RE: KMP Stuka-build details    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: KMP Stuka-build details
Page: <<   < prev  32 33 [34] 35 36 37 38 39 40 41   next >   >>
Login
RE: KMP Stuka-build details - 12/24/2010 4:59 PM
irocbsa
Score: 110
Last Login: 5/24/2013
Status: offline
Alan, it's good to hear that you stock extra parts. I wish the distributors here in the US would do that. I made some mistakes when assembling my Stuka and had some rough landings as well. A few things got dinged up and I'm unable to get spare parts. Wheel pants (terribly manufactured IMHO) and exhaust stacks are impossible to come by and no one seems to be able to get them. If you have any in stock I would be interested in ordering them from you.
Hide Signatures
(in reply to alanc)
       Post #: 826
RE: KMP Stuka-build details - 12/26/2010 9:32 AM
kwik
Score: 105
Status: offline
quote:
ORIGINAL: irocbsa
That is my problem as well. The distributors in Norway. Didnt occur to me to contact YT in the UK.
Hide Signatures
(in reply to irocbsa)
       Post #: 827
RE: KMP Stuka-build details - 12/30/2010 8:42 AM
kwik
Score: 105
Status: offline
Here is the siren I bought for my Stuka;
A so called Wolo Mighty Mo ;
http://www.buyautotruckaccessories.com/product.cfm/cf-bin/pn.wolo-mighty-mo-motor-siren/
It is quite small, weights 170 grams, and produce a very powerful sound.
It has a motor that turns some kind of a fan,and sounds very close to the stuka-sound, a continous sound.
Funny how that "fan" can produce such a powerful siren-sound.
A Lipo 11.1 Volts seems to drive it quite well.
I plan to put it in the middle of the center-section, pointing downwards. Noone will notice the hole for it, I think.
Hide Signatures
(in reply to kwik)
       Post #: 828
RE: KMP Stuka-build details - 1/2/2011 1:24 PM
Andrew_S
Score: 110
Last Login: 6/30/2012
Status: offline
Hey Kwik, so how is she flying? I'd love to hear the siren in action......I;m thinking of going electric on mine. I'm still having aerovate engine issues. I know absolutely nothing about electrics. Any ideas on what I need to get?
_____________________________
What do heli''''''''s and ceiling fans have in common? When the blades stop turnin, You start sweatin ! ! !
Hide Signatures
(in reply to kwik)
       Post #: 829
RE: KMP Stuka-build details - 1/2/2011 8:26 PM
SunShyne
Score: 120
Last Login: 5/17/2013
Status: offline
would love to see a video of the siren in action
Revver Bro #86
Visit RCU''s E-flight Only Website: www.WattFlyer.com
Hide Signatures
(in reply to Andrew_S)
       Post #: 830
RE: KMP Stuka-build details - 1/2/2011 9:10 PM
kwik
Score: 105
Status: offline
Andrew, Sunshyne,
I promise I will make a video of a bomb-run with the siren in action. Hopefully we will hear it !
I guess a video of it on the ground is of no interest.
The stuka is ready to go with its new engine. But I need good wheather in the weekend. It is dark when I get home from work.....
Andrew, the 26 cc class (and thereabout) petrol engines often has a smaller carb than the larger ones.
It seems to me the quality of these smaller carbs isnt allways so good ? I had a Roto-25, and had to buy 2 carbs ,
so it didnt run properly until I installed the 3'rd carb. Very annoying.
Electrics?
I think the safest route is to copy a setup that works for a similar sized plane.
Copy the setup of motor, controller, propeller and batteries. From someone who has tested it in flight.
Otherwise you can easily be "burned". I have, and it doesnt feel good.
Hide Signatures
(in reply to SunShyne)
       Post #: 831
RE: KMP Stuka-build details - 1/8/2011 3:56 PM
AIRPLANENUTS
Score: 105
Last Login: 5/23/2013
Status: offline
Kwik, based on your post, I just ordered one of those sirens. I've requested a .wav file from Wolo, and if they send it, I'll post it.
"Futaba gets it right the first time."
Hide Signatures
(in reply to kwik)
       Post #: 832
RE: KMP Stuka-build details - 1/8/2011 4:42 PM
kwik
Score: 105
Status: offline
Okay, Airplanenuts. I sure hope it is loud enough when the plane gets up there. Everything is different then.
