mrasmm -> RE: How to convert an ATX power supply to rc use (2/29/2008 7:35:57 AM)
quote:
ORIGINAL: Tusken Im having a problem with my power supply shutting off when i try to charge 4s packs. The psu is out of a compaq pc and is rated 8 amps at 12v. It works fine charging 3s and im getting about 12.6v under the charge load. Does it take that much more juice to charge 4s packs? or ?? Allso I had the same problem as edwal07 on page2 ""and the 5v sense to the 5v. In this configuration I had voltage but no current. I removed the 5v sense and it latched on perfectly. "" I had 12v+ but it wouldnt power anything until i disconnected the grey and red wire. This is the charger im using if that matters. http://www.allerc.com/etecchargers.htm Thanks Rob it all depends on the conversion efficiency of your charger, but yes it will take considerable more power, about 33% more assuming a 100% efficient conversion factor. If it's a compaq PSU, it's likely not very good, infact most cheap PSU's are only good for about 50% sustained draw of what they are rated for. The simplest fix would be to just charge at a slower rate, and see how that works basically the math of it is: max voltage of 4s lipo pack is 16.8v, at 2.5A. I assume an 80% conversion efficiency, so if you do the math you end up with 16.8v x 2.5A / .8 = 52.5w required, and if you figure your PSU, you'll need basically 4.5A sustained current @12v In your case you run into a problem because your PSU probably just puts out 12v, and if you load it up around 4A, then the voltage drops below 12v, as soon as that happens your charger shuts off to prevent an undervolt that would fry it.
