easy to build a few and should make a good target.
I was thinking of the motor and elects to be mounted to a thin piece of ply run the length of the wing to both stiffin it up and be detatchable when the wing gets damaged.. then just screw on a new one. Wieght wo't matter cuz like Deadeye said it needs to go slow anyway. Just has to fly.
THAT'S IT, gonna do it!
Have Fun!
Andy
       Post #: 7
RE: Spad + paintball = ??? - 4/5/2007 6:56:09 PM
Flying freak
Status: offline
post pics once you get the spadbal project going...
(in reply to I.C.O.N.)
       Post #: 8
RE: Spad + paintball = ??? - 4/6/2007 1:05:35 AM
Deadeye
Status: offline
quote:
ORIGINAL: Flying freak
One shot hit the fuse, and we didn't even notice it until it landed, no damage, just goo. The other went through the sign vinyl wingtip cover on one side and made more of amess inside the wing than anything. Wiped it up, new vinyl, done. The guns we used weren't all that powerful, maybe middle of the road as far as paintball guns go.
       Post #: 9
RE: Spad + paintball = ??? - 4/6/2007 2:11:05 AM
Flying freak
Status: offline
So if i understand correctly if we were to use the same caliber guns we have nothign to worry about if the plane gets bombarded with paintballs and it wont desintagraqte when it gets hit thats good news...
       Post #: 10
RE: Spad + paintball = ??? - 4/6/2007 3:46:28 AM
Nogyro
Status: offline
Use a SPA3D and harrier it around 2 to 10 feet off the ground. Nice and slow.... big wing to hit, and if it gets knocked down, just crank it up and go again. Sounds like a hoot!
Frank
       Post #: 11
RE: Spad + paintball = ??? - 4/6/2007 7:05:44 AM
Deadeye
Status: offline
quote:
ORIGINAL: Nogyro
Now that is a good route to go. A fellow club member had one with a Saito 72 a few years ago. Never thought about the SPA3D. Easy to hit, easy to fix.
(in reply to Nogyro)
       Post #: 12
RE: Spad + paintball = ??? - 4/6/2007 12:06:05 PM
Flying freak
Status: offline
would you build some sort of protectiv "box" for he servos and rx?
       Post #: 13
RE: Spad + paintball = ??? - 4/6/2007 12:51:33 PM
Clean
Status: offline
Nope, tuck the receiver under the wing flap, the servos are on the top where they won't get hit and the battery won't even notice it.
SPAD3D, good idea.
From Somewhere near Parkville, Mo.
William Crane (aka Mr Clean) Rever Brother #168 Time Man of the Year
       Post #: 14
RE: Spad + paintball = ??? - 4/6/2007 1:17:40 PM
Nogyro
Status: offline
quote:
ORIGINAL: Clean
I had one with the Saito 72 on it for a while, then switched back to the TT-46. The .46 is lighter and faster spool ups, but the Saito sure did sound nice putt-putt around a foot off the ground.
Great idea on putting the receiver under the wing flap for protection. With the other servos in the aluminum frame, they'll be protected by the profile fuselage.
Click to see fullsize image.
Click for fullsize
< Message edited by Nogyro -- 4/6/2007 1:20:45 PM >
Frank
(in reply to Clean)