I might get a test-flight tomorrow. But the wheather-forecast is changing daily now, so we will see.
Hide Signatures
(in reply to AIRPLANENUTS)
       Post #: 833
RE: KMP Stuka-build details - 1/8/2011 4:54 PM
irocbsa
Score: 110
Status: offline
The Aerovate (RCGF) engines have a junk carb on them as delivered. I started a thread in the gas engine section that documents the troubles that so many people have had with these carbs. It's mandatory that they be replaced with a genuine Walbro unit if you ever want them to run right.
Hide Signatures
(in reply to kwik)
       Post #: 834
RE: KMP Stuka-build details - 1/9/2011 4:42 AM
AIRPLANENUTS
Score: 105
Status: offline
Good luck Kwik!
Hide Signatures
       Post #: 835
RE: KMP Stuka-build details - 1/9/2011 9:30 AM
kwik
Score: 105
Status: offline
Thanks Airplanenuts! There is no sun today, even though they said it would be 2 days ago.
So they cannot forecast 2 days, but they think they can forcast the climate 100 years from now.
Go figure.
Andrew, here is a building thread where Sean McHale tells us about his electric setup;
http://www.rcscalebuilder.com/forum/forum_posts.asp?TID=16070&PN=0&TPN=6
Hide Signatures
       Post #: 836
RE: KMP Stuka-build details - 1/9/2011 9:39 AM
TA152
Score: 105
Last Login: 5/20/2013
Status: offline
It's snowing lightly here now Kwik. But nice temperature -4,5 degrees.
Ta152C. The ultimate Warbird!
Hide Signatures
(in reply to kwik)
       Post #: 837
RE: KMP Stuka-build details - 1/9/2011 1:57 PM
kwik
Score: 105
Status: offline
Okay, we didnt want to do any flying while it was snowing.
The airlfield is 30 minutes drive from my home, it didnt snow here, so instead I did a little test outside.
At full speed the engine noise overpower the siren somewhat.
But when you are in a dive you are likely to throttle back anyway, so I think we will hear it;
Here;
http://www.youtube.com/watch?v=NTbj6xJCjWM
Hide Signatures
(in reply to TA152)
       Post #: 838
RE: KMP Stuka-build details - 1/9/2011 5:07 PM
AIRPLANENUTS
Score: 105
Status: offline
Kwik, that's awesome! Have you already posted info and pics of the siren setup? If not, I would love to know how you set your system up. Thanks for the video. I can't wait to get the siren in and get it installed in my Stuka.
Rick
Hide Signatures
(in reply to kwik)
       Post #: 839
RE: KMP Stuka-build details - 1/11/2011 3:26 AM
canadian8apilot
Score: 100
Last Login: 3/30/2013
Status: offline
I just got my KMP stuka yesterday, looks ok, been looking through the thread and found lots of good info here.
The ARF looks pretty good, and a 32cc gasser will find itès way under the hood. The cockpit is a bit cheesy, and the hardwear is about what I expected...crappy...but once I am done my current project, a scrach built DO28 skyservant of my own design, http://www.rccanada.ca/rccforum/showthread.php?t=73418 I'll get going on the stuka..
Bill
Hide Signatures
       Post #: 840
RE: KMP Stuka-build details - 1/11/2011 1:04 PM
irocbsa
Score: 110
Status: offline
Nice job kwik! If we could find a way to ramp up the volume and pitch a bit slower it would sound really good.
Hide Signatures
(in reply to canadian8apilot)
       Post #: 841
RE: KMP Stuka-build details - 1/13/2011 1:50 PM
fa18frog
Score: 100
Last Login: 4/17/2013
Status: offline
irocbsa,
I noticed in a post that you were going to mount a DLE-30 in your Stuka. I have a DLE-30 and wondering if it will fit in the Stuka and what exhaust system you used to fit it under the cowl.
Hide Signatures
       Post #: 842
RE: KMP Stuka-build details - 1/13/2011 3:26 PM
irocbsa
Score: 110
Status: offline
I'll paraphrase what I sent you in a PM here for everyone else'e benefit.
