RE: The Ofiicial Thunder Tiger Ducati 999 & Desmosedici
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Motorcycles >> RE: The Ofiicial Thunder Tiger Ducati 999 & Desmosedici
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmosedici - 10/22/2007 10:30:54 PM
nothinbetr2do
Status: offline
thanks about the video, that was just a tuning run. but still fun. and yes i'm still running the stock tires, i'm not having any problems with them, and i don't race(wouldn't know where to go). so there fine for me. hope your enjoying your bike
_____________________________
just say no to "shelf queens"
(in reply to 2002denali)
       Post #: 51
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmosedici - 10/24/2007 2:53:29 PM
2002denali
Status: offline
Just ordered new tires and rims along with the tuned pipe.Should be here in the next couple of days.I can get my bike to turn good but with some better tires I'm hoping to get it to hook up alot better.It doesn't matter what kind of vehicle your running tires are always the first thing you need to figure out.Once you find the right tire combination then it's time to move on to other things.I have done alot of experimenting to get the bike to handle better and now it's time to get some good tires.The bike works a whole lot better than it did when it came out of the box but still not where it needs to be.In bone stock form it really sucked compared to where it is now.
(in reply to nothinbetr2do)
       Post #: 52
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmose... - 10/27/2007 6:38:37 AM
2002denali
Status: offline
Parts came today.Mounted and installed tires and rims also put on the pipe.Man does it sound good.Spools up real nice but of course it's pouring rain out.Looking forward to seeing the difference with new tires and the pipe.
       Post #: 53
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmose... - 11/15/2007 11:33:01 AM
Coopz
Status: offline
So are the bikes recomendable?
I have the option of buying a near new one off a mate. Would just be for carpark bashing. Is the front brake really needed and are they hard to work on?
HB Lightning Pro, Mach .21
HN X1 CRT Pro, Sportwerks Chaos, 30cc FS Baja
       Post #: 54
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmose... - 11/15/2007 2:14:54 PM
2002denali
Status: offline
They are a blast.I don't find them hard to work on but they do have a number of things that need to be done to make them realiable.I have the front brake and would say it's a deffinite advantage to have but not a must have option.I would recomend one to anyone with previous nitro experience.If inexperienced I would suggest an electric version.
(in reply to Coopz)
       Post #: 55
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmose... - 12/29/2007 6:56:15 PM
heartofmadnes
Status: offline
I got balistic on mine and added a Trax 2.5 motor to it...Im still fine tuning the top in, at this point if you punch it. when it starts to top out it may bog at peak rpm...I love the bike but they are a pain in the butt working on
Click to see fullsize image.
Click for fullsize
You had me at Hover...
       Post #: 56
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmose... - 1/7/2008 10:58:25 PM
bigairlife
Status: offline
Must be REALLY fast... Fast, but i'm not a fan of traxxas motors
LST2 (converted from aftershock) ~ Savage 25 basher ~ Muggy w/ Mach 427 teal ~ Xray m18t Carpet racer
(in reply to heartofmadnes)
       Post #: 57
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmosedici - 1/20/2008 6:04:27 PM
harleychris95
Status: offline
does anyone know of an electric conversion on the thunder tigre ducati 999. ive had enough with the nitro. would like to try brushless. My neighbours are tired of the noise. i already own the nitro version. i dont want to spend the cash on the electric version. to then convert it to brushless. any info would be great help!
(in reply to bikeracer)
       Post #: 58
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmose... - 1/21/2008 4:39:05 AM
Jeremy1976
Status: offline
quote:
ORIGINAL: heartofmadnes
You are too lean on the H needle that is a lean bog you are experiencing. Fatten up the H needle a 1/4 turn or more.
       Post #: 59
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmose... - 1/31/2008 11:20:46 PM
heartofmadnes
Status: offline
I know, I added a 2 speed set up to the bike and the gearing is different I just havent had time to tune it, to busy messing with my 8th scale trucks
(in reply to Jeremy1976)
       Post #: 60
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmose... - 2/2/2008 3:28:53 AM
bigairlife
Status: offline
Where did you get a 2 speed setup for it?
       Post #: 61
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmose... - 3/9/2008 11:10:27 PM
flynte
Status: offline
Finally got mine. Upgraded radio and servos and battery. Added front brake. Just waiting for some lots to dry up (snow melting) to take it for a test spin. Got the intigy back shock for it and it's a good 1/2" taller than the stock. Did you guys build an extension mount for it? or just installed like is. It puts the swing arm at quite the angle as is.
flynte
MAAC 79035
(in reply to bigairlife)
       Post #: 62
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmose... - 3/15/2008 11:57:36 PM
whitham69
Status: offline
put a limiter inside the shock to get the height you wont
(in reply to flynte)
       Post #: 63
RE: The Ofiicial Thunder Tiger Ducati 999 & Desmose... - 3/18/2008 4:46:56 AM
linkadrip
Status: offline
My neighbor gave me this today dont know much about it. Never messed with motorcycles plenty of cars trucks helis and Planes. It seems to work has some weird Bars on the side to prevent it from falling over i guess was wondering if it can be run without the bars on it it needs alot of work. things are loose and the front shocks Dont seem to work right. but Seems to be pretty Cool from what i can tell so far. Am i in the right thread?
I'm not real certain this is the same bike theres nothing on it except Ducati Testastrerra Sticker on the red fairing Has a duratrax radio in it and Jr racing servo for the steering. charged the battery up and ran it around the house a little seems like it will go fast. Has reverse. Wouldnt mind fixing it up and making it look better its looks like it has been beat on quite a bit. But i want to make sure i have the right motorcycle before i go buying the wrong stuff to fix it up.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
TwisT 150 Bro 12
AMA 888111 Club Saito 572
(in reply to whitham69)
       Post #: 64
