Which engine should i use?
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  9/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> Which engine should i use?
Page: [1]
Login
Which engine should i use? - 4/5/2007 4:59:02 AM
raflyer
Status: offline
Hello,
I have the new Top Flite Cessna 310 which calls for 2 OS 46ax's. In actual test, these small engines have shown to be more than enough power and fly it well at 1/2 throttle.
I was thinking of using either 2 58cd's w/11x8 prop or 2 60sp's w/14 or 15" 3-blade prop. Which would you suggest and what props?
Rob
       Post #: 1
RE: Which engine should i use? - 4/5/2007 10:20:20 AM
RCV Engines
Status: offline
Hello Rob
We would suggest that you use 2x58 CD as we have had
good feedback from this application. 11x7 would be a better choice of prop.
Regards
Ray
_____________________________
Technical Support
RCV Engines - UK
(in reply to raflyer)
       Post #: 2
RE: Which engine should i use? - 4/5/2007 1:23:55 PM
raflyer
Status: offline
Thank you!
quote:
ORIGINAL: RCV Engines
Hello Rob
Regards
Ray
(in reply to RCV Engines)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.266RCU1
