RE: KMP Stuka-build details    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: KMP Stuka-build details
Page: <<   < prev  32 33 34 [35] 36 37 38 39 40 41   next >   >>
Login
RE: KMP Stuka-build details - 1/26/2011 2:27 AM
canadian8apilot
Score: 100
Last Login: 3/30/2013
Status: offline
thanks Andrew, but not seeing any holes for the flap servo`s...must have forgot to cut them for me
I drilled the alerons and flaps, but there are no slots for the hinges in the center section...and I'm just getting started...
Bill
Hide Signatures
(in reply to Andrew_S)
       Post #: 851
RE: KMP Stuka-build details - 1/26/2011 3:40 AM
Andrew_S
Score: 110
Last Login: 6/30/2012
Status: offline
they should be under the covering. U should be able to feel them under there. u have to cut the slots for the hinges too.
_____________________________
What do heli''''''''s and ceiling fans have in common? When the blades stop turnin, You start sweatin ! ! !
Hide Signatures
(in reply to canadian8apilot)
       Post #: 852
RE: KMP Stuka-build details - 1/29/2011 5:31 AM
AIRPLANENUTS
Score: 105
Last Login: 5/23/2013
Status: offline
Kwik, the siren is terrific! Very audible. What is your voltage source?
Rick
"Futaba gets it right the first time."
Hide Signatures
       Post #: 853
RE: KMP Stuka-build details - 1/29/2011 11:05 AM
kwik
Score: 105
Last Login: 5/24/2013
Status: offline
Hello Rick. Yes the siren works very well.
I am using a 3S Lipo at the moment. After the last flight I forgot to turn it off. The battery switch, that is. After a week it was discharget trough the LED in the switch, and was destroyed. As you know, a LiPo cell is destroyed if you allow it to go below 2.5Volts. This happened to me.
So I will use two A123 batteries in the future. That will give me 6.6 x 2 Volts.
Hide Signatures
(in reply to AIRPLANENUTS)
       Post #: 854
RE: KMP Stuka-build details - 1/31/2011 11:12 AM
Andrew_S
Score: 110
Status: offline
Bill, did u find the flap hatches? mine are to the inboard left side of the crosses on the bottom of the wing... Kwik that siren does sound good.....
Hide Signatures
(in reply to kwik)
       Post #: 855
RE: KMP Stuka-build details - 3/22/2011 12:19 AM
Black Drape
Score: 100
Last Login: 5/25/2013
Status: offline
Hey Guys
I just got this model from Thomas. None of the hinge holes are drilled in my ailerons or flaps. How are you drilling the holes without coming through the surface of the parts?
Is anyone still using the aerovate engines, and how are they holding up?
Ron
Hide Signatures
       Post #: 856
RE: KMP Stuka-build details - 3/22/2011 12:28 AM
canadian8apilot
Score: 100
Status: offline
Found the flap servo bays.
I was just out in the garage machining a set of stand-off's for the Aerovate 32 I plan to hang on the front of the Stuka, need to make a shorter set, 1 7/8" long.
Glad I have a lathe in the garage, handy for that kind of thing.
Bill
Hide Signatures
(in reply to Black Drape)
       Post #: 857
RE: KMP Stuka-build details - 4/19/2011 9:49 PM
maourit
Score: 100
Last Login: 7/3/2012
Status: offline
 Hello,
With a weight of 7.6 kg excluding fuel on my Stuka B, the engine purchased (saito 115)  would be sufficient?  If no, is it absolutely necessary to get an other one like Saito 150 or 180? think it's limits but requests your advice.
