f4you
OH, USA Status: offline
Hi Neo. Any of the 3.2 CI (52cc) engines will do what you want. I've flown the Quaddra 52, Fox 3.2, FPE 3.2, and a Sachs 3.2 on that size plane all with excellent results. A 19 X 11N Mejzlik 3 bladed prop will turn right at the typical max rating on those engines, and fly the plane in just the way you describe. With this engine size, you'll be able to throttle back a bunch at cruise, giving you a LOT of extra flying time. I could fly for 18 minutes easily, and have reserve left over (32 ounce tank). Throw in a few full throttle passes/manuvers during that time!! Haven't operated a G-62, but have heard and seen other folks fly similar sized planes with them with very good results, also. In my case, a Top Flite giant scale corsair at 27 pounds, and a Byron Corsair at about the same weight, size.
_____________________________
"It's only a flesh wound"
