RE: How to convert an ATX power supply to rc use    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> RE: How to convert an ATX power supply to rc use
Page: <<   < prev  7 8 9 10 11 12 13 14 [15] 16   next >   >>
Login
RE: How to convert an ATX power supply to rc use - 4/9/2012 6:05 PM
ImpalaPolicePack
Score: 116
Last Login: 2/24/2013
Status: offline
im charging 5s and 6s 5000mah packs at 7amps. i know its not 1c but i dont care if the packs does not last as long since they are cheap to buy.
i tought that i was only pulling 7amps, why is it more because of a 5s pack ?
anyway, like you said, the ps should handle it...
_____________________________
My worst nightmare is that after I die, my wife sells all my RC stuff for what I told her I paid for it.
Hide Signatures
(in reply to bgosselin)
       Post #: 351
RE: How to convert an ATX power supply to rc use - 4/9/2012 9:19 PM
bgosselin
Score: 150
Last Login: 11/24/2012
Status: offline
quote:
ORIGINAL: ImpalaPolicePack
Ready for a bit of math?
Charging a 5s pack at 7A requires up to 147w of power (4.2v/cell * 5cells * 7amps). Since the charger is not 100% efficient (typically around 80%), add in another 20% of power for 176.4w. That is the power the charger will pull from the power supply. Since the PS outputs 12v, the power supply will need to supply 14.7A (176.4w/12v).
Charging a 6s pack at 7A requires up to 176.4w of power (4.2v/cell * 6cells * 7amps). Again, to account for efficiency losses, add in another 20% for 211.68w. At 12v PS output, it has to supply 17.64A of current.
I say "up to X watts" because the most power a charger will have to output is just before the battery reaches 4.2v per cell and so is still in the CC phase of the charge. Before and after that point, the actual power required is a little less, but we always want to use worst-case to figure things like this.
http://scriptasylum.com/rc_speed/
Hide Signatures
(in reply to ImpalaPolicePack)
       Post #: 352
RE: How to convert an ATX power supply to rc use - 4/9/2012 9:50 PM
Andrew
Score: 105
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: bgosselin
.............Charging a 6s pack at 7A requires up to 176.4w of power (4.2v/cell * 6cells * 7amps). Again, to account for efficiency losses, add in another 20% for 211.68w. At 12v PS output, it has to supply 17.64A of current.
And it gets worse! Your current demands appear to be loading the supply causing a voltage sag which in turn increases the current load. Using bgosselin's calculations of 211 watts, by the time your voltage has fallen to 10.5v, current requirements are over 20 amps.
Thermaltake claims efficiencies over 80%, even higher if you're on 230v mains (voltage setting on back). What does the spec placard list for 12V1 and 12V2 amperage and wattage - there are several models that are rated at 500W.
Drop your charge rate to 1C and try again.
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
Hide Signatures
       Post #: 353
RE: How to convert an ATX power supply to rc use - 4/10/2012 2:29 AM
ImpalaPolicePack
Score: 116
Status: offline
bgossellin, wow thanks for the precise explanation. this make sense but the PS should still be enough...
here is a couple pics i took tonight.
the 3 yellow wires, were actually 3 ''bundles'' but to make things easier i de-soldered all 3 and re-soldered 1 single bigger guage wire.
i used the small brown, with one orange for the ''stay on'' but i took any orange, is it supposed to be one in particular ?
andrew, im pluged in 110v main supply. no acces to 220v. i bought this PS to allow me to charge at a faster rate lol, i dont really want to drop to 1c.
look at my pictures to see the info your looking for (not sure what you want)
thanks again for helping me out, this is driving me crazy...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Andrew)
       Post #: 354
RE: How to convert an ATX power supply to rc use - 4/10/2012 2:33 AM
ImpalaPolicePack
Score: 116
Status: offline
2 others
edit : ''all grounds from the same bundle'' are used as negative with the +12v.
should i use ALL grounds from ALL bundles ?
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 355
RE: How to convert an ATX power supply to rc use - 4/10/2012 3:35 AM
bgosselin
Score: 150
Status: offline
Thanks for the pics. Couple points I want to mention though:
1) The two heatsinks doesn't necessarily mean two rails. Actually usually one heatsink is for the AC mains side switching section (FETs, bridge rectifier, etc), the other heatsink (closer to the output wires) is for the output FETs and associated components.
2) To really see how many 12v rails there are, you'd have to pull out the PCB and follow the traces. Even though there are 3 sections, they could simply be tied together via copper traces underneath. However, there are three coils/caps per output wire, but that could just be paralleled/split to help handle the high currents without using larger (and more expensive) components. Again, a peek at the traces (especially before the coils) would tell you more.
3) All the grounds are the same point. Typically, I use the same amount of grounds as the yellow wires. So, if I bundle 6 yellows together, I'd also bundle 6 blacks together. Since all grounds go to the same point, it doesn't matter which ones you use - there are no separate 5v, 3.3v, and 12v grounds.
It is odd that the PCB has three 12v outputs labeled, but specifies only two on the outer case label.
I probably should go look at the ATX spec, but I assume the red/brown connection consists of the 5v line and the 5v sense wire tied together?
Hide Signatures
       Post #: 356
RE: How to convert an ATX power supply to rc use - 4/10/2012 4:05 AM
ImpalaPolicePack
Score: 116
Status: offline
yes for the sense wire with the 5v, all grounds are the same, so i can rule this out.
i will remove the board from the case and try to follow the traces, but even if i find that there is 1,2 or 3 rails, it should not matter to why it can't keep its voltage under load ?
Hide Signatures
       Post #: 357
RE: How to convert an ATX power supply to rc use - 4/10/2012 4:49 AM
Andrew
Score: 105
Status: offline
quote:
ORIGINAL: bgosselin
I agree WRT to the three 12v outputs.
I think he meant orange/brown for his 3.3v to sense wire connection.
On your motherboard connector, do you have any pins other than orange that have a second wire? Most supplies have only a 3.3v sense wire, but I have seen a few that have sense wires for other rails.
the "other" andrew
Hide Signatures
       Post #: 358
RE: How to convert an ATX power supply to rc use - 4/10/2012 7:17 PM
ImpalaPolicePack
Score: 116
Status: offline
i only have the small brown wire in the same spot as an orange wire.
all other wires are alone in there spots.
does my brown wire needs to be with the SAME orange wire it was on the connector ? because i didnt labeled them before i cutted the connectors off. so its paired with any orange wire i found...
Hide Signatures
       Post #: 359
RE: How to convert an ATX power supply to rc use - 4/10/2012 8:45 PM
Andrew
Score: 105
Status: offline
No, what you have done is fine. With only a 3.3v sense wire, that eliminates one part of the puzzle.
It would really be useful if you would try a charge cycle on your 5s cell starting around .8C . According to the specification placard, your supply certainly has the capacity to carry a higher rate, but obviously it is sagging under the load. If it runs at .8C without a significant voltage drop, then up the rate. If it won't carry a .8C rate, you may have a faulty supply. I must confess that I'm running out of options here; maybe bgosselin has a suggestion that can help out.
andrew
the "other" andrew
Hide Signatures
       Post #: 360
RE: How to convert an ATX power supply to rc use - 4/11/2012 2:49 AM
ImpalaPolicePack
Score: 116
Status: offline
thanks for your support, i will try tomorow morning a .8c charge rate and see what it will do.
thanks again !
Hide Signatures
       Post #: 361
RE: How to convert an ATX power supply to rc use - 4/11/2012 2:35 PM
bgosselin
Score: 150
Status: offline
quote:
ORIGINAL: Andrew
I'm out of ideas as well...
Hide Signatures
       Post #: 362
RE: How to convert an ATX power supply to rc use - 7/3/2012 8:13 AM
SirNoob89
Score: 100
Last Login: 7/21/2012
Status: offline
Hi Guys,
I Am converting my old PSU and have 4 1Ohm 10W Resistors and want to know if they should be hooked up in 4s or 2s2p. With 4s i get under 12.1v when i turn it on but that drops to 11.5v when i try to charge. The charger dose not give an error but I have not let it run for more then a min or so. Have not tried 2s2p yet as I don't know how many Watts each resistor will get like this.
Hide Signatures
       Post #: 363
RE: How to convert an ATX power supply to rc use - 7/3/2012 1:32 PM
Red Scholefield
Score: 191
Last Login: 7/13/2012
Status: offline
Connect them all in parallel. This should give you a better output voltage. Collectively they will draw about 2 amps which is 10 watts total.
Red S "AMA 951 since 1958
Hide Signatures
(in reply to SirNoob89)
       Post #: 364
RE: How to convert an ATX power supply to rc use - 7/3/2012 3:38 PM
bgosselin
Score: 150
Status: offline
quote:
ORIGINAL: Red Scholefield
That was probably a typo (?), but hooking all four 1ohm resistors in parallel will equate to 0.25ohm, which will draw 20A from the 5v line and generate 100w.
Personally, I'd start by putting just two or three of those 1ohm resistors in series (2ohm or 3ohm total). The more current you draw from the 5v line, the more stable the 12v line will be, but you are wasting more power as heat.
[EDIT] Now that I re-read it Red, you probably thought he had four 10 ohm resistors...
Hide Signatures
(in reply to Red Scholefield)
       Post #: 365
RE: How to convert an ATX power supply to rc use - 7/3/2012 4:09 PM
Andrew
Score: 105
Status: offline
quote:
ORIGINAL: bgosselin
Even though he stated that his resistors were 1 ohm, it's possible that he intended to write 10 ohms. At 4s, I would think that a 4 ohm load would have been sufficient to hold his 12v rail above 11.5v when attached to his charger; 40 ohms would likely not be enough to prevent sagging out.
Perhaps we can get a clarification on the actual resistance.
the "other" andrew
Hide Signatures
       Post #: 366
RE: How to convert an ATX power supply to rc use - 7/3/2012 5:04 PM
bgosselin
Score: 150
Status: offline
Yeah, that's possible too. Either way, I wasn't trying to pick on Red or anything, just trying to prevent SirNoob from doing something incorrectly. Hopefully, he reposts the actual value. What a difference a simple 0 can make!
Hide Signatures
       Post #: 367
RE: How to convert an ATX power supply to rc use - 7/3/2012 6:23 PM
Andrew
Score: 105
Status: offline
quote:
ORIGINAL: bgosselin
Amen to that.
the "other" andrew
Hide Signatures
       Post #: 368
RE: How to convert an ATX power supply to rc use - 7/4/2012 12:58 AM
SirNoob89
Score: 100
Status: offline
They are 1ohm 10w just double checked.
Could it be that this cheap multi meter is showing the wrong value?
Without any resistors the charger just displays an error saying incorrect input voltage.
I have an extra 4 1ohm resistors if that would help me get a better voltage.
Hide Signatures
       Post #: 369
RE: How to convert an ATX power supply to rc use - 8/1/2012 10:52 AM
jam398
Score: 100
Last Login: 8/2/2012
Status: offline
Hi All ! I have done my power supply by simple way , and I can get 12.5 w/o load 12.16 w/load , I can charge 4 battery in one time using one quate charger in 5A without any problem , and the resistor I place it on a piece of big alu heatsince , running for 3 to 4 hours and warm only not hot not cool , our country weather now is very hot , about 31-34c , after I test it for over and over charge all my battery from two cell to four cell , no problem at all , but don know if charge up to six cell lipo , so  what I want now is to install the volt and amp meter on it , so that can see all the time , but problem is I don know how to wirie them up , can any body teach me how to do it , tks .
jim
Hide Signatures
       Post #: 370
RE: How to convert an ATX power supply to rc use - 8/1/2012 1:42 PM
jam398
Score: 100
Status: offline
Hi Again , forget to tell my power supply spec , mine one is
Enermax 350w
+3.3v 32a
+5v 32a
+12v 26a
Use 10ohm 10watt resistor on the 5v side and attach on a piece of big alu heatsince , size is 16cm x 10cm x 4.5cm without fan .
Supply power w/o load 12.3v  amp unknown not measure yet , but soon .
Supply power w/load 12.15v  watt unknown not measure yet , do it soon .
The charger that I use is HK quattro 4 x 6 200 watts
50 watts per ch
I charge all my battery from 7.4 to 11.1v without trouble and power keep on steady and normal , no over heating no burning resistor , everything work just find .
But I need someone to teach me how to install the amp meter and volt meter , so that I don have to use the test meter everytime , hope someone can give a helping hand . tks
Hide Signatures
(in reply to jam398)
       Post #: 371
RE: How to convert an ATX power supply to rc use - 8/1/2012 6:14 PM
bgosselin
Score: 150
Status: offline
Not sure about your specific charger, but many have a built-in voltmeter that will show you the voltage of the power supply feeding it. If so, you don't really need one on the supply itself unless you want it for other hookups.
But to answer your question:
A voltmeter is wired in parallel with the 12v output wires. So take the positive lead of the meter and hook it to the +12v output line. Then, take the negative lead of the meter and hook it to the ground output. It looks sort of like this:
POWERSUPPLY(+) ======== OUTPUT_CONNECTOR(+) ===== (+)
                                               VOLT_METER
POWERSUPPLY(-) ======== OUTPUT_CONNECTOR(-) ===== (-)
An amp meter needs to be wired in series with the output. This is very important! This means you have to "break" the positive connection from the power supply wire to the output connector and insert the meter in series. Hard to explain, but it looks like this:
POWERSUPPLY(+) ===== (+)AMP_METER(-) ===== OUTPUT_CONNECTOR(+)
POWERSUPPLY(-) =========================== OUTPUT_CONNECTOR(-)
To wire both up at the same time, do this:
POWERSUPPLY(+) ===== (+)AMP_METER(-) ===== OUTPUT_CONNECTOR(+) ===== (+)
        VOLT_METER
POWERSUPPLY(-) =========================== OUTPUT_CONNECTOR(-) ===== (-)
Hide Signatures
       Post #: 372
RE: How to convert an ATX power supply to rc use - 8/1/2012 10:15 PM
Andrew
Score: 105
Status: offline
Nothing to add on wiring in your meters - bgosselin's diagrams are spot on.
Make sure your voltmeter is classified as DC. Some ampmeters are listed as AC or DC; some as DC only. Also ensure your ampmeter has a capacity greater than the amperage you anticipate drawing while charging. Since your 12v rail is rated at 26A, the minimum size I would suggest would be a 30A meter. If you select one with too high a capacity, the scale will be very broad and you will not be able to get a real accurate reading.
If the amp meter requires a shunt, be sure that it's included with the meter or order one when you get the meter itself. Some may indicate that a shunt is included or built in.
the "other" andrew
Hide Signatures
       Post #: 373
RE: How to convert an ATX power supply to rc use - 8/2/2012 5:44 AM
jam398
Score: 100
Status: offline
Hi Guy's ! Thanks for the info , will try it soon when get the volt and amp meter , thank you x 2
jim
Hide Signatures
       Post #: 374
RE: How to convert an ATX power supply to rc use - 10/8/2012 2:28 PM
Propworn
Score: 193
Last Login: 6/18/2013
Status: offline
Looking for discription and wiring diagram for wiring two in series for 24 volt 40 amp for 6S and up. I have two server power supplies at 12.5 volts and 47 amp and would like to wire these in series for the higher voltage.
Dennis
Hide Signatures
       Post #: 375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
