RE: nitro to gas conversion (with pictures)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: nitro to gas conversion (with pictures)
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: nitro to gas conversion (with pictures) - 5/1/2007 9:36:58 AM
Mudgy
Status: offline
It's possible the tank will fail/leak at the seam, time will tell.
As carpy100 said re: silicone tubing - this is the harsh truth (so we all find out the hard way)
a fuel tank from an aeroplane/boat that runs on 2 stroke (petrol) is the best bet
My first fuel tank on the rail was from a leaf blower - this was the smallest tank in the "graveyard" of the local mower joint
Still way too big for a scale car (hence the hip flask idea)
chainsaw fuel tanks today are incorporated in the alloy casting so no luck there, either.
either way, use it till it breaks! Who knows, it just might last
good luck
(in reply to sam123)
       Post #: 76
RE: nitro to gas conversion (with pictures) - 5/1/2007 9:44:46 AM
Mudgy
Status: offline
Also forgot to mention, you are going to make it 4WD again, right?
Forget the centre diff if you are just using it on-road!
Have you EVER seen an on road car with one???
that's because under load/stress, the rear wheels will unload to the front - poor handling results
Have you seen an overpowered V one RRR for example - the rear foamies are shredded, and the fronts seem OK
Not good for tyre life, but the only way to keep it on the blacktop when cornering
If you are just going to go in straight lines, solid axle doesn't hurt the wallet
(in reply to Mudgy)
       Post #: 77
RE: nitro to gas conversion (with pictures) - 5/1/2007 10:10:12 AM
ibuildanythink
Status: offline
i been trying to get my picks up but its been inpossable coud i email them to some one to put up
thanks dan
(in reply to Mudgy)
       Post #: 78
RE: nitro to gas conversion (with pictures) - 5/1/2007 10:30:53 AM
nycballer0591
Status: offline
Wow nice work! I may consider trying this lol
Also Ibuildanythink you can email them to me
nycballer0591 at gmail dot com
< Message edited by nycballer0591 -- 5/1/2007 10:31:57 AM >
(in reply to ibuildanythink)
       Post #: 79
RE: nitro to gas conversion (with pictures) - 5/2/2007 8:05:04 AM
sam123
Status: offline
Thanks alot for your help Mudgy. I guess that some time soon I will be changing the tank, I might even use a hip flask like you did. How much do they cost?
As for the 4WD, I think I will just be making it solid shaft because it will be alot easier to fabricate. I don't really mind if the handling suffers a bit anyway because Its already good enough.
Thanks for your comment nycballer I would reccomend the swap from nitro to gas to anyone! - Just S00000 much more low down torque!
(in reply to nycballer0591)
       Post #: 80
RE: nitro to gas conversion (with pictures) - 5/2/2007 9:44:34 AM
Mudgy
Status: offline
Cheapest hip flask I could find = $20.00 Add 2 x aircraft nipple fittings (Du-Bro) or maybe you have some tuned pipe pressure fittings - same thing.
It only hols 3 Fluid ounces - about 120ml - that's all you need for drags
Maybe something that holds a little more for you??
Surely hip flasks come in different sizes
try tobacconists/junk shops - the retailers wanted too much for ones that had anything engraved on them like "jack Daniels/Harley Davidson, etc.
the days of Highway robbery are still alive and well when it comes to those kind of products
       Post #: 81
RE: nitro to gas conversion (with pictures) - 9/17/2007 2:41:23 AM
gbasile77
Status: offline
Hi Sam123,
First thing - I love your work and good to see what a fellow Aussie can do! You have given me some inspiration for the the wipper snipper motor I have sitting on the bench.
Just a couple of questions on your build -
1. What is your overall drive ratio? I know you mentioned your pinion to spur is 6.25 to one Do you feel that the gearing is good?
2. In the pics I can't see how the drive is to the diff (from the sprocket chain). How did you do this?
3. Looking at the drive front-on, which way does your engine turn?
4. How did you attach the sprocket to the clutch bell?
Sorry for so many questions, I just love your design and am hoping to build one myself.
