Tony Bonetti's Troublemaker Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> Tony Bonetti's Troublemaker Build Thread
Page: [1] 2 3 4 5   next >   >>
Login
Tony Bonetti's Troublemaker Build Thread - 4/6/2007 4:36:38 AM
dave_anderson
Status: offline
Hi All!
Just spent about an hour on the phone with Don Turnock of Eureka Aircraft discussing the short kits he sells. I told him my goals for a vintage pattern ship and he told me the Troublemaker EXT (extended version) would be the ticket. I have some experience with foam wings so I opted for the taildragger/foam wing/foam stab kit. My intention is to put retracts and a piped .61 on it, but haven't ruled out SPA since I'm moving to Florida next year... so the retracts and pipes may get nixed. Or I could hook up with the BPA guys and....GAME ON!
I should have the kit in about a week, and progress won't begin right away, but I wanted to start the thread so anyone with Troublemaker pictures or experience could chime in while we wait for me to get started.
Should be a fun build by the sounds of it. I've got quite a lot of IMAC kit building experience, but this will be my first small pattern ship and I'm really looking forward to a fun build.
Please post any pictures you may have of the Troublemaker or bestow your knowledge!
Click to see fullsize image.
Click for fullsize
< Message edited by dave_anderson -- 5/23/2007 11:07:17 PM >
       Post #: 1
RE: Eureka Aircraft Troublemaker Build Thread - 4/7/2007 9:32:39 PM
Skip
Status: offline
I have the Troublemaker short kit from Eureka. I bought it for SPA competition and when I looked at the size of the plane I determined that it wasn't really suitable for a .91 four stroke. It's a fairly small plane. I was going to extend the fuse even more but what it really needs is more wing and a wider fuse. I will be selling the short kit next week. I believe a modern .46 would be all the plane needs to fly well. I don't like noisy two-strokes so I won't build it. I really wish either the SPA would allow more planes into the stable because it is next to impossible to get what I really want. ie: Compensator, Phoenix etc. I will be curious to see how you make out with the kit. Keep us informed with text and pix. It should be a good flying plane but it's just too small for me. Good luck. Skip
_____________________________
Highly skilled at at hiding new kits from wife ( Or so I thought)!!
(in reply to dave_anderson)
       Post #: 2
RE: Eureka Aircraft Troublemaker Build Thread - 4/7/2007 10:13:57 PM
dave_anderson
Status: offline
Skip,
Was yours the EXT version? It's like 3.5" longer and adds 5" or so to the wing span.
Dave
(in reply to Skip)
       Post #: 3
RE: Eureka Aircraft Troublemaker Build Thread - 4/8/2007 12:19:50 PM
Skip
Status: offline
Yes, it was the extended version.
       Post #: 4
RE: Eureka Aircraft Troublemaker Build Thread - 4/8/2007 6:21:27 PM
jeide
Status: offline
Hi. Does the Troublemaker quailify for Vintage pattern? It has to be designed pre 1970. Thanks, Jim
(in reply to Skip)
       Post #: 5
RE: Eureka Aircraft Troublemaker Build Thread - 4/8/2007 6:42:32 PM
Skip
Status: offline
I thought it was 1975
(in reply to jeide)
       Post #: 6
RE: Eureka Aircraft Troublemaker Build Thread - 4/8/2007 7:02:00 PM
dave_anderson
Status: offline
LEGAL AIRPLANE LIST
1965 THRU 1975
A-6 INTRUDER (Kirkland) A-6 INTRUDER (Airborne Models)
ACCUSTAR ATLAS
AVANTI AVENGER
BANSHEE BELLAIRE
BLUE ANGEL CAJUN QUEEN
CALIFORNIAN CENTURY
CHECKMATE II COMPENSATOR
CONTENDER COLD DUCK
CURARE CRUSADER
CUTLASS DADDY RABBIT I THRU IX
DECEPTION
DIRTY BIRDY DON JUAN II
DRAGIN FLY EIGHT BALL
EL GRINGO EPITOME
EQUALIZER (Curtis Motes) EYEBALL
FANTASY (Small) FIREBIRD
FIRE FLY FLEA FLY
GLADIATOR HI – LO
HOT PANTS HUMMING BIRD
INVICTUS II KAOS
KAOS (Direct Connection) KILLER KAOS I THRU IV
KWIK FLY TAPER WING
KWIK-OS (Howard Engineering) ALL ARF
KING ALTAIR LIBERY BELL
LANIER LECTRA
L’OISEAU VIRGINIAN
MACH I & II MAGIC DRAGON
MAGNUM 600 MISS FLORIDA
MORRIS HF MR. ED
MR. SLICK MURA
NEW ORLEANEAN NUCLEON