I would not recommend putting a gas engine in this plane at all unless its configured like the Saito FG or the Evo engines. The "standard shape" rear carb gassers like DLE/RCGF/CRRC/etc. require way too many modifications to fit in the cowl without having to hack it to pieces. If you don't mind having to cut a large section out of the side of the cowl for the exhaust then you will have no problem using a gas engine. However, if you want to maintain a more scale appearance you're going to have to custom fab a muffler assembly. I was able to do this since I have access to guys at work that can weld aluminum and we were able to constuct my design for no charge. If you can't weld aluminum or don't have access to those resources at a cheap cost you're not going to be able to find an off the shelf muffler that will fit within the cowl. I have spent way too much time building and fabbing and not nearly enough time flying because I went with a gasser. If I had to do it all over again, I would use a large four stroke glow engine. This is just my humble opinion based on my personal experience. Hopefully it can save someone else the trouble.
< Message edited by irocbsa -- 1/22/2011 5:57 PM >
Hide Signatures
       Post #: 843
RE: KMP Stuka-build details - 1/14/2011 1:59 AM
canadian8apilot
Score: 100
Status: offline
Welding and Fab'ing is not an issue, I have a spool gun, and access to a TIG welder, and I like a bit of a challenge.
I built a pitts style muffler with smoke coils for one of me dl50's and other than being a bit heavyer than a costome unit, works just fine.
That being said, I am told that Andrew has a muffler that will fit in the cowl for the 32cc gasser.
Bill
Hide Signatures
       Post #: 844
RE: KMP Stuka-build details - 1/14/2011 6:51 AM
frank99
Score: 100
Last Login: 5/12/2013
Status: offline
man iam not sure which sound the best the fg or the siren , all time fav german war bird, have a old royal .60 hanger queen never got a engine , and want one of the big ones, can i come over and see it fly thanks frank
Hide Signatures
(in reply to kwik)
       Post #: 845
RE: KMP Stuka-build details - 1/16/2011 7:23 PM
kwik
Score: 105
Status: offline
Folks, the wheather is against us here in Norway nowadays. Last weekend it was snow. This weekend it was snow and fog.
On working days it is often sun and nice wheather.The clouds are back friday evening, and the sun is back monday morning.
So, no flying, no video. ( Just some parkzone fun with Hartmanns 109 )
I have a couple of pics of the installation, though. As you can see I accepted a big hole underneath.
I am into practical scale, not high level scale. not many will notice that hole.
About ramping up the level.....maybe a big, say 4700 microfarad capacitor would do the trick.....
Dont forget that during a dive and flyby we will probably get the doppler effect helping us....
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to frank99)
       Post #: 846
RE: KMP Stuka-build details - 1/22/2011 5:30 PM
kwik
Score: 105
Status: offline
Finally a video with the siren in the air. Turn up the volume;
http://www.youtube.com/watch?v=TcQflHxaMXc
Hide Signatures
(in reply to kwik)
       Post #: 847
RE: KMP Stuka-build details - 1/22/2011 6:05 PM
irocbsa
Score: 110
Status: offline
That's fantastic kwik! Next time you go out, try to get into a dive by rolling her upside down and pulling back on the elevator. If you do it directly over the field it should look great. Here's a video to help describe what I'm talking about.
http://www.youtube.com/watch?v=k-qK5gbvCXI
Hide Signatures
(in reply to kwik)
       Post #: 848
RE: KMP Stuka-build details - 1/25/2011 11:27 PM
canadian8apilot
Score: 100
Status: offline
Just having a look at the stuka, and noticed there are only 2 servo hatches in the wing for the aleron servo's and none for the flap servo (as shown in the instructions) and none of the holes for the alerons and flaps line up with the hinge points. Also there are no places cut for the inboard flap hinges.
Is this a common issue, or am I just lucky?
Bill
Hide Signatures
       Post #: 849
RE: KMP Stuka-build details - 1/26/2011 2:07 AM
Andrew_S
Score: 110
Status: offline
the flap servos are covered by the coverig, u should be able to see where they go. Use an axcto knife. u have to drill for the hinges.the hles that are there were factory paint holes...
Hide Signatures
       Post #: 850
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.484RCU1
