mavdriver
CA, USA Status: offline
Hi the -11 and + 11 is only used when you are in idle 1 or 2 , it sounds to me like you had the heli set at -11 +11 in normal flight mode , this is why your heli came down hard , in normal flight mode you should have the heli set mechanically i fly DX7 so this an example how my pitch is set at , Low -2 , ( 1 )+1.5 ,( 2 ) 0.0 , ( 3 )+ 6 , High +11 how ever if your a newb , i would recommend this settings , Low -2 , ( 1 ) + 2 , ( 2 ) + 5 , ( 3 )+ 6 or + 7 , High +10 or 11 remember you must have pitch gage when you do this , if you don`t know how to use a pitch gage get some help from an experience heli pilot , as far as getting parts try WWW. RC Hover .com they just posted that they got a bunch V2 parts on there web site , hope that helps . Ed