Cheers.
(in reply to Mudgy)
       Post #: 82
RE: nitro to gas conversion (with pictures) - 9/17/2007 9:58:23 AM
Tusar
Status: offline
quote:
ORIGINAL: annie_himself
That was pretty cool. It had alot of bottom end take off looks like.
Your mom has a wierd accent.
its an Australian accent.....
_____________________________
Its not about the landing, its about how the landing is performed
(in reply to annie_himself)
       Post #: 83
RE: nitro to gas conversion (with pictures) - 10/6/2007 2:59:04 PM
sam123
Status: offline
Hi gbasile77. Sorry about the late reply, its just that I havent been on here in a while.
I found that the overall ratio of 6.25:1 is far too much if you intend on using the 1/8 buggy wheels. I have since changed the ratio to 3.6:1 and it is much better. The engine spins anticlockwise looking at it from the clutch side, like most other whipipper snipper engines (but not all of them). The clutch on this engine is like a socket spanner, the sprocket has been pressed into a nut of the right size and held inside the socket by the bearing on the end of the sprocket shaft. Drive to the diff is done simply by the chain and sprockets, nothing more. I hope this answers your questions.
Now, I would just like to let everyone know that I have done some substansial modifications to this car. Firstly I have now made it 4WD once again (yay ) but It was not as easy as I first thought. I have changed the drive ratio to 3.6:1 and also re-made all the engine/bearing mounts. This was done by changing the drive sprocket from a 6 tooth to an 11 tooth and the driven sprocket to a 12 tooth. I have made a new muffler which looks, sounds and performs great.
I have also ported the engine. I raised the exhaust port by 1.7mm and widened it each side by 1.2mm, matched the transfers to the crank case shaved 1mm off the intake side of the piston skirt for more intake duration. The result is an engine that revs much higher and produces much better mid to top end power, but uses more fuel (only slightly more though) and has lost some bottom end punch.
As of now the only things left to do are to seal the exhaust can with a better gasket (the chassis is used as the bottom half of the exhaust can to cool it down quicker), make breaks for it and stiffen up the suspension with some monster truck springs and thicker oil.
To sum things up all I can say is that this car is very, very fast. I will post some update pictures soon and definately a video. I cant wait to show you how much faster this thing is now compared to before
(in reply to Tusar)
       Post #: 84
RE: nitro to gas conversion (with pictures) - 10/6/2007 3:06:32 PM
T I G
Status: offline
Wow Sam, that really looks great. That sucker must fly.
I as well as everyone else are very excited to see some video of it in action.
Keep up the great work.
Later
Lead Follow or Get Out Of The Way
       Post #: 85
RE: nitro to gas conversion (with pictures) - 10/7/2007 12:33:32 PM
sam123
Status: offline
Here are some pictures. I will upload the rest tomorrow.
< Message edited by sam123 -- 10/7/2007 12:38:27 PM >
(in reply to T I G)
       Post #: 86
RE: nitro to gas conversion (with pictures) - 10/7/2007 4:42:55 PM
jatoracing33
Status: offline
looks slick. nice job
92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
       Post #: 87
RE: nitro to gas conversion (with pictures) - 10/8/2007 8:19:13 AM
sam123
Status: offline
Here are some pictures of the 4WD transmission.
And here is a video of the transmission setup in action:
http://www.youtube.com/watch?v=YDj_DU7KuMM
(in reply to jatoracing33)
       Post #: 88
RE: nitro to gas conversion (with pictures) - 10/8/2007 7:34:18 PM
Dave ESPI
Status: offline
so simple !
HEY SMARTTECH and MCD ENGINEERS...ARE YOU PAYING ATTENTION ?
hahaha.
I look forward to hearing/seeing it run again
Saying the Baja is aerodynamic for an offroader is sorta like saying a brick is aerodynamic for a piece of cement.
       Post #: 89
RE:
