RE: How to convert an ATX power supply to rc use
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> RE: How to convert an ATX power supply to rc use
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: How to convert an ATX power supply to rc use - 10/10/2007 9:00:33 AM
mrasmm
Status: offline
quote:
ORIGINAL: Savage03
Just put a load on it with 2 resistors and its showing 12.11v, good grief more?
looks like you put them in series, that should make your voltage go down, run them in parallel and it should make it go up =)
The higher you are above 12v the better you are because chargers run more efficient at higher voltages, which basically means less heat in the charger. As long as you are above 12v though for most chargers you will be good to go =)
As far as amp draw check out the ammeter in your dmm, those are usually rated to 10A, and mine measures about 18 to 20 before the fuse blows =P (shh I didn't tell you that)
_____________________________
I don't always check every thread I respond to, so feel free to PM me
(in reply to Savage03)
       Post #: 51
RE: How to convert an ATX power supply to rc use - 10/10/2007 9:02:47 AM
mrasmm
Status: offline
quote:
ORIGINAL: NM Bob
Hey Guys, I need some help-I'm making a DC power sourse from a computer power supply. I have read all types of helpfull info and have even done this before but this time I got a Dell power supply ( circa 2000) and I can't figure out which wire I need for on/off function. This model of PS does not follow the industry standards so I don't know what colors to use. Anyone out there have experience with an old Dell?
sounds like that other guy has got you taken care of, but you could also match the wire colors to the molex conntectors, take some readings, and also you could match the 20 pin mobo power connector
that's taken off of this site
http://www.marcee.org/Articles/PCPowerSupply.htm
That's how I ended up doing mine. I jsut cut off the mobo connector and made sure to leave about an inch or two of the color coding in the mobo connector, then make sure to reverse it because you are looking at it from the top instead of the connector side =)
(in reply to NM Bob)
       Post #: 52
RE: How to convert an ATX power supply to rc use - 10/10/2007 9:26:37 AM
Savage03
Status: offline
quote:
ORIGINAL: mrasmm
Sorry for the newbness but how do I wire them?
Tried the meter on the 10amp setting and it kicks off my PS, whats that mean? Im sure its more then capable for me, its a 650watt ps and I bought lesser PS alread coverted off a guy on another forum and I run 3 chargers off it with no probs.
< Message edited by Savage03 -- 10/10/2007 12:39:23 PM >
(in reply to mrasmm)
       Post #: 53
RE: How to convert an ATX power supply to rc use - 10/10/2007 4:07:49 PM
Andrew
Status: offline
If your DELL powersupply was manufactured between 1996 and 2000, there is a high probability that the PSU is one of the DELL proprietary supplies and that it will not conform to the INTEL Design Guide standards.
The pinouts (colors) that were used in this time frame are:
GRAY -- PS_ON (power supply on) equivalent to ATX standard GREEN. This should be switched or hardwired to GROUND.
BLACK -- ground plane (the same as ATX black)
RED -- +5v rail (the same as ATX red)
YELLOW -- +12v rail (the same as ATX yellow)
Tie the GRAY to GROUND (BLACK) through a switch or hardwire it.
Pre-load the +5v rail with a power resistor (RED to BLACK). Use the highest ohm rating that will give you a satisfactory voltage level on the +12v rail.
Your charger connections (binding posts) will be YELLOW and BLACK.
andrew
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
       Post #: 54
RE: How to convert an ATX power supply to rc use - 10/10/2007 7:56:53 PM
Savage03
Status: offline
Ok tried this, just added extra leads off the black and red ones so basically a Y then ran each lead to the resistors, I know get 12.29 with no load and 12.22 with a 5amp load. Need more:?
(in reply to Andrew)
       Post #: 55
RE: How to convert an ATX power supply to rc use - 10/11/2007 7:40:26 AM
mrasmm
Status: offline
quote:
ORIGINAL: Savage03
sounds pretty good to me, it's all just about what you want and what you're looking for. If that's close to how many amps you'll be using max on a regular basis then I would probably say that is pretty much good =)
       Post #: 56
RE: How to convert an ATX power supply to rc use - 10/11/2007 7:51:23 AM
Savage03
Status: offline
Well if I were to wanna run anohter charger off it would it drop below 12v? To be safe I just should add another resistor? Easy enough now that I know how to do it.