NUTCRACKER OMEN
PANTERA PEGASUS
PHANTOM I PHOENIX I THRU VIII
PINK PANTHER PUFFIN II
PULSAR BIPE QUICK FLY
RAMPAGE RCM EXPERT
RETARDED SIG KOUGAR
SKEETER SEQUEL
SPEAR SO-LOSTARFIRE
STAR TREK SUPERFECTION
SUN FLY (ALL) SUPER SICROLY
SUPER FLY
SUPER DUCK SUPER SKEETER
SUPER KAOS SWEETATER
SWEEPER T-BIRD
T2A (Mk I only) TEXAS TWISTER
TEXAN TIGRE NUT
THREE PERFECTION TRITON
THUNDER PANZER WARLOCK
TIGER TAIL TRION
TRIGON TROUBLE MAKER
TRILPLE TROUBLE UNDONE II
TWISTER (RCM) UTTER KAOS
UTOPIA VULCAN
(in reply to Skip)
       Post #: 7
RE: Eureka Aircraft Troublemaker Build Thread - 4/8/2007 7:42:49 PM
8178
Status: offline
quote:
ORIGINAL: Skip
I have the Troublemaker short kit from Eureka. I bought it for SPA competition and when I looked at the size of the plane I determined that it wasn't really suitable for a .91 four stroke. It's a fairly small plane. I was going to extend the fuse even more but what it really needs is more wing and a wider fuse. I will be selling the short kit next week. Skip
Is the ability to use an OS 91 4S is becoming the defacto standard for selecting what airframe will work for SPA? I hope that is not the case because it would eliminate a lot of wonderful designs that were designed around a 61 2S.
(in reply to Skip)
       Post #: 8
RE: Eureka Aircraft Troublemaker Build Thread - 4/8/2007 10:05:12 PM
Skip
Status: offline
You can use any engine you want up to a 91 four stroke. With these old designs which were set up for .60 two-strokes there is a real "squeeze" factor. Also many of the old designs carry lead in the tail to balance the plane. I can't see any reason not to use a smaller engine. If I had suitable engine I would build the Troublemaker. It's about time a really good stick wins with the smaller setup. It would set a good precedent and make more kits useable.
(in reply to 8178)
       Post #: 9
RE: Eureka Aircraft Troublemaker Build Thread - 4/9/2007 2:09:57 AM
kr9x
Status: offline
I have the Troublemaker EXT as well and have started and stopped building on it, work keeps getting in the way! I plan to drop in a Rossi 60 in the nose and see what happens. I hope I can place the servos in the tail to help balance everything out. I'm very sure I will have no problem with CG.
Jon
SPA 261
(in reply to Skip)
       Post #: 10
RE: Eureka Aircraft Troublemaker Build Thread - 4/9/2007 2:55:10 AM
rainedave
Status: online
Yep, there are a lot of SPA designs that cry for a light 2-stroke. I'm gaining interest in the new OS AX .55 and might have to buy one soon. It weighs 14.25oz and is rated at 1.75hp/16,000rpm. That sound a lot like some those older, small-case sixties to me. The problem is it's b*** ugly:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNMD1&P=ML
(in reply to kr9x)
       Post #: 11
RE: Eureka Aircraft Troublemaker Build Thread - 4/9/2007 3:14:01 AM
eness76-RCU
Status: offline
The K&B Twister .61 is right in there weight wise too, and is really supposed to crank. Even can be had with a tuned muffler.
(in reply to rainedave)
       Post #: 12
RE: Eureka Aircraft Troublemaker Build Thread - 4/9/2007 2:43:04 PM
bob27s
Status: offline
Ive had contact from one modeler who is building the Troublemaker, and will be installing a SJ-60Lx up front. I will try to coax him to posting in this forum. And/or I will post what ever info I can as I get it.
Bob
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
       Post #: 13
RE: Eureka Aircraft Troublemaker Build Thread - 4/9/2007 5:06:23 PM
Lotus72D
Status: offline
quote:
ORIGINAL: jeide
VRCS pattern requires pre-1970 airplanes; the SPA allows up to 1975. Technically both promote "vintage" pattern so I can see where there could be confusion over what's legal when the generic "vintage pattern" term is used.
The Troublemaker is legal for SPA, not legal for VRCS. VRCS is primarily an organization dedicated to celebrating the old designs...the pattern events are very informal and low key.
(in reply to jeide)
       Post #: 14
RE: Eureka Aircraft Troublemaker Build Thread - 4/10/2007 12:30:57 AM