Thank you
Hide Signatures
(in reply to tdbeltz)
       Post #: 858
RE: KMP Stuka-build details - 4/29/2011 5:03 PM
Firepower R/C
Score: 110
Last Login: 5/16/2013
Status: offline
Good work on the Siren, Kwik... I have an idea about that Wolo siren. I would like to use an ESC (might have to install a different motor) in conjunction with the rate control feature of my Hitec Aurora TX to control the spooling up & down of the siren. I am hoping that I can reverse the channel controlling the siren (ESC) and mix it to the throttle stick, while using a switch to arm the mix. Hopefully, that will evenly spool up the siren as I throttle down & roll over into the dive to deploy the bomb, and then back down as I add in throttle after the pullout. It just might make that siren sound a little better. Any thoughts? I have already started massing the parts for this
Firepower R/C
Saving un-loved R/C airplanes around the world
Hide Signatures
(in reply to maourit)
       Post #: 859
RE: KMP Stuka-build details - 4/29/2011 7:05 PM
kwik
Score: 105
Status: offline
Firepower;
Letting an ESC run the motor should work? Cannot see any reason why not.
Next, whether the Aurora TX mix idea will work, I really dont know. It sounds like you want a reversal of throttle input?
Minimum throttle gives maximum siren speed, and opposite? Cannot see why it shouldnt work, either.
So, go ahead, experiment! That is the fun part, if you ask me!
By the way, the ramp up-down....I wonder.....it could be that a big juicy capacitor on , say, 4700 microfarad in parallell with the
motor would work too.....??
Maourit :
I friend of mine used a Saito 180. It was a perfect fit. Cannot answer for the other engines. But the Saito 180 drinks fuel so fast you
wouldnt believe it. So if you consider buying a Saito 180, I think I would consider a Saito FG 30 too. Its a petrol engine, and can
run forever on a tank.
Hide Signatures
(in reply to Firepower R/C)
       Post #: 860
RE: KMP Stuka-build details - 4/29/2011 10:49 PM
Firepower R/C
Score: 110
Status: offline
I second the fuel-drinking capabilities of the Saito 1.80... nice, nice engine, but you will be buying fuel for it by the case
Firepower R/C
Hide Signatures
(in reply to kwik)
       Post #: 861
RE: KMP Stuka-build details - 5/18/2011 12:58 AM
canadian8apilot
Score: 100
Status: offline
well I got sick of waiting for a muffler, so I built one from brass, copper and steel all silver soldered together and it fits inside the cowl.
Any thoughts or recomendations as to what prop to use on a 32cc gasser?
Bill
Hide Signatures
       Post #: 862
RE: KMP Stuka-build details - 5/18/2011 6:03 AM
Andrew_S
Score: 110
Status: offline
some where in the 20-20 pitvh range...which engine? lets see some pics....
Hide Signatures
       Post #: 863
RE: KMP Stuka-build details - 5/18/2011 12:55 PM
irocbsa
Score: 110
Status: offline
I'm swinging an 16 X 10 three blade on my DLE30 (I would go bigger but three blade props start getting really expensive above 16"). Are you using a two blade?
Hide Signatures
       Post #: 864
RE: KMP Stuka-build details - 6/5/2011 12:48 AM
kahloq
Score: 125
Status: online
I had a saito 150 in mine spinning a 15x8 3 blade prop and had way more then enough power to fly.
Hide Signatures
(in reply to irocbsa)
       Post #: 865
RE: KMP Stuka-build details - 1/22/2012 8:04 AM
maneba
Score: 100
Last Login: 5/19/2013
Status: offline
Hi, this is my Stuka.
I've got the B model to use a dle 30 engine.
This kit are not very ARTF, there is a lot to work to finish it.
Hide Signatures
(in reply to kahloq)
       Post #: 866
RE: KMP Stuka-build details - 1/28/2012 9:12 AM
Prekin
Score: 101
Status: offline
Hi,
I am building ESM Stuka D, I have engine DLE 30 and I try to do cockpit myself. I´ve just done instrument panel and now I´m doing rear guns MG 81Z. Because the tail wheel was bad I did new one and also new main gear with springs.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to maneba)
       Post #: 867
RE: KMP Stuka-build details - 1/28/2012 9:26 AM
Prekin
Score: 101
Status: offline
Hi Maneba,
It looks nice, but I am little bit afraid of the strength the front part, because when you did the holes behind the engine, you maybe disturb the structure. This fibreglass is not very strong and vibrations behind the engine are very big. Do you have some silent blocks (anti shock system) on the engine base?