       Post #: 57
RE: How to convert an ATX power supply to rc use - 10/11/2007 7:55:38 AM
mrasmm
Status: offline
I'd just find a good dummy load that is gona pull your max load on the charger (test for verification with a shunt if it's over what your ammeter is capable of, and just see what the voltage comes out to be, if it's below 11 I'd put in another resistor =) If you don't want to go to all of that, probably just put in another one =) make sure they are in parallel, because series actually adds the resistive capacities together and would go the opposite way that you are looking for
       Post #: 58
RE: How to convert an ATX power supply to rc use - 11/25/2007 7:20:09 AM
nano__
Status: offline
Where did all the pictures go?
       Post #: 59
RE: How to convert an ATX power supply to rc use - 11/29/2007 6:10:52 AM
markind
Status: offline
Mod under way
Hi guys thanks for all the great info!
My PSU is a fairly new Antec 550W and I have it running with all the un-needed wires cut short to the board, with nice banana jacks mounted in the case for 12V out, and one standard wire set with 5V and 12V available on that standard 4-pin Molex connector.
I have tested it with a 5 ohm dummy load across the 5V line, and my 10W sand bar resistor gets up to 190 deg. F. after a couple minutes.
Not a problem but the 12V out is only boosted to 12.06V under load. I was hoping to get 12.2ish.
Should I try for 3 ohm dummy load? With no dummy load, she runs just fine but only at 11.97V
I'll post up some pics when done. This one is neat and easy.
Edit:
Well I needed my 4 batteries charged so I hooked up the whole system with a DMM reading the 12V output and once the charger really got going, it drops to 11.89V
The sand bar 5 ohm resister got just under 200 deg. F. Not terrible but a bit too hot to handle.
This is boogers. I will try the 3 ohm dummy load to try to boost the 12V out.
End result: All 4 batteries went through the charge cycle fine but only 12.46V to 12.56V. I will 'top off' the packs before flying asI like to see 12.6V at launch. That's lame though. I want it right the first time!!
< Message edited by markind -- 11/30/2007 3:15:32 AM >
       Post #: 60
RE: How to convert an ATX power supply to rc use - 12/1/2007 4:18:17 AM
mrasmm
Status: offline
I think you're gona have a hard time getting an ANTEC to run much over 12v. They are very good PSU's and are very accurate, it's part of the mfg process of them. A 5 ohm load should draw about 1A, which will definitely get hot, that's about 5.3 watts TDP, and the thing is only rated for 10w at something like 220C. The way to get around this is to put them in series, so you have 2 5 ohm resistors for a total of 10 ohms, and then you can run two of those setups in parallel for a net resistance of 5 ohms and a TDP that is the same 5.3w but divided between 4 resistors, or about 1.32w each which will run alot cooler.
if you want to go to 3 ohms total, there are many ways to get there, but one single 3 ohm resistor is not gona work unless you want it to get really hot
the reason for it not getting to 12.6v is your charger rather than the PSU. make sure to balance the packs, and really anything over about 12.4 will work, the difference between 12.4 and 12.6 is only about 3 to 5% on most packs.
(in reply to markind)
       Post #: 61
RE: How to convert an ATX power supply to rc use - 2/16/2008 1:57:32 AM
rob1234
Status: offline
Guys,
I use a 32 amp computer power supply and charge 4, 6 or 8 1800mah bats at one time for my little kids traxxas rustler.
I simply use a 5 amp diode bridge on each and select whatever charge current I want with a simple door spring (This serves as a high power resistor. To turn the supply off, you just switch that one wire from ground.
I don't have pictures, I'm new here. But I may take some this weekend to post here if i have time.
It will charge 4 in about 25 min. or longer if I choose.
Never use this method and charge your bats too fast, they will not last very long if you pump 4+ amps into them. But it works very well if you charge at 2.5 or 3 amps and keep a close eye on the charging. It works just like the cheap chargers that cost $29.00.
(in reply to Hack73)
       Post #: 62
RE: How to convert an ATX power supply to rc use - 2/20/2008 5:19:03 AM
K-OS
Status: offline
Just did the mod on an Antec 400 watt power supply. When I connect the charger while the unit is on, the unit shuts down completely. However when I connect everything and THEN power on the unit it works.
Just wanted to share this info so no one does the same mistake as me (dismantle the unit 3 times and try over and over)
(in reply to rob1234)
       Post #: 63
RE: How to convert an ATX power supply to rc use - 2/20/2008 1:12:47 PM
Andrew
Status: offline
quote:
ORIGINAL: K-OS
This is a fairly common occurrence and is tied to the overload protection circuitry built into the PSU. Some chargers have fairly hefty ripple suppression capacitors built into the front end and when discharged represen