Hide Signatures
       Post #: 868
RE: KMP Stuka-build details - 1/28/2012 10:18 AM
Prekin
Score: 101
Status: offline
Here are my exhausts. I made it from epoxy.
Does any know if it is necessary to add any lead, when I use DLE 30?
Click for fullsize
Hide Signatures
(in reply to Prekin)
       Post #: 869
RE: KMP Stuka-build details - 1/29/2012 4:46 AM
Sharpeye22
Score: 120
Status: offline
Prekin,
Could you post a pic of the other side of your engine. I would like see how you did your throttle servo setup.
Larry
Saito Club #692
Hide Signatures
       Post #: 870
RE: KMP Stuka-build details - 1/29/2012 9:12 AM
kwik
Score: 105
Status: offline
I had to enforce the whole area in front of the cockpit by laying up a layer of fiberglass at the inside.
Used finishing resing. It sticks very well to the fuse's inside.
Had extra lot close to the firewall. Soaked the firewall area real good.
Before that, with a G-28 the whole front moved around at least one cm amplitude on idle.
It looked like the pilot had Parkinson, or something.
The 30 cc line of planes from ESM is designed for 4-stroke glow engines, me thinks. Not 2 stroke gassers.
The 50cc Corsair is stiff enough up front from the factory. Dont forget locktite on ALL screws and bolts.
Espesially on servos with metal gears. And ditch all plastic ARF stuff regarding horns and clevis'es.
Hide Signatures
(in reply to Sharpeye22)
       Post #: 871
RE: KMP Stuka-build details - 1/29/2012 10:46 AM
Prekin
Score: 101
Status: offline
Here is the other side of my engine. I added some picture of the origin engine base. I cut it and made new one which I put together with fuselage by layer of the fibreglass. Inside the fuselage behind the engine will be the ignition.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 872
RE: KMP Stuka-build details - 2/2/2012 9:52 PM
maneba
Score: 100
Status: offline
quote:
ORIGINAL: Prekin
Hi Maneba,
Hi Prekin. I've added a lot of carbon fiber and carbon sticks behind the new firewall. No silent block for me. The dle30 is very long and i've no space to move it more back. I hope to have no problems with vibrations, otherwise i'll install a 1.80 Asp 4T engine. I've just ordered a new cowl and a new canopy. The original canopy got damaged during trimming. It's to brittle...
Hide Signatures
       Post #: 873
RE: KMP Stuka-build details - 2/3/2012 2:04 AM
flyingpiggy
Score: 100
Last Login: 5/22/2013
Status: offline
I have the ASP 180 4 stroke in mine and it flies well. Yes I agree that the canopy is too brittle. I will add some bracing inside the canopy frame area as the canopy is prone to damage if you flip it over upon landing.
Regards
Dave Read
Sooo many models, such little time
Hide Signatures
       Post #: 874
RE: KMP Stuka-build details - 2/3/2012 2:57 AM
irocbsa
Score: 110
Status: offline
Great work from everyone!
Prekin, your setup is very similiar to mine. I have a DLE30 on my D model with a scratch built cockpit as well. My plane came in at 18lbs and flies great with the 30 up front. It takes off in about 50 feet and has tons of climbing power. Plus, it floats in for landings. It's really a great flying plane.
Regarding your question about balancing weight, my plane needed 3oz of tail weight to balance.
< Message edited by irocbsa -- 2/3/2012 2:39 PM >
Hide Signatures
(in reply to flyingpiggy)
       Post #: 875
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.937RCU1
